Question about Nixon Delta NIX0001 Wrist Watch
Nixon delta This watch keeps stopping and I cant change anything without resetting
5 Suggested Answers
  • 2334 Answers
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Posted on Feb 10, 2009
  • 2334 Answers
SOURCE: battery change for Nixon Kink watch
You have to open your watch caseback. Undo the battery holding contact, get the battery out and memorise the writings on the battery. Buy exactly the same one and replace it in the backwards way you took it out.
Posted on Feb 28, 2009
  • 2334 Answers
SOURCE: need to switch bands and cant remove pins
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 28, 2009
  • 2334 Answers
SOURCE: get the user manual for nixon banks watch
Use this link and browse through my TIPS AND TRICKS: You will find manual for your watch here.
Posted on Apr 25, 2010
SOURCE: nixon 51-30 screw that hold the band onto the case
The same thing happened to mine and all I need is the screw..those assholes should fix the problem at Nixon and atleast send us the screw if we're willin to pay for it..
This will b the last Nixon I buy..
Posted on Aug 01, 2011
0 characters
1 Points
My Nixon Rubber Re-run watch's light button does not work, but instead, resets the entire watch. Would anyone be able to help me with this?
Probably dirt and/or dirty contacts. If you can open the watch up, try cleaning with an electrical cleaner solvent. (First make sure you can do it without running fluid into the front face of the watch. Perhaps holding the watch face up and spray upwards from beneath it).
Jan 01, 2015 | Nixon RUBBER RE-RUN A169 White/Black
Hi - i need a manual for a nixon The Housing - or how dot I set the time and tide on it
Hi here is the link for all of the nixon manuals
Kind regards
Sep 12, 2014 | Nixon The Housing Watch
Wont stop beeping
OMG me too!! Just got the watch today and none of the features to stop/start or reset respond!!! It's crazy...
Feb 06, 2014 | Nixon The Genie Watch
User manual for nixon delta pu watch
Here you go,
Apr 07, 2012 | Nixon Delta II stainless steel PU Digital...
I havent used my watch for about 3 months and now i cant get the stp watch to work on it? it has been srored in a drawer and is in new condition?
if the watch is still keeping time but the stopwatch wont work then its probable that the watch has two modules inside,one for the normal hour and min hand and a module to run the stop watch.The cell on the stopwatch module will be flat and needs to be changed.Your watch is waterproof so take care who opens it and ask for it tom be re sealed or it wont be waterproof.
If you cant find a local watchmaker see where there is a postal repair service within a day or so.
Aug 18, 2010 | Nixon 51 30 Watch
I change the battery of my nixon superhero TI/PU and now i cant see the digital numbers what can i do??
you need to restart digital part of the watch. Open it ( the screws part) and there you will find 2 reset contacts. You need toen close the contacts with the big battery in it. Then it should start working. This acion have helped me few hours ago.
Jun 19, 2010 | Nixon Super Hero Ss Ii Black Watch
Change tide location
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIXON watch manuals.Rate me, please..
Mar 29, 2010 | Nixon Lodown Tide watch
Nixon watch warranty info?
I have the exact same watch and problem. The local Nixon dealer told me to take it to them and they'd send it away to be fixed. Good luck!
Feb 26, 2008 | Watches
Nixon Delta NIX0001 Wrist Watch Logo
Top Nixon Watches Experts
Arturs Kalnins
Arturs Kalnins
Are you a Nixon Watch Expert? Answer questions, earn points and help others
