Hi i am having a problem with my hp 65 watt ac adapter it is getting very hot to the point were it will burn you to touch it!is it sopost to do this or do i have a serious problem?
    Problem Solver:
  • 12 Answers
This is pending doom for your systems mother board if you do not replace the power supply, the first thing you will notice is the loss of use with your USB ports if this happens the next thing will be the video and other motherboard components, You should unplug the power from the wall and get a replacement power supply, If you would like to save a few dollars, you could use a universal power adaptor, stay away from the RadioShack you will save money there. The power supply from HP is a little over 1 hundred dollars- the after market power supplys should run about $35.00 to $65.00.
Posted on Nov 05, 2008
Why do dimmer light switches run hot to the touch?
Dimmer should be warm... but never HOT
7 x 65 = 455 watt
Dimmers are rated 600 watt to 1500 watt
Sounds like you have bad dimmer.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat
Gene
Oct 07, 2014 | Leviton Electrical Supplies
N7010 AC adapter not detected
Hi.
make sure your charger is good, if not buy another. Now if you are good will have to replace the motherboard
Apr 04, 2014 | Dell Inspiron 17R (N7010) AC Adapter 65...
Can i use any charger on s505
The Toshiba Satellite 5205 series of Notebook PC, and the S505 series model; uses an AC adapter (Charger) that produces 15 Volts DC.
http://www.sparepartswarehouse.com/Toshiba,Satellite,5205,PS520U-31P1RV,Laptop,AC-Adapters.aspx
You will see AC adapters sold that show 15 to 24 Volts. (DC)
http://www.duracelldirect.com/toshiba_satellite-5205-s505_ac-adapters_laptop_ac-b20h.aspx
This is because the AC adapter (Charger) has PFC.
Power Factor Correction,
http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-Power-Supplies/181/2
Also I see it is just a two pin AC adapter plug, to laptop.
Center hole is Positive, outer metal cylindrical metal shell is Negative.
Go for 75 Watts or higher though, and not a 65 Watt model.
[ On the case of the AC adapter;
Input: 100 ~ 240 VAC 50-60Hz
Means it can use from 100 to 240 Volts AC, and either 50 or 60 Hertz.
Output: 15VDC 6A
Means 15 Volts DC at 6 Amp's. (Amperes)
Watch the outside dimension of the cylindrical part, and the center hole dimension. Outside cylinder may be correct, but center hole may be too small. Or vice-versa.
Regards,
joecoolvette
Dec 17, 2012 | Toshiba Satelite 5205-S505 Notebook
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
How do I get my computer to recognized my new ac power adapter?
The computer doesn't need any drivers to recognize an AC Adapter. If you have purchased the correct AC Adapter for your laptop then it should just work when you plug it in. If it does not then my guess is either you have received a faulty AC Adapter or the DC Jack which you plug into in the back of the laptop is bad.
I am assuming your battery is dead and when you plug it in and turn it on nothing happens?
You can also try taking the battery out and try to power it on with the AC Adapter plugged in.
The Dell Latitude D610 takes a PA-10 or PA12 AC Adapter. It's 65W or 90W
For 90 watt Adapter the output voltage on your AC Adapter label should read 19.5V and 4.62A
At least that's what the Dell brand reads so it should be close to that.
Jan 20, 2011 | Dell Latitude D610 Notebook
I have a pavilion dv 7 that shutdow the otherday.The battery was hot and if i turned the pc back on it would run for a couple minutes then shutdown.The charger was also hot. I purchased a new battery and...
There are isues with HP external power supplies - if it is a dv7-3xxx series you require AC Smart adapter (120 watt) - 100-240VAC input, 50-60Hz, 2.5A - 18.5VDC output, 6.5A, Pt No 463953-001
for earlier models require AC Smart power adapter (90 watt) - 100-240VAC input, 47-63Hz - 19.0VDC output, 4.74A, 90 watts, with power factor correction (PFC) 463955-001
If you are within the warranty period utilize that warranty if not contact HP and see what price a replacement external power pack is.
Jun 15, 2010 | HP Computers & Internet
I need a new cord that plugs in to charge the batteries,or so i wont need to use batteries they are dead
Here are the specifications for the power chord for your notebook.
417220-001 : AC adapter (65 watt) - Input voltage 110-240VAC, 50-60Hz, 2.4A - 18.5VDC output voltage, 65-watt - Requires a separate 3-wire AC power cord with C5 connector
You can purchase from impact computers
Mar 28, 2010 | HP Pavilion ze2000 Notebook
HP DV9000 Display Works with battery not AC almost
Have you checked whether the Power Adapter of your Notebook is a 65 Watt or 90 Watt ??
If you are connecting a 65 Watt adapter with the Notebook, try wiht a 90 watt one from any other Notebook if available..
Notebooks with Nvidia Graphic card need a 90 Watt Power adapter to supply the adaquent power required for the Graphic Card and a 65 Watt adapter may not be able to supply the required power.
Aug 03, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
