Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
GE washing machine has Squealing during agitation only. Pretty loud.
I have a squealing in my GE washing machine while it is agitating, only, not spin. Is this the agitator coupling, motor coupling or the transmission?
Thanks
  • bgwinger Nov 05, 2008
    I have same problem...only model is GEĀ wwjrr4170g0ww.
  • Crashgal Feb 23, 2009
    Mt Whirlpool Ultimate Care II #LSQ9564JQ0 makes short a short but loud squeal sound upon each agitation. It does not squeal during any other parts of the cycle, only agitation.
Buffalo12980
  • 625 Answers
SOURCE: Loud noise
sounds like the absence of lubrication in the transmission. could be a bad bearing on the pulley side
Posted on Sep 25, 2007
Jimster
  • 240 Answers
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Posted on Oct 24, 2007
SOURCE: Whirlpool Washing Machine Top Load LSC9355AN0 agitator frozen
Had the same problem, just hade to replace the agitator.there are teeth on it and it was stripped out.
Posted on Feb 25, 2008
SOURCE: Won't spin or agitate
Sounds like a burning out motor to me...
Posted on Aug 02, 2008
SOURCE: agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Posted on Oct 28, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
Feb 16, 2015 | KitchenAid Washing Machines
GE Top Load Washer Loud Squealing Noise
Would check belt for tightness and it is also possible you have a dry bearing in pulley, motor etc.
Nov 21, 2017 | GE Profile WPRE6100G Top Load Washer
Squealing during agitation...drum seems to be 'sticking' ....
could be several things if it is an intermittent squeak that goes in time with the agitation then you have bad brakes if it is constant then you may have a bad pump or object in the pump
Sep 19, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Performa PAVT920AWW washer makes a squealing sound
i am sorry but i had this problem happen before with my customer maytag performa, what i found out is that the brakes become crystallized, causeing a squeaking noise, remember in agitation, the brakes stops the the drum from spinning, what i advise you to do is change out the breaks or take the brake pads and rub them with sand paper
thanks
Aug 23, 2009 | Washing Machines
Loud squealing during agitation
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 12, 2009 | Kenmore Washing Machines
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Loud noise
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
280 people viewed this question
Dan Webster
Dan Webster
Sal De
