Question about HP Computers & Internet
For no apparent reason, my cd-rom just began opening and closing continually. Any ideas about what could be causing this erratic behavior? can you provide some possible solutions to try? My computer is an HP pavilion with a Windows XP3 OS. It also has a DVD writer/CD writer combo, a floppy disk and an external Seagate FreeAgent 300Gb hard drive. This is the first significant problem with this three year old computer.
    Problem Solver:
  • 19 Answers
Zimmer, are you connected to the net?? If yes...... OMG your computer has been hacked..... they know the identity of your computer........shut off yourt connection and consult an IT.
Posted on Nov 06, 2008
1988 Chevy Truck 305 Engine Idling and ****** shifting problem
check the vacuum lines going to the tranny, but it sounds like a vacuum leak, when the engine is at idle, spray a few short blasts of starting fluid around all the vacuum lines, if the rpms jump up, thats where the leak is
Jun 07, 2017 | Chevrolet Cars & Trucks
Computer wont recognize printer,power light flashing
The flashing of the power light indicates a problem in the cartridge/s. Try to remove your cartridges from the printer > close the printer cover > unplug and re-plug the printer into the power source to reset > when the printer turns on, reinsert one cartridge first > check the behavior of the power light. If power light does not blink, open the printer cover again and reinsert the other cartridge. Replace whichever cartridge is causing the power light to blink with a new genuine Lexmark supply.
Dec 22, 2011 | Lexmark Z2300 InkJet Printer
My dri8ve will not open and close with the push of the button.
Hi. if you are using a cd rom that dosnt open and close. try the following. unplug your HDD cable to the hard drive. just use cd rom. if cd rom open. you must use a separate cable. if problem continues then you must take cd rom to the nearest Computer electrical expert to fix.
good luck
Nov 11, 2010 | Computers & Internet
I have a HP desktop PC and the DVD/CD ROM keeps opening and closing. How can I fix this? Thanks
It has gone faulty, this is not normal behavior. You will have to replace it. Check the button on the front, ensure it isn't jammed on?
Feb 26, 2010 | E-Machines emachines (emachinees) CD-ROM...
I am not able to install XP sp2...in D865GBF
Several reasons could cause this kind of behavior:
1. Defective power supply.
2. Defective RAM.
3. Hard drive with bad sectors.
4. The CD-ROM drive you are installing from is defective.
Sep 06, 2009 | Intel D865GBF Motherboard
CD Rom Drive opens and closes over and over won't quit
it happens often because of some materials or cd broken pcs try to clean it carefully
Apr 11, 2009 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Has anyone found a fix (short of getting rid of) for Logitech MX 600 Laser Mouse pointer erratic operation?? Seems to work OK on a Flat smooth surface, but jumps all over the place on any mouse pad I have...
  1. Mouse is not clean.
  2. Optical portion of mouse is blocked.
  3. Moisture or other material on finger.
Mouse is not clean Users who have an optical mechanical mouse (most common mouse for desktop computers) are likely experiencing erratic behavior because the mouse is not clean or is dirty. Optical portion of mouse is blocked
Users who have an optical mouse are likely experiencing erratic behavior because a portion of the optical eye is blocked. Most commonly this is caused by a hair.
Moisture or other material on finger Users who are using a touchpad may experience erratic behavior because of moisture or other material on the finger such as lotion.
Mouse has been cleaned and still has problems If you've cleaned the mouse and continue to encounter issues and this mouse has worked in the past fine unfortunately your mouse is likely defective. One additional test that can be done to help determine if this is the case or not is to connect the mouse to another computer. Otherwise we suggest replacing the mouse.
Oct 24, 2008 | Computers & Internet
DVD Rom opens up automatically.
you may wish to re install the drivers for this unit and see if it continues to happen
Oct 14, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Erratic Cursor Behavior
Are you sure your not touching the pad as you type , a common error, cover the pad with card board or plastic and see.
otherwise you may have a bad touchpad and it needs replaced or re-seated on the cable.
Mar 22, 2008 | Computers & Internet
CD player cover/door won't stay closed
The intermittent version of this seems to be related to the cable that goes to the subwoofer portion. Have seen this behavior when the cable got loose. Unfortunately, I believe that this behavior may get worse in the long run and cause CDs to not play at all.
Jan 25, 2008 | Teac CD-X8 CD Shelf System
Computers & Internet Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
