Question about Frigidaire ATF6000ES Front Load Washer
Fridgidaire affinty front loaded washer 1 month old
I have only used my new washer maybe 6 or 7 times. I put a load in today and it washed them but did not drain or spin them. I can hear a slight hummmm sound and it clicks and tries to drain but then I hear the hummmmmmm sound again and the time runs out. Meanwile the clothes are stilla little sudsy and soaken wet. This washer was not cheap and I need help on what I can do rather then take it back 45 miles away .
Thank you
  • 903 Answers
Most machines come with transport protection, like spacers or a bar across the top of the machine (inside) that need removing before you use it. It will tell you in the instruction manual about these. Always check this first incase you remove the wrong item/s. If you done this already, then it could be a faulty programmer. I would not try to replace anything yourself while the machine is still under guarantee because the company will refuse to fix it if you have already tried. Contact the company you purchased it from and let them know your problem. They should send out an engineer and you should not have to take it back. If the engineer cannot fix it, it is their duty to replace it and deliver it to your door.
Posted on Nov 05, 2008
Washer Seal ripped door seal
Yes. Because all front load and or stacked machines are bad! It is called Planned obsolescent. Meaning, it is normal for a new machine to break and become obsolete! These seals on the front loaders can be Expensive around $100 dollars...Sorry
Feb 19, 2014 | Maytag Washing Machines
Drum does not spin centered, it is rubbing the seal
This isn't good. it's normally related to the tub bearing or spider brace on the inner/ outer tub. Both parts tend to be very costly. If its under a year old you will be covered in warranty.. if not it maybe time for a new machine. I have seen this on washer's as little as 14 month old. I'm not a front load washer fan because of this problem.
Jan 19, 2014 | Maytag MAH8700A Front Load Washer
My fridgidaire frontloader wont do a spin cycle
A lot of times it is the strainer clogged at the pump. That has happened to mine. Hope that helps.
Sep 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Tub cracked on my Fridgidaire front loading washing machine
sorry no recalls on fridgidaire front load,,there pretty good units,,the mildew and slugg comes from not using he or low suddsing detergent..now dont move so fast ,,because a new spin basket may not solve your problems with noise..check that back tub bearing while you have it a part..now that unit is fresh and new ,,clean the unit every other month with bleach..hot wash cold rinse,,that will keep suds slug and smell out unit...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Repeating cycles
REPLACE POWER CONTROL BOARD SOUNDS LIKE TIMER PROBLEM
Dec 12, 2007 | GE WCVH6260F Front Load Washer
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Feb 25, 2007 | Maytag MAH8700A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
