Question about Maytag Washing Machines
Need directions to replace timer on Maytag Washer PAV1000AWW.
  • 62 Answers
First unplug washer from power , remove back panel of control panel, there should be a large molex connector maybe 2 of these connectors that plug into timer they usually have a clip that holds them into the timer there may be a release for the timer knob that would be on the back of the timer. Remove any screws holding the timer to the panel. plug connector blocks back into timer, most of the time they will only fit one way and if there is two of these connectors they only fit in the right one , the right way . I suppose if you tried hard enough you could possibly get them to fit in the wrong way or the wrong spot but that would be a lot of work. Reassemble in the same way you disassembled replace back panel of control panel happy washing. By the way how do you know the timer is bad?
Posted on Nov 05, 2008
  • Hank Apr 15, 2011
    To unscrew the front knob, you must keep the knob push in while turning counter-clockwise.
Maytag PAV1000AWW comes unbalanced a lot. What repair parts would be involved?
What you would probably need is a part called a snubber which affects the balance if it is worn out.
Part number 21002026
Thank you
Aug 03, 2011 | Maytag Performa PAV2200
Maytag Performa PAV1000AWW. Motor buzzes but does not turn.
Your motor has gone bad...
you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Aug 13, 2010 | Maytag Washing Machines
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
Maytag pav1000aww stopped working
Sounds Like Your Belt Broke And Seized The Motor.
Jan 12, 2009 | Washing Machines
Warm water temp Maytag PAV1000aww washer
Perhaps you need to simply open the hot and cold water faucets all the way.
Jan 05, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer. Model PAV1000AWW: It won't spin. Agitates OK. Water pumps out OK. Just won't spin. Makes no unusual noise. Bad transmission?
If the motor is spinning fast, but the tub is not spinning, then it is the transmission. If the motor is not spinning, then the high speed windings of the motor are shot and it needs a new motor.
Sep 06, 2008 | Maytag Washing Machines
This is probably a timer problem. In maytag washers the motor turns in one direction to wash, the opposite direction to spin. The timer decides which direction to start the motor.
Jul 05, 2008 | Estate TAWX700JQ Top Load Washer
Maytag PAV1000AWW washing Machine
Your machine has a two speed motor. If the motor hums as it tries to spin in the normal cycle, it could be the motor. If there is no noise, it could be a timer related issue.
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
Washing Machines Logo
147 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
