Question about White Sewing 1418 Mechanical Sewing Machine
White sewing machine tension trouble
The machine is knotting all the stitches just like the tension is off
  • 136 Answers
Check top threading carefully
Posted on Jul 12, 2009
I have a 9020 singer sewing machine I bought without a manual. I can't seem to sew without looping the thread under it. Almost in knots.
Are you saying the upper thread is knotting under the fabric as it stitches? This is bird nesting or thread nesting and is generally caused by mis-threading, the thread not being seated in the tension disk, or the upper tension too loose.
When threading the upper thread, ALWAYS RAISE the presser foot. Verify that the machine is threaded correctly. If one guide is missed, the stitching will go haywire. Start out with the upper tension set around the midway point and then tweak it through test stitching.
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 22, 2016 | Singer Sewing Machines
All seems fine & threded correctly but will not stitch [knot]
from your description I guess that the knot is under the material
If so then the top thread is too loose
tighten it up a fair bit and use scrap material until you get it right
Dec 09, 2015 | White Sewing Sewing Machines
I have a singer 500/550 .I'm trying too sew a straight stitch ,but I'm having trouble with the tension. What's the best setting? And i can't sew with needle in the middle position. Why
500/550? wow, that an old one. have you check your timing? or the bevel gears?
what type of problems are you having with the sewing. is the thread knotting up on the back side of the fabric? is the thread just breaking? or is it just missing stitches? does the needle hit the bobbin case?
I have a 600 series and I found that if i put the tension around 2 or 3 it sews the best.
too tight the tread breaks, too lose the thread knots up on the back.
I had to change out the bevel gears and have the machine re-time to stop the miss-stitching.
also may want to check your bobbin tension.
May 29, 2015 | Singer Sewing Machines
White 3100 just knots in stitching
when you say knotting, do you mean a snarl up of looped thread on the underside. If so check top thread tension
Dec 26, 2013 | White Sewing Sewing Machines
White Style-maker 3100 knotting
again check needle thread tension
Dec 26, 2013 | Sewing Machines
My stitch does not sew on right side of fabric. I sew & see the underside of the stitch. I remove the fabric & the stitch is on the underside.... Never known sewing machine to do this. Help!!
Hi. first thing is to remove the threads from the machine, top thread and the bobbin, and replace to manufactures instructions. If still the same the problem sounds as if there is no tension on the bobbin [under] thread, adjust to a light tension. Then adjust top thread tension until the knot is in the middle of the cloth. Most times people keep tightening the top tension..
Aug 10, 2013 | Brother XL-2600I
Can't set the tension on needle or bobbin to match
1. make sure your machine is threaded right.2. set the tension between 3 and 4 and play with the tension as you need it to adjust it.3. make sure the bobbin is threaded right.make sure to visit the site below; it has solutions to multiple problems and instructions how to thread the needle or bobbin. Good luck.htt://Fix Looping/Knotting Thread Fix Knotting/Bunching Thread Looping Bunching & Knotting Thread
Aug 03, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Bunches of threads on the bottom
Try threading the machine with the presser foot up.
This opens the tension and allows the thread to seat into the tension control.
When the thread is not properly seated, there isn't any tension on the top thread the bobbin thread cannot make a proper stitch with a top thead that is loosey-goosey.
Mar 20, 2010 | Sewing Machines
The thresd gets knotted and it won't stitch
Rethread your machine
Make sure your cotton runs through the two tension plates
Check that your top tension is set on 5
Make sure your bobbin case is threaded correctly
Lastly, make sure there is no cotton stuck between your top tension's plates(take a long needle and remove any fluff)
Sep 14, 2009 | Singer 6038 Mechanical Sewing Machine
White Sewing 1418 Mechanical Sewing Machine Logo
122 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
