Question about Garmin Foretrex 201 GPS Receiver
Changing a Foretrax201 Battery
I believe I have a faulty chargeable battery within my unit. It needs frequent recharging and will accept further charge within an hour of completing a charge. I have tried asking Garmin Europe for help but am not getting any sense from them. [They advised me to re-boot it!. Thanks for nothing. I have 100 nautical waypoints in there.] Is it possible to change this battery 'at home' What is the number or identification of the battery? Do the two halves of the unit separate without doing damage or is there a cunning trick.
Hi. Did you solve this problem? I have the same issue. Cheers rogerlaidlow@hotmail.com
Posted on Jun 22, 2011
HAVE LOADED CD, PRESS PLAY BUT GET ONLY A WHIRRING NOISE THEN Er WITH BATTERY ICON ON DISPLAY BUTTON - HOW DO I GET THE CD TO PLAY?
Normally a battery icon on a display indicates that the battery power is too low to operate the device. If the device uses disposable batteries, it's time to replace them with fresh ones. If it uses rechargeable batteries, recharge them. If recharging the batteries fails to work, they may have reached their useful lifetime and need to be replaced as well. If the unit has a internal battery that is chargeable, and charging fails to work, you may need to have the unit serviced to replace the internal battery(ies) or just get a new unit, depending on the cost-effectiveness of repairs.
May 25, 2016 | GPX PC101B Portable Compact CD Player
Can u put rechargeable batteries into the Lanson smoke alarm
I am not familiar with the brand, but a quick search of the internet makes it look as though this is a 240VAC device. Since I'm not familiar, I thought I might offer some general advice re: rechargeable batteries. Most units will probably accept rechargeable batteries, but they will not provide a charging current to the battery, so you would probably find yourself changing the batteries more often, not less, because typical rechargeables are not charge to as high a voltage as non-rechargeables. I would suggest using lithium batteries because they are more likely to last the life of the unit (10 years by code in the US) when only being used as a backup; certainly you could expect 5 year battery life unless you go without power on a regular basis for extended periods...hope that answers your question. When in doubt, always check with the manufacturer.
Sep 23, 2015 | Home
How do you recharge the battery casio m850
if it doesn't have a jack for a charger or a charger stand to sit it in then it will not be re-chargeable as such
you will have to remove the battery and check if it is an alkaline battery ( not re-chargeable ) or a rechargeable battery in which case you will need a battery charger for that type of battery
If that is the case get spares and have a fully charged one on hand to just swap over while the other is charging
Sep 13, 2015 | Casio Cameras
I have a wirless xbox 360 headset and it was working about 4 days ago and I had it on charge when it died when I went to charge it wouldn't charge or turn on and I have had it to long to take back to...
so you are saying that you have a chargeable microsoft headset and the last time you tired to charge it. it would not work... it sounds like your rechargeable battery is dead and you might need a new one. also try you head set on a friends unit and see if it works, at the same time take their chargeable battery and place it in your headset and see if it works that will tell you if it is your headset or the battery..
game tag DeepReserve
May 19, 2011 | Microsoft Wireless Headset for Xbox 360
My Sigma SD9 rapidly drains battery power; and I don't mean over a short period of time, but over a few minutes. Regardless of new or fresh rechargeable batteries, the drainage is frustratingly...
For any camera, you need high power re-chargeable batteries - 2300 mAh or 2500 mAh. Try with a set of those. I have heard Eneloop suggested, but have no experience myself.
May 21, 2017 | Sigma SD9 Digital Camera
Can you use any rechargeable batterys?
mcdevito75 here, I would figure yes, any re-chargeable batteries, but check with your local Radio Shack or Staples or refer to your manual, Generally you just have to watch the size of the re-chargeable batteries used, and of course a cheaper battery may not lasty as long as the manufacturers suggested battery type or brand if any.
Jul 07, 2010 | Kodak EasyShare Printer Dock Series 3
I had the same problem my 5800 is not switching on
You might have on of these problems
1. Faulty charger
2. faulty battery
3. Reload the soft ware but very rare chances the phone behaves like this due to s/w issue
4. try & format the memory card
Sep 07, 2009 | Nokia 5800 XpressMusic Smartphone
My back up battery is in critical stage..how can i fix it? unit is eten g500
backup battery might be a non chargeable lithium battery inside th epda somehwere in the back or inside the housing try changing it it is not chargeable
Feb 19, 2009 | Eten G500 Smartphone
1999 Volvo S80 will not hold a charge
Tricky ... Was the alternator replaced with a 2nd hand one or a new one?
A defective alternator can allow the battery to discharge within a few minutes (the diodes in the rear of the alternator can burn out and cause the problem. The diode pack can be replaced). When this happens recharging the battery only replaces the power in the battery - which drains straight back to earth via the alternator, flattening the battery again - often within a couple of minutes or less.
Does the battery lose its charge when the car is standing or just when the engine is fired up?
If the battery loses its charge overnight, try disconnecting the wiring from the rear of the alternator (also look at the electrical connector that fits into the back of the alternator - look for melting/burning marks which suggest something may be amiss inside the alternator).
Let the car stand overnight with the alternator wires disconnected. Will it start up ok and drive (with the alternator wires still disconnected) the next morning?
You could also try just disconnecting the alternator wires, firing up the car and then driving it -
If the car drives ok without dying out and gets further down the street than it usually does, then it probably is the alternator at fault. The car should drive until the battery drains and has insufficient power to trigger the ignition. You certainly would get further down the street with a charged battery and disconnected alternator than you currently do.
It does sound as though you've had an alternator fault to begin with. If it has been replaced with a 2nd hand unit that unit may also be faulty. Rather than replace parts in desperation, visit an auto electrician's - within a few minutes they will be able to test the battery/alternator output and also identify where the lost current is going. It will be cheaper in the long run to have an auto electrician look at the charging system. It only takes a few minutes.
Sep 14, 2008 | 1999 Volvo S80
Battery exhausted
I found this happening until I decided to change to re chargeable batteries and havnt had this problem since.
Aug 19, 2007 | Nikon Coolpix 3200 Digital Camera
Garmin Foretrex 201 GPS Receiver Logo
177 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
