Question about Kitchen Ranges
St. Croix Pellet Stove stops working
I have a St Croix insert (York) that works fine for the first few minutes, but then it seems as though the auger stops feeding the burn pot. If I push the button on the side to manually feed, the auger turns and feeds pellets to the burn pot. Once I stop manually feeding, then it ceases to continue feeding, and the fire will eventually go out. I've emptied the hopper, and completely cleaned the stove and hopper.
Thoughts?
Thanks,
Gary
  • 2 more comments
  • jill_mazz Nov 12, 2008
    We have the same issue. The York was just installed today. The installer started the stove, left, and the stove stopped about an hour afterward. We keep starting it up again, but once the pellets we've added to the burn pot die out, the stove stops.
    We keep hearing clicking as if the auger is trying to go on, but no go.
  • gpierce Jan 02, 2009
    Hi, I have the same insert and the same exact problem. I notice the auger light will go on but the auger does not run. However, some of the time the auger will kick in. However, more often than not the auger does not run and my pellet stove fames out.
  • MendotaDude Jan 09, 2009
    Is it in thermostat mode or manual? Also, does the on/off light blink when this is happening?
  • Anonymous Apr 19, 2009
    same problem no auto feed
3 Suggested Answers
SOURCE: St Croix pellet stove: pellets drop
ignitior is bad ....
Posted on Mar 29, 2008
http://www.jaygaulard.com/blog/2009/01/18/how-to-clean-out-a-st-croix-prescott-exl-pellet-stove/
Posted on Feb 24, 2009
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Heard a bang auger stopped moving seems loose. What's wrong?
Could be a broken safety drive pit in the auger if there is one. I am not sure but just an idea.
Dec 31, 2015 | Us Stove Company US Stove King Pellet...
My st croix Hastings pellet stove is 3 yrs old and is not blowing as much heat as it has in the past. What could be the problem?
Hi, Check to see if vents are free of debree (spider webs etc...) Clean fan if necessary. Also try a different pellet some pellets will burn hotter. Good Luck.
Feb 04, 2015 | Heating & Cooling
Auger not working on Blaze King Pellet Stove
depending on how the manufacturer set up the system, there may be pellets wedging the auger. most augers are geared low enough to snap the pellet but if its something else blocking it (stick or rock etc) it may have blown a fuse for the auger drive or the drive mechanism itself. if you are going to work on the auger. UNPLUG THE STOVE AND USE TOOLS TO CLEAR BLOCKAGE as there may still be some pressure to spin auger
Aug 07, 2017 | Pool & Spa
I purchases an elcipse pellet stove in 1990. It still works perfectly. I need to replace the insulation blocks for the side walls and also need a new ash pan. Do you know where i can purchase these items.
Elcipse was manufactured by Warnock Hersey, but was sold to St Croix. So, their parts may be interchangeable with your stove. Try Pellet Stove Parts.com and click on other brands for St Croix.
http://www.pelletstoveparts.com/mm5/merchant.mvc?
Feb 22, 2011 | Heating & Cooling
Auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Jul 08, 2009 | Napoleon Auburn Pellet Stove Heater
St.croix pellet stove
your either burnig the wrong type of fuel, or the fuel you are burning is wet, not burning hot enough resulting in cloudy door
Feb 03, 2009 | Kitchen Ranges
St croix pellet stove
Had the same problem which I discovered this weekend..........
I have an eleven year old Afton Bay....the versa grate was not moving. I look into the inner workings of the stove and saw a bracket which had broken off....
The bracket was attached to the versa grate rod and made contact with the cam system in the stove...this is what moves the versa grate...........
I called my dealer, the part costs about $12.00 and looks like it can be replaced with out having a service guy come out..........
Hope this helps
Oct 21, 2008 | Kitchen Ranges
Kitchen Ranges Logo
747 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
