Question about Technics SL-MC6 CD Player
Disc gets jammed mid-way between CD magazine slot and inside player
Technics Compact 110 Disc Changer, Model #SL-MC6: Disc gets jammed mid-way between CD magazine slot and inside player. Jammed Disc does not play. User needs to manually pull disc out, slightly forcefully. Something seems to be blocking the Disc from reaching the actual playing area. System does not recognize that a disc exists. Screen continuously displays 'Checking Discs."
  • 2 more comments
  • Glennis Bohn Oct 06, 2006
    Does anyone have a manual I can purchase for Model #SL-MC6? Is a manual available on-line?
  • Anonymous Mar 23, 2014
    MOTOR RUNNING BUT BELT TENSION IS GONE
  • Anonymous Mar 30, 2014
    61 disc cd changer model sl-mc4 will not load. Checking for discs scrolls continuously across screen
  • Anonymous Mar 31, 2014
    System turns itself off if playing CD's at more than about 50% (-26dB) volume. No problem with the tuner at high volume, just the CD player
    President:
  • 3,130 Answers
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
Stuck in "checking discs" mode
Obviously your device is not working and you should seek professonal assistance..
Jun 08, 2015 | Technics SL-MC7 110-Disc CD Changer
Technics sl- mc6 110 disc changer just keeps saying checking disc dosnt respond to of the buttons
this is a common thing to happen when the laser gets dirty or out of tracking , as it cant "see" any of the disks so it's "checking disk" forever
Mar 05, 2015 | Technics SL-MC6 CD Player
SL MC6 110+1 disc changer door gets stuck at about a fingertip's width. Seems to be small plastic guides and the one on the left seems to be stuck. Anyone know how to unstick it?
if you have kids, it is likely that they put something in it. even if that's not the case, you may have to open it to fix the problem. best luck to you!
Dec 06, 2014 | Technics SL-MC6 CD Player
Door will not open,get checking disc message
I solvwed the problem by removing the cover and found 2 discs jammed into the same slot. removed them and put them in the proiper slos, put back cover, gently tightening the screws incase it happens again.
technics 110 cd changer. model sl-mc310.
Dec 20, 2009 | Technics Audio Players & Recorders
CD CHANGER BROKE
Have the same problem only mine does it on all slots. It appears the finger which removes the disk from the tray does not slide foward to "pick" the disk. Don't know why, tried to pull it and it will not move foward I was hoping this sight might have some sort of exploded view of the linkages but doesn't.
Jul 28, 2007 | Technics SL-MC7 110-Disc CD Changer
Technics SL-MC6 CD player
You have to removo all disc
Then turn on the unit and let do the initialization process
May 26, 2007 | Technics SL-MC6 CD Player
Technics SL-MC6 CD Player Logo
413 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
