Question about Toshiba 42H81 42" Rear Projection Television
Service manual for 42h81
I got this tv from a buddy, but he messed with the yoke magnets. i'm fairly fluent with convergence as i have a Sony 1252 pj in my theater. the color is off and the convergence is off. the touch convergence comes back with an error. i really need a service manual so i can go through the service level convergence setup. ive found a few places offering to sell the manual but i'm hoping to download a free copy...
Regnad
  • regnad Nov 10, 2008
    i sent you an email to premtech@willapabay.org, but you replied saying that i need the correct manual....? i thought you where going to send one to me with Pando?
    shannon
  • 934 Answers
Email me privately and I can send you one via Pando... You will need Pando to download it but it in itself is a free download... Be precise in what you're asking when you email, I get more than 3000 emails a day so it will be impossible to figure out what you need without you telling me.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Posted on Nov 07, 2008
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
Do you have the service codes for the JVC I'art AV-27F802? I have a set that has convergence & color calibration issues and I can't find the codes anywhere... Thanks
There is no much convergence adjustment inside service menu. Yes color it has RGB drive adj. but if not touch it will not change. Convergence mostly adjusted mechanically (check your purity magnet and yoke mounting). Hope it helps
Feb 10, 2010 | JVC AV-27F802 27" TV
42H81 Convergence issues
I've seen a few shorted convergence yokes in toshibas. Sometimes after running the TV for a few minutes, you can feel the relative temperature of the 3 yokes to tell which is overheating and therefore shorted. Don't forget to re-check all the low resistance resistors around the convergence ICs to make sure that the are within the 5% tolerance rating they should be. Also on some of these models, there is a jumper wire located near one of the ICs that develops an intermittent solder connection.
michtech
Feb 14, 2009 | Toshiba 42H81 42" Rear Projection...
I have a Toshiba 42H81 that has the power indicator light blinking and the TV will not turn on
Replace the convergence amps and check the return resistors in path to the yoke from that circuit.
Bill
PO Box 442
360-642-4993
Oct 14, 2008 | Toshiba 42H81 42" Rear Projection...
Convergence -manual
Replace the convergence amps and test and replace any or all of the 2.2ohm resistors in the yoke return path out in front of the amps. This unit takes two STK392-110 Sanyo originals, DO NOT GET CHINESE KNOCK-OFFS... Buy them from Acme sales out of Florida and you can be assured they're originals.
Bill
PO Box 442
360-642-4993
Oct 11, 2008 | Toshiba 42H81 42" Rear Projection...
TV turns on only after disconnecting convergence cable to red yoke
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Sep 23, 2008 | Philips 50PP9202 50" Rear Projection...
Convergence
The 1.2 ohm resistors should have the rating stamped on the resistors themselves. But if you would like the service manual I can post a link where you can buy one and get free unlimited tech support with the manual purchase
Apr 09, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Toshiba 50H81 manual convergence
are you sure it's yoke? these are know for bad convergence amp ic's
other wise it's a screw and glue holding the yoke in place loose the screw and try to break the glue with out breaking the plastic on the yoke, the other thing you can do is adjust the magnets which have tabs on the yoke. i would mark the position's of everything on the tube with a sharpie so you can get it back to start.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Toshiba 50H81 50" Rear Projection...
PT-53WX42F
http://www.hdtvoice.com/voice/showthread.php?t=28929
Sony Convergence
Jan 26, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
182 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
