Question about Goldstar MV-1526 Microwave Oven
Gold Star Microwave- model MV 1500MG
The door glass is stained brown - how do I clean it-It is in between the panes
  • Goldstar Master
  • 9,098 Answers
Normallyyou have to separate the door panels (as shown in the attached photo)and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
There are many good suggestions for cleaning and deodorizing microwaves here.
Posted on Nov 08, 2008
How can I remove the door glass?
You really don't want to undertake this task.
Feb 16, 2016 | In Microwave Ovens
What is the cfm of a goldstar OTR microwave oven model mv-1500mg
CFM would be "cubic feet per minute", which is a measure of how much air the cooling or vent fan pushes. That specification is not listed in the Goldstar / LG owner's manuals or service manuals I've seen.
If you might mean the cubic feet (CF) size of the cooking cavity, the M1500-series have 1.5CF capacities.
Mar 09, 2013 | Goldstar MV-1501 Microwave Oven
My Panasonic Genius NNP295SF has moisture run stains between the glass to fix please?
You might want to talk to Panasonic customer service---either it can be taken apart and cleaned etc or it is a sealed unit and would have to be replaced completely.
Dec 10, 2012 | Panasonic NN-P295SF Microwave Oven
I have a Gold Star Model MV-1500MG over the range model microwave oven. Everything works except it will not heat and the turn table does not turn. While it is running everything sounds normal but does...
Hello, does the control panel light up? If it doesn't then probably the fuse has shorted. Now, if the front control panel does light up. There a number of thing going on. Door closer switch is working.
The mega-tron tube is shot or something is going on the micropressor. Now, if the mega-tron is shot. Buy a new micro wave oven and allways to recycle used appliances. GB...stewbison
Aug 22, 2011 | Goldstar MV-1526 Microwave Oven
How do you clean moisture stains from between the door glass?
If they are stains, not too much can be done except for taking apart the glass and cleaning. If it's just moisture, you can shine an auto/shop trouble light (the old kind that get warm, not the new flourescent ones) on it to slowly heat it up and dry it out. Be careful not to get the door glass to warm or it may warp. Best is to just get it a bit warm and keep the light on it for several hours.
Jan 31, 2011 | Microwave Ovens
On a goldstar microwave oven model mv-1500mg, after pressing the light button, there was a bang and then no power to anything. I have checked the electrical outlet and there is no problem. Thanks for your...
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Dec 19, 2010 | Goldstar MV-1526 Microwave Oven
I need to clean brown stain and scale (?) from two 'plastic' tea kettles, one a Chefmate, the other a Kitchen Gourmet. The latter is much more stained than the other, with entire interior incuding spout...
If you can find this product: (Or order it online)
el-4.jpg Picture: To find a distributor: 800.528.3149
Shower Tub & Tile Cleaner
  • CLEANS everyday scale, calcium, hard water spots, soap scum & body oils on showers, bathtubs, tile and sinks.
  • EFFECTIVE on glass, fiberglass, clear plastics, ceramics, aluminum, stainless steel, brass, chrome, porcelain and cultured marble surfaces.
  • UNIQUE biodegradable, cherry-scented chemistry. 32 fl. oz. size (950 ml)
  • Non-toxic, non-fuming non-abrasive, non-corrosive, non-flammable
  • Biodegradable
  • Removes soap scum, scale, hard water deposits and body oils
  • Safe on plexiglass, plastic fiberglass, chrome, brass, gold, silver and ceramic
It is carried by Ace Hardware $6.49 ea
An awesome product that you spray on and let sit overnight. then simply wash it off. (Non Toxic / Non corrosive) No gloves required but does have an odd odor so I would let it soak outside. Heavy accumulations may require a second treatment.
Also great on shower heads. Remove it.. place it in a glass overnight and then re-install the next moring. Does not discolor anything. Ditto for shower enclosures and tile. Why this product is not in great demand is a mystery.
Link with picture: (out of stock!)
THIS WILL Clean it.
Sep 10, 2010 | Microwave Ovens
There are stains in between the glass on the door. How can I remove and clean this?
Hello :
Disassembling the door yourself will void the warranty and may require a service technician to repair any damage or put the door back together. It is recommended that a service technician complete this for you. It is not recommended that you disassemble the door yourself.
Things You Will Need:
Glass cleaner
Soft cloths
Glass stovetop cleaner
Steps to Remove the Glass:
Make an appointment with a service technician to remove the glass from the door.
Use glass cleaner to remove as much of the debris as possible.
For tougher stains and food debris, use a glass stovetop cleaner to aid with removal.
Once the stains and debris are removed, allow the service technician to reassemble the door.
Cleaning Through the Door Vents:
When the glass cannot be removed or is no longer covered by the warranty, there are other, more creative, ways that can be used to clean it.
Long handled cleaner
Bottle brush
Yardstick/ruler wrapped in cloth
Bent hanger wrapped in cloth
Dryer vent brush
Glass cleaner
Soft cloths/towels/long socks
Duct tape (optional)
Steps to Clean Between the Glass:
Some Microwave ovens have small vents along the bottom or top of the door. These vents go in between the glass (and are likely part of the problem with other materials getting in there as well). By inserting a towel on a long-handled stick, you can gently clean between the glass without disassembling the door.First, find the vents on the door if you have them.
It may be easier to remove the door from the hinges and lay it flat on the floor. Many microwave oven doors simply lift right off of the hinges, others will require loosening a few screws first. Replacing the door should be easy to do at the end of the cleaning and will not void the warranty.
Start by choosing a long-handled cleaning tool. There are a variety of options available, so be creative.
Secure a towel or soft cloth (long socks work well) to the handle with duct tape or other strong tape. Make sure it’s well fastened so it doesn’t come off and become stuck in the door.
Moisten the towel or soft cloth with the window cleaner or other cleaning product.
Insert the cleaning tool through the vents.
Move the cloth back and forth to remove the debris from between the glass.
Remove the cloth.
Repeat with a clean cloth until all of the debris is gone.
Replace the door on the oven and enjoy the clear, clean view.
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Whirlpool MH7140XF Microwave Oven
Need help with my Gold Star microwave.
i just took out my fuse on the same model. you have to pull down the microwave and take cover off. there should be like 6 screws on backside and cover will slide back and off. then you will see a fuse cover with a small cylinder fuse in a plastic cover. pull it out and check continuity with volt meter. mine unfortunately came up good still, so i dont know what kinda problem mine is having. had a short in light and it popped and power was gone. good luck!!
Mar 08, 2009 | Goldstar MV-1526 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
508 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
