Question about Microsoft Troubleshooting Your Web Page (0-7356-1164-5) for PC
Motorola FRS T9550 has broken transitting between radios
I have 2 hardly used motorola frs T9550 radios. Everything appears to be working and batteries are at full charge. When receiving the voice message the dialog is very broken, every 3rd syllabel is heard. Both radios have the same problem. Distance is not an issue. They are within a few feet to 300 yards apart in clear view and they still dont work.
  • 181 Answers
Www.gbcomms102@aol.com  his name is steve . he can help get you sorted. hope the helps.
Posted on Jun 01, 2009
Can two different style motorola 2 way radios be changed to same frequency
Hi Kate,
The short answer to your question is: no, or "not readily". Here's why:
The Motorola 4900 radio operates in the FRS (family radio service) and GMRS (general mobile radio service) in the UHF band. This radio will work with any other FRS / GMRS band radios (no reprogramming of transmit and or receive frequencies is possible for these radios). The trick is that the numbering of the channels may differ from brand to brand ie: Ch1 on your Motorola may not necessarily be Ch1 on a Midland radio or other brand. A complete list of the frequencies and channel assignments for FRS /GMRS can be found on Pg. 17 of the manual. It is important to note that without a valid GMRS license, you are prohibited from transmitting on the GMRS only channels (Ch 15 through Ch 22). The combination GMRS/FRS channels (Ch1 through Ch7) and the FRS only channels (Ch8 through Ch14) are for individuals and family members that do not have valid GMRS licenses. If this is you, you should limit your transmissions to Ch1 through Ch14 only, as FRS does not require a license in the US. Unlicensed use of GMRS only Ch15 through Ch22 can result in fines and imprisonment if caught by the FCC.
Further complicating the issue are the so called "privacy tones". This is simply a very low or "sub-audible" frequency that is sent whenever transmitting. Motorola calls these "Interference Eliminator Codes". When another radio receiver is set to listen for a particular privacy tone, it stays silent until a transmission with the exact same privacy tone is detected. Again, these tones are listed in no particular order, but are generally listed as 1, 2, 3, etc. or a, b, c, etc. instead of the actual frequency in hertz. You can selectively set your radio to transmit & receive one of the 38 codes or, set the code to "0" to communicate with radio that do not offer these privacy codes - or does not use the same frequencies for these codes. You can read more on Motorola's codes on Pg. 19 of the manual.
The Motorola CP200 radio on the other hand is a commercial radio, and requires computer programming with Motorola software. The CP200 is offered as both Low & High sub-banded VHF and Low, Mid & High sub-banded UHF radios. You would need to have a CP200 that is designed to accept the Mid UHF band (438Mhz - 470Mhz) frequencies in order to program the 462Mhz & 467Mhz FRS / GMRS frequencies into it. The final obstacle would be what is called "FCC Type Acceptance". The CP200 is probably NOT Type Accepted for transmitting FRS/GMRS frequencies, and as such the Motorola dealer doing the programing might balk at putting them in. You can read a spec sheet on the CP200 here.
I hope this helps & good luck!
Feb 29, 2012 | Motorola Radio Communications
Can you use 2 different talkabouts fr50 and t5420 with each other? I have just one of each unfortunately.
  • Yes they will both talk together on the same channels just fine. Most of the more recent Talk About Radios are FRS/GMRS with 22 channels. These radios are FRS only with out the GMRS. The FRS are the first 14 channels in most talk about's as are your radios.
Regards, Tony
May 01, 2011 | Motorola Talkabout FR50 (14 Channels)...
Will the MU21CV radio's work with the talk about radios?
Short answer, maybe. It depends on whether you have a 14 channel or a 30 channel Talk-About. The Motorola Talk-Abouts operate on the FRS frequencies (14 channel) or FRS & GMRS frequencies (30 channel). The MU21CV does cover a few of the GMRS frequencies. (see bold numbers)
GMRS Frequencies
462.500, 462.575, 462.600, 462.625, 462.650, 462.675, 462.700, 462.725, 467.550, 467.575, 467.600, 467.625, 467.650, 467.675, 467.700 & 467.725
FRS Frequencies
462.5625, 462.5875, 462.6125, 462.6375, 462.6625, 462.6875, 462.7125, 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, 467.7125
MU21CV Frequencies
464.500, 464.550, 467.7625, 467.8125, 467.850, 467.875, 467.900, 467.925, 462.575, 462.625, 462.675, 464.325, 464.825, 469.2625, 469.500, 469.550, 462.7625, 462.7875, 462.8125, 462.8375, 462.8625, 462.8875, 462.9125, 464.4875
Nov 01, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
I have a 12 year old Motorola FRS 250 radio that needs a speaker. I would like to find a replacement speaker (internal) but don't know where I can purchase them. I need these radios for a...
You have a few options: check with your local radio dealer or radio shack store for a similar speaker, purchase another used T250 radio via ebay or other source, or simply retire the T250 and purchase another low cost TalkAbout radio. All these radios operate on the same 14 FRS frequencies. Motorola has never supplied parts for this line of consumer radios. They had a replacement warranty, then following the expiration of your warranty they were considered disposable/replaceable. Sorry.
Best regards.
Mar 08, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Describe how you call someone with the motorola talkabout 250
Your question is unclear. Call them from where? Using what device?
If they have an FRS phone, set the channel and privacy code and go.
Feb 09, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Need manual for GMRS FRS 04A08 cannot get radios sound on. Do you have instructions?
Hi!
Here is the user guide for the Motorola Walkie Talkie you have.
http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Please save a copy to your hard drive or produce a printout so that you have a hard copy. This will be very useful if you need it again in the future.
Oct 29, 2009 | Motorola FV200AA GMRS/FRS 2-Way Radio...
I can't find a download for the Motorola Talkabout 250 manual
Grasp the black bottom sides of the radio and tug it hard. No screws to loosen. The bottom slides off. The battery placement will be in there.
Apr 21, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola T5728 walkie talkie freq mismatch
Unfortunately the T5728 is not compatible with the US FRS (family radio service) frequencies. The T5728 operates between 409-410MHz. The FRS radios operate between 460-470 MHz. FRS frequencies are license-free frequencies for use in the US, as regulated by the FCC. Other countries have differing rules and thus their frequencies assigned to family usage differ.
Apr 09, 2009 | Motorola Walkie Talkies 2-Way Radio
Same station same code only working one way motorola 250
If one set has FRS and GMRS channels and the other doesn't, the FRS channels may not match. Try using the lower channels or going up or down one channel.
Aug 14, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Microsoft Troubleshooting Your Web Page (0-7356-1164-5) for PC Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
