Question about Motorola Mobility RAZR V3
Razor problem It seems to be locked. All that will come is the volume scale or the home screen. None of the keys will do anything.
I have the exact same problem. have tried removing battery blah blah blah, a flash reset, i even tried to use my computer to log into the phone remove some of the stuff in memory as that may be part of the problem. It froze up when i was call forwarded and got a text message. the memory was getting low in messages.
I just want my numbers back (my last synch was 2 months ago, let this be a lesson to synch allot), but cannot access bluetooth or change the data setting on the usb from storage device.
Posted on Nov 06, 2008
My zte model z813 is locked. I forgot unlock pattern and it doesnt give me any recovery options
You can try hard resting your phone
1. Power off your device
2. Hold the recovery buttons
Volume Up + Home + Power
Volume Down + Power
Home + Power
If none of the above work, do a web search for your phone’s model plus “recovery mode”.
3. Use volume keys to navigate and home button to select
4. Select factory reset from the menu and then select yes
5. Everything will be set to factory settings
Jul 20, 2015 | ZTE Cell Phones
Unlock screen on lgl34c
when ever you forget the
pattern lock and can't access the
phone, below is a step by step guide
on how to reset it.
1. Switch off the phone by pressing and holding the power button.
2. Now, press and hold the power button and the volume down button
(Power-on + Volume down button)
together until the phone has power on.
3. On the next screen that shows up, you should see about four ( 4 ) options, scroll down to "Factory Reset" or "Clear Flash" and select it. (Use the " Home button" or Switch button to select).
4. On confirmation, the factory reset process begins immediately. And,
when the process completes, the
phone boots up without the pattern security lock.
TIPS: For navigation purpose to explore
other options on the screen, you can
use the (Volume Down key) to
navigate down, the (Volume Up Key)
to navigate up and the (Home Key)
to select the option you want, you can use (Switch button) to select in some android phones
Nov 01, 2014 | Cell Phones
My China Mobile Vell-com Model V222 Has been Lock When I switch On first screen was open lock code input this mobile full screen touch only 3 key are there 1 call and 2 menu 3 switch off/onWhat Can I
try power home and volume down, all at the same time. when turn's on leave fingers on power and volume then count to 10 ( seconds) and take your fingers off power and volume, should have a menu come up and use the volume button to move down to factory reset and press home button. now this will wipe all you have on the phone but as you dont know what the password is this is your only choice. hope this helps.
Mar 24, 2014 | Cell Phones
Reset phone to factory setting.
kindly have an software updation in your mobile
Jul 23, 2009 | Cell Phones
I cant seem to turn up the volume on my razor...i cant hear the..
the volume control key thi means the side key have problem u need to repair it
Nov 19, 2008 | Motorola Mobility RAZR V3
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Slowness of keys when using my razor
First thing is first: try restarting your phone. Turn it all the way off, remove the battery for about 20 seconds, then turn it back on.
If that doesn't help, then Motorola provides a factory reset function that you can try. This will delete all of your contacts, so make sure you have a way to pull them off. (If you have a Mac, and your phone has Bluetooth, try iSync.) Once you've done that, follow these steps:
  1. With the phone on and at the home screen, press the Main Menu softkey
  2. Choose Settings
  3. Choose Initial Setup
  4. Choose Master Reset (near the bottom)
  5. If you haven't changed your password yet, it will be 1234
And away you go.
Dec 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
