Question about Whirlpool GBD307PDS Electric Double Oven
Temperature gauge won't elevate past 350 and timer is messed up
The timer is acting nuts and the temperature setting only goes up to 350 all of a sudden! When I try to change the temp to go higher, it goes lower in 5 degree increments. Should I try to reclean again and see if it resets?
    Scholar:
  • 62 Answers
Somehow you have entered into the oven calibration mode at least that is what it sounds like. Normally if your press the clear button or reset it should come out of that mode you also could try to turn your breaker off for 15-30 min and then turn it back on. I dont think I would recommend cleaning cycle if the oven control is acting up.
Posted on Nov 05, 2008
  • Stuart Moon
    Stuart Moon Nov 05, 2013
    This does nto work
My oven wont shut off and gets very hot way past set temp what up with this.
Good Morning Friend,
I understand that your Frigidaire electric oven, model# es 200/300, will not shut off. I also see that it gets very hot, way past the set temperature. First, make sure you have not put it into the self-cleaning cycle. If it is not in the self-cleaning cycle, I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I'm so tired of this! Everything I bake is overcooked/burnt on outside and not cooked on inside. IE..banana bread, cookies, muffins. I have two gauges that are telling me that the temperature is correct. I...
The cheapest would be to go buy an oven thermometer. A couple of dollars. Set oven at 350. Put thermometer on the oven rack. Put in a cake pan, etc with water in it. Let be 15-30 minutes. Then read the thermometer. You can tell by how much it is off.
Really, what might have to be replaced is the thermostat. That constantly trying to kick in would be the ticking noise.
Mar 03, 2014 | Whirlpool Ovens
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Turn oven on and it won't heat. set it at 350, will only fo to 185
Get the temperature control unit checked up. It is not functioning correctly.
Aug 22, 2011 | Frigidaire Ovens
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and Fixyourboard.com can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
info@fixyourboard.com
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
Oven will not heatup
  1. Make sure the controls are set properly: that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
  2. If nothing else on the Range, Oven or Cooktop is working then Check the fuse
  3. Test the oven elements
  4. Test the oven thermostat
  5. Test the oven selector switch.
or
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
Jan 18, 2010 | Ovens
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Jan 29, 2009 | Whirlpool RBS245PDS Electric Single Oven
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Oven temperature
you guys should check your tempurature sensor. Our oven has been acting weird like saying it has heated up to 400 degrees in like 1 minute haha. Well after a few months of this happening on occasion we get an F2 error flashing..
did some research on it and apparently for GE ovens this is a temp sensor gone bad. Im looking to buy one now which is how i found this post, i just thought id tell you all what i found out and maybe you should look into that as well.
Oct 30, 2007 | Viking VGS0166 Stainless Steel Gas Single...
Whirlpool GBD307PDS Electric Double Oven Logo
129 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De GO PATS
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
