Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosche dishwasher dishwasher quit during cycle, no power, is not the fuse box
  • 1 more comment
  • petro5045 Nov 06, 2008
    dishwasher runs for a short time then shuts off. I let it stand with the power off for about 15 minutes and then it will run for a short time again
  • Guy Bob Dec 22, 2008
    I too have a SHU 43 dishwasher. It runs for a short amount of time; normal and power scrub cycle. After a short while running it stops. I unplug the power and let it sit for about 15 minutes or so and it starts back up again. Sometimes it will complete the wash cycle, other times, it stops again.
    I check the J box and all connections are good. While it is "off" I can remove the panel and move the red drain plunger and it will drain the machine; however, nothing is displayed on the controls.
    What do you think?
  • dittim May 11, 2010
    We have this problem with the Siemens. Wire nuts are melted, don't quite understand the solution, but it is the same problem, can you clarify ? Thank you
  • 42 Answers
Check the junction box under the dw on the right front side. sometimes where the power lines come in they fail to tighten the wire nuts and they heat up over time and melt leading to the kind of problem your describing
Posted on Dec 20, 2008
Replaced control panel for dishwasher and it still won't run
sound like the thermal fuse on the main control board is bad. replace the fuse and it will be ok. the fuse is the white rectangle with a black, and a black w/white stripe that clips to the top of the control.
Jan 31, 2012 | KitchenAid Dishwashers
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher without power
Check the electrical source. Possibly the breaker blew or he plug went bad.
The electrical load varies drastically during a cycle due to heater, motor, etc. If the breaker blew, ONLY reset it ONCE to try as there may have been a serious problem within the dishwasher. ALSO if the unit shares the power with another device that could cause the problem.
Sep 05, 2009 | Bosch Dishwashers
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher
small_9_26.jpg For a detailed Dishwasher illustration, click below.
redarrow.gif Built in
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Hope this may help;
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
hi there first i would confirm you don't have power supply issue, replace the fuse and try different power outlet failing that it is quite common for bosch on/off switchs to burn out.
hope this is of some help
Dec 14, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher SHX33A
I had the same problem. The motor had to be replaced. For as much as we paid for this it has not lived up to the Bosch name. It's never been as quiet as other people talk about, and then the motor went out! It's only 2 years old.
Aug 18, 2007 | Bosch 24 in. SHX33A02 / SHX33A06...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
207 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
