Question about Honeywell Programmable Thermostat Heater
Globe 59005 fan will not shut off
  • 359 Answers
What kind of furnace.heat pump ect is it
Posted on Nov 08, 2008
How do I change the lightbulb in the HC-1131 ceiling fan... the globe will not come off and the whole shaft turns if I try to lift and turn the only part that looks like it comes off
I appologize in advance for not having absolute, 100% certainty if this will work with your particular model of fan, but it appears that most fans of that style have a threaded globe glass covering. The difficulty most people encounter, is that if the globe is even mildly warm from the fan motor running, it will be near-impossible to grip, much less to turn.
In all related cases I had read about, the solution was to allow about 12 to 24 hours of power to the fan being completely off to allow it to cool, then try turning the globe to unscrew it. Most suggest "clockwise" but I have no way of knowing if they mean clockwise from the perspective of looking up at the globe, or clockwise relative to the fixture itself.
Some also suggest that rubber gloves to improve grip or friction may also help to turn the globe.
Oct 19, 2013 | Hunter Ceiling Fan Control Switch
The glass light cover falls off when the fan is on. I have made certain that the cover was screwed in properly but the vibration of the fan loosens the cover. Any suggestions?
I would first tighten any screws that might be part of the vibration problem. They do work loose. As far as the globe goes, sounds like you might need some kind of spacer material between the glass globe and the frame it screws into. Perhaps a few pieces of small clear plastic hose. Try and wedge them between the globe and metal frame when screwing the globe back on. Make sure it is snug, but do not over tighten to the point where the globe breaks.
Aug 27, 2010 | Casablanca Fan Stealth 3211T Ceiling
Light bulb replacement in ceiling fan. Hampton Bay with a solid globe (no hole in middle) - how to remove globe?
Look for three or four small thumbscrews around the metal rim that holds the globe. Unscrew each several turns while holding the globe with your other hand underneath to keep it from dropping out. You should not have to remove the screws completely. Just loosen them all enough to remove the globe. If there are no screws then the globe may twist into the rim light a light bulb. Hold the fan housing steady and turn the globe counter-clockwise to unscrew it. If it turns but does not unscrew then there are probably screws holding it as first described. They may be flush with the rim and you may need a small screwdriver or Allen wrench to unscrew them.
Oct 16, 2009 | Dryers
Need new globes on lights
Go to lowes or home depot as both places carry replacement globes in stock. They can also special order for you. Bring in one of the old globes to be sure you get a perfect fit.
Apr 28, 2009 | Westinghouse Helix 78794 Chrome Finish...
Need to change glass globe in hampton bay fan
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Jan 23, 2009 | Hampton Bay 24002 Ceiling Fan
I can't remove the globe to replace bulb in the ceiling fan. I removed the 3 screws but I can't tilt the globe.
My fan has no screws. You simply twist and tug the globe (firmly but easily) and find that it is held on by three "tension clips" that hold the thing in place.
If you are nervous, have someone else get on the other side of the ladder and hold the fan steady while you twist/tug the globe with two hands.
I did it by myself but I would have liked another pair of hands holding the fan steady while I gently but firmly tugged at the globe.
Jan 19, 2009 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Removing the globe for put bulb in
I found on mine that the bulb is held in with 3 tenshion clips. You just have to pull the globe down slowly to gain access to the light bulb.
Sep 03, 2007 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Heating & Cooling Logo
170 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
