Question about Compaq Presario s4020wm (DK214AR#ABA) PC Desktop
OS will not load
My system will not load the OS (XP). The system seems to load, but once it gets past the Compaq screen, it goes black. The light is on like it is working but nothing. I tried to do a system recovery, but the recovery shutoff or locks up and restarts. I used the System Suite 8 to try to boot the system and that didn't work. My biggest thing is saving the files that are on the hard drive. Is there a way that I can copy them? Can I access command prompt from any where other than alt+d in the system recovery mode? PLEASE HELP! I am losing my mind here!
  • 3 more comments
  • Kennebrew Nov 12, 2008
    I did unplug all the usb devices minus the keyboard and the mouse. Still didn't work. So, what I am resorting to is installing a new hard drive which brings me to another set of questions. I did not receive a copy of the XP disc with my computers. I have a HP that has the same OS as the compaq. Can I (and how) clone the hard drive on the HP to the new drive for the compaq? Will the recovery discs that I have work?
  • Kennebrew Nov 13, 2008
    A little more detail....I am moving from a 40gb to a 250 gb drive. I have Norton Ghost to copy the original drive. Is there a way to isolate the OS on a separate partition on the new drive?
  • Kennebrew Nov 20, 2008
    New problem....I am seriously ready to chuck this machine. Compaq didn't have the recovery discs for this model pc, so I bought the Windows XP Pro to install on the hard drive. In the setup, I am getting the following error:
    SXS.DLL - Syntax error in manifest or policy file "D:\I386\asma\10\MSFT\Windows\GDIPLUS\GDIPLUS.MAN" on line 4
    Any idea as to what the problem is and how to fix?
    I do have a regular XP disk. I finally got the install to work (cleaned the disk off)....NEW PROBLEM...nothing else will load to it now...I can't get any updates, drivers or even install my antivirus....and it is moving SOO Slow. The RAM was upgraded back in August and a new power supply was put in.....I am at a serious loss as what to do at this point. I have re-formatted and reinstalled....now when the boot screen comes up, I have two choices for OS to choose from. Both are the same one.
  • Kennebrew Dec 05, 2008
    Much appreciation....after installing and reinstalling a few more dozen times, I finally got it to install. I removed the ram that was recently installed and adjusted the BIOS settings and it ran straight through with no problems.
    Genius:
  • 1,124 Answers
Kennebrew if it's a fresh install, just try and reinstall. When it gets to the part about installing on the following partition, follow the instructions to delete the OS partition, then reformat it. Don't use the quick ntfs format. Use the regular (slow) method. When I am having an install problem, that usually works for me. Trying to do a fix on a new install is usually going to end up with problems down the road. It's better to do it now before you have data to lose. I'm assuming you have a regular XP CD and not a proprietary one from a manufacturer (recovery disk i.e.dell compaq et al)
Posted on Nov 20, 2008
    Genius:
  • 1,124 Answers
Unplug all USB devices >> turn off your computer and turn on again (with all USB devices unplugged)
Posted on Nov 05, 2008
  • 4 more comments
  • Pablo Csaky
    Pablo Csaky Nov 12, 2008
    If you clone the disk means that both disks will become the same. You can use the same recovery disk set.
    To clone your disks you need a program like a partition magic or similar.
    Or you can get a Ultimate boot CD from internet for free here:
    http://www.ultimatebootcd.com/
    You will get a lot of utilities for your hard drive in that disk for your needs
  • Pablo Csaky
    Remember that if you clone the disk both disks must be of the same size. If you have disks with different sizes you can copy the partitions instead of clone them.
  • Pablo Csaky
    Pablo Csaky Nov 13, 2008
    Sure, you have to do two partitions. You can create one with the same size of your original hard drive and copy that partition there and keep the available space like a second drive (aprox 200 GB)
    You can do it easily with partition magic.
  • Pablo Csaky
    Pablo Csaky Nov 20, 2008
    JUST IN CASE......
    Due you're doing a fresh installation, this option is NOT VALID, but keep this info, just in case....(to replace the corrupted file)
    SXS.DLL: syntax error in manifest or policy file
    The gdiplus.dll file is probably corrupted. Go to this site and download the file and replace it
    http://dll-files.com/dllindex/dll-files...." target="_blank" rel="nofollow" http://dll-files.com/dllindex/dll-files....
  • Pablo Csaky
  • Pablo Csaky
    There is two ways to remove the second instance of Windows XP in the boot
    screen.
    One way is in Control Panel > System on the Advanced tab, click the Settings
    button under Startup and Recovery. Click the Edit button and remove the last
    line in the boot.ini file.
    The other way is to open C:\boot.ini in Notepad and delete the last line in
    the file and save the file.
    It is a hidden, system file so it may not show if you don't have your system
    configured to show hidden and system files.
    About your computer slow, go to bios and check the CPU temperature.
    Check also if your CPU fan is working properly to discard any hardware issue
Hey I'm having troubles with my compaq mini hp 110
Sounds like the operating system is not loading. needs to be reinstalled.
Jan 24, 2013 | Computers & Internet
I have a compaq presario 1200 laptop and I have a blue screen problem. Whenever I run anything memory intensive it simply flashes a blue screen at me then reboots. Whats more is after it reboots it won't...
Your Operating System (OS) is corrupted.
The best solution to this problem is to reinstall your OS using an OS installation CD.
I would also recomend upgrading to Windows XP.
You can upgrade by simply installing Windows XP on your laptop.
Back up all your data before reinstalling your OS.
Jan 07, 2010 | Compaq Presario 1200XL104 Notebook
Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
May 22, 2009 | Compaq Presario R3000 Notebook
Dell Precision WorkStation 650 crashed and restore CD won't load
If possible try changing your cd rom or dvd rom for cd use check it is recognised in bios and change bios to boot from it,if you still get the black screen with flashing cursor ,could be os is missing due to hdd failure
Jan 09, 2009 | Asrock AM2NF3-VSTA (4711140874470)...
Laptop wont turn on properly
A vital component that windows requires to run is corrupted. To fix it, you need the OS disc
In Windows Vista, there is usually a second partion on the harddrive that you can load by pressing F8 (or F10 depending on your system) and selecting the repair your computer option (depending on your manufacturer, you might need to input a password, after that choose the repair your computer option or solve startup problems
In Windows XP load the disc and open the recovery manager.
Jan 01, 2009 | Compaq Presario 700 470024-192 Notebook
Os loading
have you got a cd/dvd drive or a mem stick.if not I could send the sp2 file via email.when you get it drag and drop it into a file(or desktop or my documents)and then double click it and off it goes
Nov 06, 2008 | Compaq Presario Notebook
Hp compaq d220 MT loading screen freeze up
only thing I can see is for you to re-install WIndows xp. seems like the operating system having a porblem loading.
Oct 13, 2008 | Computers & Internet
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Oct 12, 2008 | Compaq Presario 1700 Notebook
Compaq Presario s4020wm (DK214AR#ABA) PC Desktop Logo
282 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
