Question about JVC GR-D870 Mini DV Camcorder
Sd card is there a limit to the card capacity for use on this camcorder. I would like to use at leasr 8gb, if not 16 or 32.
    Problem Solver:
  • 14 Answers
Hi!
I'm happy to say that your camcorder is capable of recording to SD cards with capacities greater than 2GB, as it is SDHC compliant.
However, I must ask why the SD card capacity would be of interest in a camcorder like this, as it records its video to MiniDV tape, and its photo function is limited to low-res stills.
Hope this helps!
Posted on Nov 11, 2008
SD card format ng no card
  • 1 Insert your SanDisk 8GB memory card into a card reader connected to your computer.
  • 2 Double-click "Macintosh HD" on your desktop.
  • 3 Click on the "Applications" folder, then the "Utilities" folder.
    4 Double-click "Disk Utility". Look on the left side to locate the drive that says "SanDisk.
    5 Select the capacity of the drive on the left side of the window. The capacity will state "8GB" or "8,388,608 kilobytes." Click on the "Erase" tab to format the memory card. When you see "SanDisk" listed as the device's name, the capacity will be located above. You need to select the capacity and not the device.
    6 Select the appropriate "Volume Format." Under the "Volume Format" button, select the format you wish to use. Select "Mac OS Extended" if the SanDisk 8GB will only be used on Macs, or "MS-DOS (FAT)" if you will share the card between a Mac and PC. Select "Erase" to complete the format of your SanDisk 8GB memory card.
    Mar 07, 2012 | Panasonic AG-HVX200A Mini DV Camcorder
    Hi I inserted a new 8GB sd and the camera keeps trying to re-format. GZ-MC 200
    There are no 8GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
    Unless your manual specifically says that your camera can use an SDHC card, then it won't be able to. The maximum size of an SD card is 2GB. If you need more space, just carry a couple of cards and swap them, like people used to do when they filled up a film.
    Dec 25, 2010 | JVC Everio GZ-MC200 Camcorder
    Getting memory card error when I install an 8GB Sandisk card
    Some digital cameras can handle large memory cards as they are unable to format or manage that size of memory. Check your user manual which will tell you the maximun size allowed.
    Aug 02, 2010 | Canon PowerShot S2 IS Digital Camera
    SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
    No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
    There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
    May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
    Camera freezes up
    Use a higher quality SD card. PNY or SanDisk usually works well with flash camcorders. Also make sure it's a HCSD card ( High Capacity ).
    Apr 04, 2010 | Mitsuba DV9002 Flash Media Camcorder
    I just insert a 4G micro card and says card error. Everything else works fine for 3 years ( never put a sd card before ). Thank you in advance Miguel
    Check your mini SD card and see if it has the SDHC (high capacity) logo on it. Originally SD cards, including the mini SD, had a 2GB limit by protocol. The DC10 was introduced when this was the most advanced protocol. Since then the SDHC protocol has been introduced, but the DC10 is not compatible with SDHC. You need to get a mini SD, 2GB maximum capacity.
    Mar 16, 2010 | Canon DC10 DVD Camcorder
    I have inserted an 8gb SD card and it will not record
    If it is 8GB, it is an SDHC (high capacity) card. The protocol for SDHC is different than that for an SD card. SD card protocol handles a maximum of 2GB. This camcorder came out in 2003, well before the SDHC protocol was developed, and the camera is not compatible with it.
    Feb 05, 2010 | Canon MVX10I Mini DV Digital Camcorder
    It doesn't read 8gb sd cards on internal sd drive
    There are two types of SD cards. The first, standard type, had a capacity limit of 4GB. But quite soon the technology advanced and higher capacity Flash memory has been developed, so the standard had to be revised - and SDHC was born (HC stands for High Capacity), which includes cards having 4GB and above.
    There is an overlap, as you can see, because there are 4GB CD cards, and 4GB SDHC cards on the market.
    Now your DELL is an older machine, and it's card reader is not compatible with the new SDHC standard. And it will not be, even with a BIOS update.
    You have two options: find a 4GB SD card (they are hard to find, majority will be SDHC) and stick with this capacity, or purchase an USB SD/SDHC card reader, which is cheap, and use it to transfer files to/from your 8GB card.
    Nov 22, 2009 | Dell Latitude D430 Notebook
    I have the SD-1. It stops recording on my 8gb after only 43 min
    Try formatting the card while its in the camcorder, this might sort the problem for you, also look in the camera's menu to see if its restricted to a certain amount of used memory at once, basically return the camera to factory settings.
    I find a lot of camera's don't like certain SD cards anyway even if the camera says it supports them, Sandisc are making just about the best SD cards at the moment
    kind regards
    Dec 11, 2008 | Panasonic HDC-DX1 DVD Camcorder
    I have a JVC Everio GZ-MG21EK Camcorder can anyone tell me the maximum sd card that you can use with this camcorder
    There is no limit beyond the limits of the SD cards themselves. The JVC Everio GZ-MG21EK camera DOES NOT support SDHC cards, so you are restricted to the smaller capacities of the non-SDHC SD cards. I am successfully using a 2GB SD card in this model.
    Stewart
    Aug 03, 2008 | JVC Cameras
    JVC GR-D870 Mini DV Camcorder Logo
    134 people viewed this question
    Top JVC Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a JVC Video Camera Expert? Answer questions, earn points and help others
