Question about CyberPower OfficePower 650SL UPS System
'Battery' outlet dead.
Office equipment plugged into 'battery' outlets were dead this morning and UPS would reset only briefly. All devices worked when plugged into 'surge' side or unprotected wall outlet. Clocks in area were not flashing as usual after power outage. Now, at end of day, unit resets as if no problem.
Does this indicate a problem with the batteries? Unit is approx. 8-10 years old. Can batteries be replaced/serviced or is it cheaper just to buy a new UPS? Could it be that an otherwise unnoticed outage exhausted the batteries which recharged during the day (as in...functioning normally)? Then, why no flashing clocks? Thanks for your input. --Lynn--
  • 26 Answers
These CPS650SL's are at that age where they need a new battery. You can find these at: http://www.batteryinternational.com/cyber-power-cps650sl-ups-battery-ups-batteries-f1.html
It's usually less expensive to get a new battery instead of replacing the whole unit. It only takes a moment and keeps it out of the garbage.
Posted on Oct 22, 2009
    Problem Solver:
  • 10 Answers
It would appear that you need to replace the battery on this unit.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (BP7.5-12 battery).
You could compare the cost of a new battery to the cost of a new unit.
We have a 3 year warranty on all our battery back up units. If you have any questions, you could contact us here at CyberPower Systems Technical Support at 877-297-6937, M-F 8-5 Central, or email us at tech@cyberpowersystems.com.
Posted on Nov 18, 2008
    Scholar:
  • 124 Answers
Hi There, Its definately the battery. The batteries can be replaced.
Posted on Nov 05, 2008
Tripp-lite Internet Office UPI 350U series has red light flashing by "Overload/Check Battery." What should I do. Thanks
The power rating of the equipment that is plugged into the battery-supported outlets must not exceed the UPS capacity. To make sure it doesn't, add together the power rating for each piece of equipment and compare the total requirements to the capacity of the unit, which is listed a) on the bottom of the UPS, or b) on the Specification tab on Tripp Lite's product page. If the total power draw of the connected equipment exceeds the capacity of the UPS, the load MUST be reduced for the UPS to perform properly.
If this is NOT the case, disconnect the unit from the wall outlet and check the battery voltage- it may be at its end-of-life cycle. It may not be holding the charge or not take a charge anymore.
Feb 12, 2017 | Internet Computers & Internet
I have a Tripp Lite G1010USB uninterruptible power supply that only powers the surge surge-suppressor outlets and not the battery-backup outlets. Unless the UPS is unplugged from the wall, and then i
You know they have a TWO YEAR Warranty ?
Sounds to me that it is faulty (one of the relays or switches is not providing 'through' power to the supposed 'backup' socket when the AC power is on.).
Have you followed the manual ?
available here http://www.tripplite.com/support/model/mid/G1010USB
Have you done a 'self test' ?
'To Run a Self-Test: With your UPS plugged in and turned on, press and hold the MUTE/TEST button for two seconds. Continue holding the button until the alarm beeps several times and the UPS performs a self-test. See "Results of a Self-Test" below.
Note: You can leave connected equipment on during a self-test.' see manual
If the LCD does not give you the answer then it is faulty. Seems like something went faulty on restarting your UPS in the morning.
Seems like plenty of help available from this companys' website.
Sep 13, 2014 | Tripp Lite Ups Battery Backup G1010usb
The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    Not Working During Power Outage
    Bad battery in the UPS. To test unplug all equipment. Check outgoing power with voltage meter. Should read around 115vAC. Then unplug from the wall outlet. Check voltage again. If no voltage is present its a bad battery.
    Sep 04, 2013 | CyberPower Computers & Internet
    Three out of the five plugs do not work have stopped working.
    The APC UPS will power the non-battery (label something like surge only) with the power button turned off. If the outlets that are not powering up are labeled Battery/Surge, you need to turn on the UPS. There should be a button you depress to turn the system on.
    Also if this is a new UPS, you will need to hook up the battery for this to work. Open the bottom of the unit and you will find the battery and plugs.
    Jul 20, 2011 | APC Back-UPS Office 500VA (BF500) UPS...
    I have a computer with ups .in my area power flutucation is there .i connected all the devices to the ups .when power flutucation happens . it restarting my systems some times my modem got off and on for...
    If it is only a very short fluctuation, your system should not shut down if the UPS is working properly. Some things to check...
    1. Make sure you have your computer components plugged into the outlets marked "Battery Backup" not on the outlets marked "Surge Protection". (The words may be slightly different on different models) Only things plugged into the "Battery Backup" outlets will keep running when the power fluctuates. The other outlets do not get any battery backup.
    2. If the unit has been drained by a lot of power drops recently, it may not have enough power stored up to keep your whole system running the next time the power drops, even briefly. Especially if it is an older unit, as the battery itself does wear out over time.
    3. As for the "modem" clicking on and off... are you sure it's the modem clicking? Most UPS's make a noticeable sound when they kick into battery mode and back again. It can sound like a modem click. Just an idea.
    May 05, 2011 | Computers & Internet
    V guard ups beep sound
    UPS will beep usually for one of three reasons:
    1. You have attached too many devices and it cannot support the load. If you just added a device unplug it and see if the beeping stops.
    2. The battery pack is dead. Most manufacurers of UPS equipment list the life of battery packs as 3 years.
    3. The outlet is dead and the UPS is running on batteries.Confirm that the circuit that the UPS is attached to is live/
    Apr 29, 2011 | Computers & Internet
    Hi there, I'm wondering if I can use my "Trip Lite Office UPS500" as a surge protector only (the left 3 outlets), I don't need the battery back-up? Is it going to work properly without the...
    Yes it will work just fine make sure that the outlets you are plugging into the 3 are surge protected. Thanks for using FixYa! Most battery backups and backup modules are surge protected on-board. John
    Mar 19, 2011 | IBM Tripp Lite Internet Office 500...
    Only one side of the outlets work...
    From the User Manual:
    “OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
    indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
    CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
    The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
    If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
    If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
    Hope this helps!
    Jul 25, 2010 | Tripp Lite Internet Office INTERNET550U...
    UPS does not supply power to equipment after power trip
    Some of the less expensive UPS devices have two sets of plugs.  One set provides backup power and the other set only provides surge protection.  You need to ensure that the devices for which you want backup power are plugged into the correct outlets on the UPS.
    Apr 20, 2009 | Computers & Internet
    CyberPower OfficePower 650SL UPS System Logo
    451 people viewed this question
    Top CyberPower Computers & Internet Experts
    George Nalley
    Level 1 Expert
    Paul Bade
    Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
