Question about Teac AG-360 2 Channels Receiver
No sound! TEAC receiver no longer produces any sound. Unit turns on but that is it. It appears there is no power going to the Speaker Hookups on the back. Short circuit? I looked for a fuse of sorts inside but could not find anything. There is no spark coming to the speaker wires so I assume there is some short circuit that took place. Any thoughts?? thanks.. HManTx
  • Teac Master
  • 4,390 Answers
Check the speakers, check the wires, check the set connections (antenna) and if all is good the fault must be inside the set, in that case it would be wise to go no further and let the repair shop handle it.
Posted on Sep 10, 2017
4 Suggested Answers
jack_daniels
  • 304 Answers
SOURCE: I have a TEAC AG-500
hi there.
try checking and correcting the connections. see and fix any possible loose connections or connectors on the receiver, also check the wire quality
Posted on Dec 06, 2008
SOURCE: I have a teac AG
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Posted on Apr 16, 2009
SOURCE: Teac AG-V8525 Stopped producing sound. Has legend says "protect"
hit reset button back of receiver
Posted on Dec 02, 2009
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Jun 28, 2015 | Teac Audio Players & Recorders
Why dont i have sound
First , make sure the speaker switch is ON
Second , make sure no TAPE MONITOR function is on.
3rd, Make sure ( if there is a Mute switch) , turn that off.
If still nothing, try headphones and see if something comes through
Feb 27, 2015 | Teac AG-V8060 Receiver
My teac ag-v1200 audio/visual receiver isn't
check speaker connections - unit might be going into protection
Sep 03, 2014 | Audio Players & Recorders
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
I have a Sony STR-DE845 5.1 Channels Receiver and it has been functioning flawlessly for years. Recently though, it has started producing a loud "pop" sound within a minute after turning it on....
You probably have a discrete component failing inside it.
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Dec 22, 2010 | Sony STR-DE845 Receiver
My Teac AG-10D switches itself off after a couple of seconds of me turning it on. Is this a thermal protect? if so, how can i fix it? if not, any ideas what the problem is?
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Jun 11, 2010 | Teac AG-10D Receiver
Lost manual..do not know what is the difference sound surround
Hi use this link to download the manual .
manualnguide.com/manual/teac-ag-v8060-receiver.../page/2/.
Take care.
May 18, 2010 | Teac AG-V8060 Receiver
No sound listening to music and audio stopped
Tape monitor is it on? Muting? How old is this unit? Does speaker relay click on secoinds after unit powers on? If relay does not click probably output problem. Try disconnecting speaker wires to see if relay will click. If it does click the suspect bad wire or speaker if not bad amp. The first step to diag is to diconnect everything and simplify the citems needed to get sound. 1 Known good signal source and cable, Minimum affects, check speaker switch, Known good wire and 1 speaker to front l or r terminal. iIf still know sound seek serv.
Aug 29, 2009 | Teac AG-V8060 Receiver
SA HE200 ~ Overload at power up
First of, be sure volume is turned all the way down before or as you are powering it it.
Second if that does not work disconnect all speaker, and input/outputs.  Power the device on and see if it says overload.
If it does skip the rest of these steps, your capacitors are bad or the power supply is no longer functioning correctly.
If it doesnt, start with testing each speaker at power up.  Match the speaker to the output it goes on, power the device see if it says it.
If it does on any speaker test it is a speaker issue or a terminal issue.  To test for terminal or speaker issue plug a different/ known to work speaker in that same terminal, if it doesnt say overload it is a speaker issue, if it does say overload it is a terminal issue.
Once you have made sure all speakers and terminals work correctly start plugging input and outputs in and test individually.
Jan 09, 2009 | Panasonic SA-HE200 Receiver
Teac AG-360 2 Channels Receiver Logo
51 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
