Question about HP Office Equipment & Supplies
On startup I get this: cannot find "c:\hp\tmp\src\CDB\setup\fax\"
  • jvpritc Mar 13, 2009
    c:\hp\tmp\src\cdb\setup\fax
    Problem Solver:
  • 15 Answers
Try reinstall the driver, it might fix your problem
Posted on Nov 05, 2008
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Tip
Access software setup shipped with HP PC after Retail OS Installation
Scenario: You have installed a Retail Operating System but have left the recovery partition (usually D drive) on your HP Desktop PC and you want to access the original softwares shipped with the PC.
Tip:
1. Click start, run. Clear contents of run box.
2. In run box, type "D:\hp\apps" without quotes and hit ok.
3. This will open a folder that would show couple of folders. These are the applications shipped with your PC. You can identify the software you need. In that folder, open SRC folder. You will find setup for the application here. Install the application from here.
on Jan 18, 2010 | Computers & Internet
I downloaded an .iso file and when I clixk on it I get need c:\hp\tmp\src\sc_copy_206\copy.msi
did you mount the ISO to your hard drive. and if u need something from the .msi file, just change .msi to .txt please vote for me helping you!
May 10, 2011 | Sonic RecordNow! Deluxe 7.3
I have Vonage phone line. I cannot fax to anyone on my HP 4215 officejet. My officjet is connected to the wall jack and set to "slow" settings as advised in one of the HP solution forum. that did...
Press the setup button on teh front panel and go to fax set up
Under fax setup look for
ECM - Error correction mode
By default its ON turn it off and try to send the fax
But let me thing clear the telephone line which you have has definitely some disturbence
Apr 16, 2011 | HP OfficeJet 4215 All-In-One InkJet...
C:/hp/tmp/src/ and MyDVD.MSI keep popping up on my system. How can i get this to stop?
It seems that particular application(Sonic) files might have got corrupted or not installed properly.
So you can try these steps:
1. Start -> Run -> Type %temp% -> click OK -> delete all the files( if you are not able to delete any files please skip those files)
2. Start -> Start -> Run -> Type temp -> click OK -> delete all the files ( if you are not able to delete any files please skip those files)
2.Click on start -> Run -> msconfig -> click on services tab -> on the same window at the left bottom you could see "hide all microsoft" option, put a check mark for hide all microsoft option and then disable all the services -> go to the startup tab -> right bottom you could see disable all -> click on disable all -> click on apply -> ok -> click on restart on the popup.
/quote
Make sure you put a check mark for "Hide all Microsoft" in the service tab before you disable all the services.
quote/
Dec 29, 2010 | Sonic Computers & Internet
On my desktop this keeps popping up on the screen and I am unable to eliminate it. Need instructive help. c:\hp\tmp\src\CDB\setup\fax\
You may actually have a spyware bug. Download and install the free verson of Malwarebytes and run the Quick Scan and it may just get rid of it.
Aug 25, 2010 | HP Office Equipment & Supplies
Already have a lexmark x4270. can't recieve a fax?
Chances are you'll find your problem under 'fax settings' or a similarly titled option on the display. If you have it hooked up a computer as well you're in luck, most come with software that has an option labeled 'fax setup wizard' or something similar. Just follow the steps in that or call customer support at the following link to be walked through every step.
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:439:0:0
Lexmark Customer Support: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-332-4120cb_transparent_r.gif
Jun 26, 2009 | Office Equipment & Supplies
Sonic mamanger is trying to install using a network source that is unavailable. Told to use source: c:\hp\tmp\src\UPDATEMANAGER_MSI\
i have this probleme each time i reboot my computer, (From Sonic), and i don't know qhat to do with this, thank's to help me...
Jul 26, 2008 | Computers & Internet
232 people viewed this question
Ben Johnson
