SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
SOURCE: Janome, memory craft 4800, sewing machine
how to delete programmed patterns and start new lettering
SOURCE: Breaking Needle Thread Janone Memory
Several possibilities
1. The needle thread is not threaded properly.
2. The needle thread tension is too tight.
3. The needle is bent or blunt.
4. The needle is incorrectly inserted.
5. The fabric is not being drawn to the back when sewing is finished.
6. The thread is either too heavy or too fine for the needle.
7. Old perished thread. Use quality thread for best results.
8. Needleplate burred near hole, from needlestrikes
9. Hook is burred (Feel the tip of the hook under bobbincase with your finger....polish with 1600 emery paper carefully)
SOURCE: I've lost the 'foot holder' (that holds the
try www.sewingpartsonline.com for replacement parts
http://www.sewingpartsonline.com/presser-foot-shank-elna-janome-kenmore-804509000.aspx looks like it is the one you need I think.
