My protron PLTV-32CM model LT32c1m1 they power and after a few second they stop the sound work but the image dont display black screen, sorry for my english thanks. merci Eric
  • galerie5 Nov 05, 2008
    the display of the screen not work enough to see the bleu screen for see the menu to make the modification galerie5
    Top Expert:
  • Televison & ... Master
  • 70,346 Answers
You can have the TV repaired for most likely about $600 after all is said and done, the manufacturerers don't sell indiviual parts for the circuit boards that fail and give you your problem, new large screen's like Viszo sell for around $900 for a 42" LCD, just replace it, since after all the TV will most likely develope a problem again, more money wasted.
Posted on Nov 05, 2008
    Brigadier General:
  • 6,966 Answers
The could be a number of reasons why the unit fails to work:
  • being an LCD, foremost to check would be the CCF lamps and the inverter unit that powers them;
  • you can verify this by shining a flashlight diagonally to the screen while pressing on the volume control and see if you can see the semblance of the volume level going up (except of course it is dark);
  • it could be the power supply board. Common culprits are leaky/blistered capacitors due to the heat build-up internally.
For a better diagnosis, the unit has to be opened up. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional. if the unit is still under warranty, you may need to contact your point of purchase or an authorized Protron Service Center near you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 05, 2008
    Have you confirmed if it is the CCF Lamps and/or the inverters?
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
    Brigadier General:
  • 3,614 Answers
first try to Adjust/Set the resolution to 480 output to 720 or 1080...
let me know.
Have protron pltv-32cm. model lt32c1m1. how do i shut off the v-chip block? i don't have the password.
Hello, there is a default password, if you source is in component 2 it can't be used here are some links to the pdf file pltv types.
V-Chip Lock When turned on, blocks access to mature television and movie content, based on the MPAA and TV PG ratings selected below, unless the viewer enters a password (set below). Set Password Sets the V-Chip password. To change the password, enter the current password followed by the new password. The factory-default password is '1234'.
PROTRON PLTV 32C User Manual Parental Controls
hope this can help.
Feb 21, 2015 | Protron PLTV-32 Television
Why does it take longer for the volume of my Protron pltv-32cm to go on each time we turn the tv on?
Proton 32, most plasma and lcd TV's have internal boards a few control the stability or video display these secondary boards are controlled by a main board. if your having sound or tv function issues the main board may be defective. is it worth fixing? that depends on the service center and what they are estimating it to cost. it is repairable by replacing the main board and that's if your screen itself is not the factor yet also consider the price for the repair vs. the price of a new set. you can get this part at auction sites or buy it online and repair it yourself or with a someone who understands electronics that would save you some cash. best regards..
Jun 14, 2014 | Protron PLTV-32 Television
Does the protron pltv 32cm (model name LT32c1m1 - 2005) works in Brazil? do I need to buy any accessors to make it works?
Where did u bought this tv?Buy it from Asia,Europe,Austria,Africa,middle East?All these countries places are using the same frequencies signal which is PAL,and used 230V.Buy it from USA,Mexico,Canada?All these contries places are using the same frequencies signal which is NTSC,and used 120V.
May 24, 2011 | Protron PLTV-32 Television
I HAVE A PROTRON PLTV-32CM AND LAST WEEK IT JUST WENT OUT. NOW ALL IT DOES IS WHEN YOU CUT THE POWER ON IT JUST GOES AFTER ABOUT 3-4 SECONDS. I REMOVED THE BACK COVER AND ALL THE CAPISTORS LOOKS OK. WHAT...
Protron's mainboards like to fry and a replacement is difficult to find. Protron tvs are built with very cheap parts and don't follow manufacturing guildlines very well and are difficult to find parts for. I would start with the mainboard as the power supplys don't usually fail in these tvs.
Best of luck and please rate if this helped :)
Mar 11, 2011 | Protron PLTV-32 Television
I have lost the sound on my PLTV-32CM, MFG date 10/17/05, can't reach an answer on the troubleshooting line
Try hooking up the powered PC speakers to the Audio line out RCA jacks to see if you get the sound OK, if you do, then the power amp circuits are bad (main board may have to be replaced). Need to verfy that first.
Nov 08, 2009 | Protron PLTV-32 Television
Needs New LCD Panel
I have a screen but need the vga card if you want to contact will sell for 300
Sep 05, 2008 | Protron PLTV-32 Television
PLTV-32CM THE REMOTE HAS NO CONTROL ON TV THE BUTTONS ON TOP OF TV WILL RUN THE TV THE BATTERY ARE GOOD
Remote not working...turned t v on with it and then it stopped working...where can I get replacement??
May 19, 2008 | Protron PLTV-32 Television
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
Electro Med Services...
