SOURCE: Suzuki GS 750 Starting
Hi
Sounds like someone has customised your bike - does it have a RH switchgear?
there shd be 3 connectors for the RH switch in headlamp - a 3 pin & 2 singles, the 3 pin has 2x orange/white + 1x yellow/green, this connects to 1x orange 1x orange/white +1x yellow/green wire which are for the kill + start
The singles are 1x orange/green + 1x white (loom side) which go to 1x orange + 1x white respectively, these are for the brake light
If you are keeping the kill sw then its only the yellow/green wire that can be discarded.You can also follow it back to the starter disconnect sw - junk that - keep tracing it back to the starter solenoid & junk that too. If you want to keep the electrical accessory output terminal then connect that straight to the battery or to the orange wire from the ign sw to the fuse box. You can also junk the thick wires from the solenoid, 1x to batt + 1x to the starter motor
You can junk the starter motor too ( 2 bolts then pull away from sidecase & up at the rear) but make sure you block the hole up!
If you want to bypass the ign sw then disconnect the 4 block from it & jump the red to the orange & also the brown to grey (for lights etc)
Good luck & ride safe
Bike-Doc
SOURCE: My 2008 gsxr 600 that i bought 2 days ago is
Its nothing to do with the damper
The battery may not be accepting charge due to its age or condition (although as u can bump it soon after it sounds ok). Check this out with a charger & meter
There may be a bad or dirty connection somewhere between the alternator & regulator/rectifier or from there to the battery
It could also be a defective alternator winding or regulator/rectifier unit
Ride Safe
Bike-doc
Please mark this as useful (if it has been!!)
SOURCE: suzuki gsxr 600 06 starting problems
200° is quite warm...
If the engine wont turn over, probabily you have a bad battery, a bad starter or a bad starter relay, or bad connections.
A hot engine has more compression. If the full battery power doesn't reach the starter it won't turn over...
SOURCE: i have a 05 gsxr 750, replaced battery, now no start.
Hi and welcome to FixYa,
Initially, try starting with the clutch lever pulled in and / or the sidestand folded up. Additionally, determine if there is a clicking sound. If there is, then it would most likely be the starter solenoid.
Good luck and thank yu for asking FixYa.
SOURCE: 2007 drz400 push start button and nothing
You got it, faulty starter solenoid or wiring from switch to solenoid.
Silly question but is the kill switch on??
