Question about Symbol VRC 7946 (VRC7946-00HWWQUS) (vrc794600hwwqus)
Sticking Keypad letters
I have sticking keys on my vrc and they are very intermittent, one day they dont and one day the wont stop.
    Scholar:
  • 47 Answers
Start off trying to blow it out with compressed air, and then the question is, "How electrically savvy are you?" You could open it up and clean the contacts with some technical grade isopropyl alcohol (NOT rubbing alcohol) and a soft lint-free cloth.
Posted on Sep 14, 2007
Transmission wont downshift when it comes to a stop. It only happens intermittent
STRONGLY recommend that you add SEA FOAM (TRANSMISSION) to your Transmission and then after driving for a few days, have your Transmission serviced and see if the sticking goes away. There is a Build Up of junk in the passages inside your transmission and into your Solenoids....
Apr 06, 2013 | 1995 Jeep Grand Cherokee
Key stuck on (keys are loose, not actually stuck) but works ok with external keyboard
There's more than likely something sticky in your keyboard, someone probably spilled liquid in there and now it's sticking as though your pressing even though you aren't.
A new keyboard will fix this problem.
Jul 18, 2012 | Computers & Internet
Dora 204 SP Olivetti Typewriter I have an intermittent sticking returns key Causes paper to run on. Can I do anything about it, or can you tell me of a Service Centre in Hampshire n UK.
hello
take Q-tip cotton , apply small portion on hammer letter keys and carriage -- moving parts only
dip and smear into vasaline, wipe off excess. apply to the keys sticking or to carriage return key . this is amechanical sticking , so apply to where the part (carriage or moving part) applies. Also, take a plain paper , keep tapping the key and then return key carriage , until sticking stops and until the vasaline dissipates . repeat the typing for about 1-2 mintes until excess vasaline is no longer present on paper after typing.
repeat this process anytime the keys stick
hpe this helps
Nov 14, 2010 | Office Equipment & Supplies
My Acer One has lost the 'X' key. Can keys be purchased or would this fall under warrantee (purchased last January? Are keys easy to replace?
If the X key is just the X cover then yes, you can purchase them at a computer store, however they have have to custom order for you, when you get it just snap it in, it's easy. If you have lost the groove or if the elastic is broken under the key you would need a new keypad. You can find this out if you take a key off of another letter and try snapping it in the X spot. If they key falls off then you turn it upside down, then that means it is not sticking and you cannot fix it without an entire new keypad. Hope this helps. Cheers.
Dec 30, 2009 | Acer Aspire One PC Notebook
My GE microwave started running by it's self. It first said 3.5oz and would not stop until door was opened. then it started beeping and wouldn't stop until door was opened. we unplug hoping it would reset...
It sounds as if you key pad is sticking. PF means that there is an input power problem but could be caused by the sticking keypad.. As far as the unit starting bu itself, the only thing that can cause that is the keypad.. Try running your fingers flat across the panel several times both vertically and horizontally and see if the pad malfunction clears. It will probably repeat in the future but you could get lucky and have a one time instance. The keypad itself is just a bit over $75.00 if it has failed. Good luck.
Dec 10, 2009 | GE JVM1440 Microwave Oven
The keypad sticks on my Motorola W385 cell phone
the A sticks on my moto hate having to get a new phone
Sep 30, 2009 | Motorola Mobility W385 Cellular Phone
Key button got pluged off
You probably broke a little tab that connects the letter to the actual button.
Just get some of that thick (foam) double sided tape. regular double sided tape wont work.
good luck
May 20, 2009 | Acer NSK8458AN Keyboard
B130 LETTERS STICKING SOMME WILL NOT SHOW UP TRIED SPRAYING
Letter sticking means something got spilled into the laptop, luckily its just the keyboard acting up, best thing to do in this case is replace the keyboard cause even if you clean the stick keys others could go bad down the line.
May 14, 2009 | Dell Inspiron B130 Notebook
Starter wont stop spinning
The starter relay may be sticking on start. Get someone to start truck and when problem starts hit relay lightly wih hammer. A cheap voltmeter will tell you if relay is sticking or still energised from ingnition switch after key release from start position.
May 04, 2009 | 2001 Ford Expedition
KEYPAD STICKING AND STOPS WORKING
Obtain a replacment keypad and replace it. The non serviceable contacts inside of the key pad or going bad.
Dec 31, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
Symbol VRC 7946 (VRC7946-00HWWQUS) (vrc794600hwwqus) Logo
103 people viewed this question
Top Symbol Computers & Internet Experts
 Brian
Brian
George Etukudo
George Etukudo
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
