Question about Canon PowerShot A560 Digital Camera
Erratic Low Battery Warning
I replaced new alkaline battery and different brand but it shows low battery Warning and shuts down. help me what should i do? thanks
  • 14 Answers
Cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Posted on Aug 21, 2009
Samsung Digimax D53 Camera says low battery but just replaced with brand new ones. Camera beeps and shuts down immediately.
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Jul 22, 2009 | Samsung Digimax D53 Digital Camera
Battery life
The rechargeables are only meant to last a couple years maximum (pretty good that you got three out of them). Also rechargeable NiMH's have approximately 5 times the power of standard alkaline batteries. Alkaline batteries should only be used in emergencies in digital cameras as they will only last for a short while before they are drained (as you've discovered).
The obvious solution is that it's time to consider purchasing a new set of rechargeable NiMH batteries. Look on the package for a power rating of at least 2,500 mah. Avoid batteries that do not list the power rating as they are generally inferior batteries.
Jul 20, 2009 | Canon PowerShot A710 IS Digital Camera
Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Jun 18, 2009 | Samsung Digimax D53 Digital Camera
Says low batteries and shuts off. Batteries are brand new.
1. clean and adjust the springs in the battery compartment
2. use the right batteries, alkaline or NiMH, etc.
this tips may help
Why my camera keeps saying ‘change battery’ even with new batteries?
May 18, 2009 | Panasonic Cameras
Fuji Finepix s700
I recommend to all my customers with AA battery life issues to try Energizer Lithium AA's. Virtually all battery issues solved. I think alkaline batteries are being manufactured poorly, these days, so even brand new they aren't great.
Mar 08, 2009 | Fuji Finepix S9600 Digital Camera
Battery exhausted warning
Hello justplainles:
Do the others show the same problem?
Try this: RESET ALL in the menu or setup menu.
If that does not work, make sure that the in the menu (if it is there) you set the battery type to rechargeable not alkaline .
You may try alkaline batteries, if it does the same, the camera may need repair.
Some cameras will not set the battery type automatically.
Aug 25, 2008 | GE A730 Digital Camera
No battery life
If you have changed to new batteries and it still shows low battery warning, the camera may need the repair service.
Here is the information from Canon's support page.
Batteries do not last very long in camera (You will need to copy and paste the title on the search field)
"Solution: The PowerShot A550 requires service.
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Links to the service options that are available for your product are listed below: ..."
Jul 10, 2008 | Canon PowerShot A550 Digital Camera
False low battery warning
Same thing happened to me when I used alkaline batteries. Have you tried fully charged NiMH? If not you may have a "leak". Your next option is the service center.
Jun 27, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
Nov 29, 2007 | Samsung Digimax A7 Digital Camera
Low battery indicator
Just a quick question (dont rate yet) Are the AAA's alkalines?
Oct 02, 2007 | Sony Cyber-Shot DSC-U10 Digital Camera
Canon PowerShot A560 Digital Camera Logo
356 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
