Question about DISH Network IR Remote Control
Help hoe can i program the remote control number 8.0 uhf pro, because my receiver not recognize that code thks
  • 374 Answers
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
This is the easier of the two methods as it sometimes will find codes that will work but are not listed. If you prefer to try the method of entering in the code numbers for your TV I gladly get them for you however I will need to know the brand of tv and if it is a combo DVD or VHS model, your receiver type, and the remote type which can be found on the back of thew remote. I also have provided the link to Dish Networks Tech Portal SO YOU CAN LOOK UP THE CODES FOR THE TV TYPE THAT YOU HAVE BASED ON THE RECEIVER YOU ARE USING THE 8.0 IN CONJUNCTION WITH. The 8.0 was only issued with the 381 and 811 receivers and are pretty old from the technology standpoint and therefore newer model tvs may not be supported by this remote.
If this remote was sent to you though as a replacement and will not operate the receiver please let me know that as well as that will be a different procedure. I hope this assists you and thank you for using Fix Ya. Let me know if I can be of further assistance.
Posted on Nov 09, 2008
I need to program a zenith tv to work with the 21.0 ir/uhf pro remote control
I have listed the steps below to assist with programming the remote to your TV. If you have any other questions, let me know at Kimberly.escobar@dish.com!
Look up codes for TV here: http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if it is working.
5.) If no function, repeat steps 1-4 with another code.
Feb 14, 2014 | DISH Network ES161256 21.0 IR / UHF Pro...
Can't get my 21 1 ir/uhf pro remote to work with dish network dvr 625
If you are attempting to program it to tv-2 on a 625 receiver it has to be set to a odd number for example number 7 instead of 2 or 6.
The reason for this is that the 625 receiver only supports band A frequencies for UHF and on a 21.x remote odd numbers are A band and even numbers are B band.
Sep 25, 2013 | DISH Network DVR-625 DTV Receiver /...
Auto program dish remote 21.0 IR/UHF Pro to Epic Sound Receiver
DD Cox,
I can definitely provide more information. Without knowing the model of the sound system, I am unable to provide specific codes. Below I will include a link to lookup codes, as well as the steps to address the remote.
Link: http://www.mydish.com/support/apps/remotecodes.aspx
Addressing Remote to DVD:
1.) Press and hold the clear AUX button until all mode lights light up.
2.) Release and AUX light will be blinking.
3.) Press 2 and enter the code. (Example: If the code is 639, enter 2639)
4.) Press pound (#)
5.) Try functions (Power, Volume, etc..) and see if it is working.
6.) If no function, repeat steps 1-4 with another code.
Let me know if you have any other questions!
Tommy Faust
DISH Social Media Representative
Jan 22, 2013 | DISH Network IR Remote Control
Sanyo TV Code for Dish remote 21.0 IR/UHF PRO only operates TV Power and Volume Functions.
Hello Witt Thomas,
I can understand the concern and wanting the remote to work the TV Menus. It is possible with our remotes, however it depends on the TV itself. I've seen instances where there are 2 TV's in one house, and 1 will do it, while the other won't.
If you have tried all of the remote codes, and none work, the only other options we have available are to try a powr scan, or teach the remote. This link http://www.mydish.com/support/teach-learning-remote-20-21 can provide the steps on how to teach that model of remote control!
Let me know if you have any other questions.
Tommy Faust
Jan 16, 2013 | DISH Network ES161256 21.0 IR / UHF Pro...
I need a code for a Prima Q328 Television
It may not be possible as that remote has a limited number of codes and even if it programs may only do a few things.
Try all the possible codes and look to see if that remote has a search feature which would allow you to try each and every code it has.
Nov 07, 2012 | Televison & Video
My old Bell receiver 's remote was an IR Remote. How do I program the new UHF PRO Bell remote?
mikecrans175
I have provided the instructions on how to program your remote to your TV and addressing the remote to your receiver below. I hope this helps.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and Hold the TV Power button for three seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press OK. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote:
  1. Go to System Info screen.
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
Mar 14, 2011 | DISH Network IR Remote Control
HOW CAN i RESET SAT CODE FOR DIH REMOTE CONTROL FOR DIFFERENT DISH BOX
nmg55
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
http://www.dishnetwork.com/SupportSection/remote-setup
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
Remote lights up as if it is going to work however it won't do anything batteries are new, so that is not an issue almost seems like it needs to be re programmed or something my 2 year old could have...
Without knowing the exact issue I can only provide general information. Since it seems like it may be a satellite address problem, I can definitely help with readdressing the remote.
To program remote to Receiver:
1. Access System Information from main receiver.
2. Note the number on the bottom by Primary Remote Address/Secondary Remote Address.
3. Hold SAT until all lights turn on on top of the remote.
4. Enter a number between 1-15 and press #.
5. Press record 3 times after it finishes blinking and the number by remote address should change.
Tommy Faust
DISH Network
Aug 31, 2010 | DISH Network IR Remote Control
IR remote-Bizare Problem
Okay I am a bit confused as to the exact problem you are having but I will give you multiple avenues to resolve thios issue.
Assuming that the issue exists with TV1's remote:
Some IR remotes experience interference with other peripherals at times. The easiest way to resolve this is to get an 8.0 remote that is IR/UHF capable.Using the front panel buttons or the old remote place the receiver into UHF Pro mode by pressing menu-6-1-6 . You should be on UHF Pro setup: move the highlight to the left and go to the enable selection, press select and move the highlight back to the right to done.exit out of all screens. Then press the menu button twice to get to the system info screen.Here we will be canging the remote address of the new 8.o remote to the number for the primary remote address. This number is near the bottom of the screen. On the 8.0 press the small SAT button in the upper left hand of the remote and hold until all light on the top light up, enter the number on the screen for the primary remote using the keypad on the 8.0, press the pound sign, the SATbutton should flashh three times, then press the record button. Now you should be able to use the new remote normally. You will need to program the remote to the TV if you were able to control volume and turn TV on and off before. Since this is a different model remote it may or may not be compatible with the TV. If you need assistance with programming the remote to the TV itself just post another request for assistance and one of Fix Ya's Expert will hook you up. You can also find the solution in the archives of previous solutions as that issue is commonly addressed in this forum.
If the issue lies with the TV2 remote I would suggest moving the antenna off the back of the receiver into the room TV 2 is located. This can be accomplished by following the following diagram. If you still need assistance please let me know. I hope this solves your issue.
Oct 03, 2008 | DISH Network IR Remote Control
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
DISH Network IR Remote Control Logo
177 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
