Back to:
Tags:
Dell PowerConnect 2016  Networking Switch
Issues with Network (by 2 users)
posted by Millwork on Oct 06, 2006
The connection is fine from the modem to the dell powerconnect 2016 and every computer states that it is connected but cannot get onto the internet. A bad storm knocked out the power and ever since it has rebooted none of the computers has yet to connect to the internet.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by mycrd4ace, posted on Jul 13, 2008
ONE COMPUTER IS CONECTED TO THE INTERNET(MY MAIN COMPUTER) THE 2ND ONE SAYS IT IS BUT NO INTERNET,
Best Solution
posted on Oct 06, 2006
Helpful (85)
dugiehowsa
Rank:Wiz Wiz
Rating: 78%, 757 votes
In order to get to the Internet, a computer must have proper IP connectivity. Lets start by troubleshooting IP connectivity in your office and see where the breakdown is.
Open a command prompt on a machine. This can be done by going to Start -> run and typing the following:
cmd:
Then hit OK. A small window should open up with black background and white text.
In this window, type the following command:
ipconfig /all
Hit return. You should have output like this:
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom 570x Gigabit Integrated Controller
Physical Address. . . . . . . . . : 00-0B-DB-99-81-00
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 10.10.30.27
Subnet Mask . . . . . . . . . . . : 255.255.254.0
Default Gateway . . . . . . . . . : 10.10.30.1
DHCP Server . . . . . . . . . . . : 192.168.1.52
DNS Servers . . . . . . . . . . . : 10.10.30.10
192.168.1.24
Primary WINS Server . . . . . . . : 10.10.30.10
Secondary WINS Server . . . . . . : 192.168.1.24
Lease Obtained. . . . . . . . . . : Friday, October 06, 2006 1:46:55 AM
Lease Expires . . . . . . . . . . : Saturday, October 07, 2006 1:46:55 AM
Take note of the value for Default Gateway. Trying pinging this IP address with the following commmand:
ping 10.10.30.1
You should get a response like this:
Pinging 10.10.30.1 with 32 bytes of data:
Reply from 10.10.30.1: bytes=32 time<1ms TTL=255
Reply from 10.10.30.1: bytes=32 time=1ms TTL=255
Ping statistics for 10.10.30.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
Look at the % loss item. If this is zero, that is good. If it is 25%, try running the command again and see if it comes up as 0 the 2nd time (some times this happens and is normal).
If you continually get non-zero values, then there is a problem with your default gateway.
Run the same commands on another computer. Try pinging the IP address of the first computer from the second computer. If you cannot do this, then there is a problem with the switch.
Another thing to note is that if the IP address values come up as 169.254.x.x, and there is no default gateway, then there is a problem with your DHCP server.
Also, check to make sure there are values listed for DNS servers. If there are no values for DNS servers, then you will not be able to get out to the Internet.
Unfortunately, there are many different things that could be wrong with your environment. Hopefully this will give you some ideas as to where to start trouble shooting.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Issues with Network:
I don't want to Accept this solution
Solution #2
posted on Jan 28, 2007
Thanks for Trying (70)
pavi
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
hey millwork can u plz explain how many computer you are using and whether u r using a hub,switch or a router so that i can hav a fair idea about the problem and i would like to tell u that this is a common problem you are facing hence plz get me the information so that i can help you further.
thanx.
Thank You!
Solution #3
posted on Feb 27, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
This is very good suggestion.
But where and how to set the DHCP & DNS ?
Thanks
Thank You!
Can you Help with these Networking Hubs and Switches problems?
yellow steady, for a while after flashing all ports etc.
I have an N-tron 9000 that has two 9006TX's in the last...
lucas 7 SA seven pin need wiring diagram
hi, when i am trying to dial then after some time...
Got a call from a tenant that his thermostat was reading...
Loading problems.
Repair Service
Find Networking Hub and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
