Question about E-Machines eMachines Desktop PC
My machine runs real slow
I have a w3611 emachine desktop that runs real slow even after t removed 17 program that took up too much room, can you help
    Problem Solver:
  • 12 Answers
Its not the room on your system that slows down the computer it is the running programs in the back ground that you dont know are running, there are many programs that will run during the normal operations of your system you weill be able to view the programs from the system comfiguration utility built in to Windows,
Step 1 is to click start go to RUN and type MSCONFIG and press enter.
Step 2 look at the tabs the tab that reads startup is the tab you will click.
Step 3 see the check marks next to the each of the lines of information, click on them one at a time to remove the check mark,
Now click apply and OK and the system will will ask you if you woiuld like to restart choose yes.
Your system will restart and when it come back up ut will let you know that the system comfiguration had been used there is a emty box on that screen and you will need to click to place the check mark there, do that and then click OK, this will speed thigs up.
Posted on Nov 05, 2008
    Problem Solver:
  • 19 Answers
Clean out spyware and any possable viruses. this will help alot. you should also think about adding more system memory (RAM).
Posted on Jan 14, 2009
  • 903 Answers
Clean the computer up with windows disk cleanup. If you have not added any programs or software within the last couple of days, then go to start>programs>accessories>system tools> disk cleanup.
Click on all the options thatt you want it to clean for example temp files etc.. then click on the other options tab and click on clean system restore. Click yes or ok when it ask if you are sure. It will automatically save your last restore point. Restore points if not cleaned will take up loads of space on your computer. Once you have confirmed the cleanup will begin to compress your old files and if you have not done this before it will take a long time and you will have to be patient. The longer it takes the more space you will gain, because it is determing how much space you will gain. ONce you have done this then defrag your computer to gain more space and tidy up your files to make it run more smoother. Go to Start>programs>accessories>system tools> defrag.
Choose to defrag C: again this may take a long time. When you do this make sure you disable your screensaver by choosing 'none' in the options and apply. I normally leave my computer to defrag overnight otherwise it is like watching paint dry. Once you have done both of these soloutions, you should have gained space and made your computer more efficient. If you still have sluggish problems after this, I suggest you think about adding more ram.
I hope this helps you
    Genius:
  • 1,124 Answers
This issue can be caused by any of the below possibilities.
Hard disk drive is short on available disk space.
Several software programs have been installed/uninstalled leaving behind bad files and/or confusing the software.
Data Corruption.
Computer is overheating.
Bad Hardware.
PC Solution:
Below are steps for Microsoft Windows that should help speed up the computer or determine why the computer is running slow.
Not enough hard disk drive space
If you have a hard disk drive that is 2GB or smaller, ensure that there is at least 200MB of hard disk drive space free. If you have a hard drive larger than this size, verify that there is at least 500MB of free hard disk space. This available space allows the computer to have room for the swap file to increase in size as well as room for temporary files.
Hard drive corrupted or fragmented
Run Scandisk or something equivalent to help ensure that there is nothing physically wrong with the computer hard disk drive.
Run Defrag to help ensure that data is arranged in the best possible order.
Background programs
Remove or disable any TSRs or programs that automatically start each time the computer boots.
Hardware conflicts
Verify that the Device Manager has no conflicts, but if conflicts are present, resolve them.
Computer or processor is overheating
Make sure your computer and processor is not overheating, excessive heat can cause a significant decrease in computer performance some processors will even lower the speed of the processor automatically to help compensate for the heat related issues.
Specific operating system basic troubleshooting
Try running through the basic troubleshooting steps for your operating system.
Erase computer and start over
Finally, if none of the above solutions resolve your issues, it is recommended that you either reinstall Windows and/or erase everything and then start over.
Hardware issues
If your computer continues to be slow after going over each of the above recommendations it's possible that your computer is experiencing a more serious hardware related issue such as a failing component in the computer. This could be a failing or bad CPU, RAM, Motherboard, or other component.
  • Pablo Csaky
    Pablo Csaky Nov 05, 2008
    Be sure that your computer is NOT virus or spyware infected
Emachine w3611 power button blinks but won't start computer
Try unplugging from power source and leaving for about three minutes and then plug it back in.
May 12, 2015 | eMachines W3611 PC Desktop
How to get hdmi on emachines model w3611 without buying anything, is there a plugin inside?
No. The W3611 only has a VGA output on the motherboard. To add an HDMI port, you will need a video card. If you choose an internal card, the machine will probably need a better power supply (400W or higher). You will also need to remove the card that is currently in the PCI-e x16 slot (probably the Fax modem).
There are some external video adapters that connect to the USB port. Some have HDMI out. However, if you want to play games or moves, these are often not a good option. They are limited by the USB 2.0 port.
CNET gives the specifications for the W3611 here: http://reviews.cnet.com/desktops/emachines-w3611/4507-3118_7-32329686.html .
I hope this helps.
(no computer has "hidden" video output ports. All have to be visible from the outside of the case.)
May 01, 2013 | Computers & Internet
Upgraded memory in W3611. Won't start. Gives three long beeps instead. Restored old memory. Won't start. Gives three long beeps instead.
Remove RAM(S), clean the ram slot by blowing air, fix RAM(s) back in position untill both the side clamps are properly locked.
If problem persists try resetting motherboard via jumper pins on the motherboard.
Sep 03, 2010 | eMachines W3611 PC Desktop
Comp. runing real slow
Download, install these free programs that will clean you're system; http://www.filehippo.com/download_ccleaner/
And; http://www.piriform.com/defraggler
These should help the system perform faster.
Mike
Apr 24, 2010 | E-Machines eMachines Desktop PC
Emachine running SLOW and Freezes - 1 year old
Here are some suggestions: First of all . Do you have an anti virus installed on your husband's machine ? Viruses can slow the machine and even kill it permanently ( so be careful) . Just install an anti virus and you'll solve the problem . If you are already have an anti virus , then just run a full system scan and watch what will happen and follow the recommended steps that will be given by the anti virus [ There are a lot of anti virus softwares in the market ] but if you suspect that your system is already infected i recommend you to use (Avast professional edition) because it can make a boot scan , that means after you install it , it will ask you if you want to make a boot scan , just agree with it and it will reboot the system and start a boot time scanning , meanwhile you should watch it and give it the right orders if it detected a virus infection . Here is another suggestion : There is a certain software you could install it . This software can help your machine and detect any problem on your husband's computer but viruses . this software is called (TuneUp utilities) . You can download it from here www.tune-up.com . just try it and you'll be satisfied with result . if that didn't help just contact me again and i'll help you as possible as i can .
good luck .
Jan 29, 2010 | E-Machines eMachines Desktop PC
Freezes while trying to do fresh install from
this indicates a bad hard drive, or Ram or both
Jul 29, 2009 | eMachines W3611 PC Desktop
Motherboar reconected
Remove the hood, and double check that all of the cords and wires are correctly plugged in and secure. Hope this helps, Thanks
May 27, 2009 | eMachines W3611 PC Desktop
I don't know where to put my picture card at
according to eMachine's webpage, your dejtio should have a built in card reader.
It should look like this and will be located at the front of your computer: Your card should fit in the top right slot (according to this picture) or a slot marked with the words "SD".
Apr 19, 2009 | eMachines W3611 PC Desktop
Repalcing video card in emachine w3611
no signal try open your system unit get the memory then put it back then try to switch on your computer
Apr 07, 2009 | eMachines W3611 PC Desktop
E-Machines eMachines Desktop PC Logo
110 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
