Question about GE Spacemaker JVM1640SJ Microwave Oven
Messages i just move here and there is a message on it. How do i get it off of the mic?
  • lastewart69 Nov 06, 2008
    i just need someone to help me i have no money please help poor me
    President:
  • GE Master
  • 2,651 Answers
Just tried on my own micro.. after listening to message, i was prompted"to erase message press 0" all gone!!!!
Posted on Nov 07, 2008
I removed the bolts for my Danby OTR microwave. Dmw162w-otr. The microwave does not move. Are there any other bolts or is there anything I am missing before I can remove the microwave?
In a normal installation, there is a plate that mounts to the wall and bolts come down through the cabinet. Once the bolts are removed from the cabinet above mic, the mic should hindge forward. It takes two people to handle. How ever, in some cases an installation guy will add screws into the side of the unit. So look for some screws to the right and left of mic. Good luck!
Jan 29, 2016 | Danby Microwave Ovens
My GE Spacemaker XL1800 ovenstarted to show F3 error message and three beeps. Keyboard except light and fan keys was dead. Disconnected it from the wall outlet and forgot about it for three. weeks....
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
I would need to know your actual model number to tell you exactly, but on GE most models you can replace the control panel assy, which comes with a new keypad, and that's an easy DIY job with a part cost of about $100, sometimes less.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
You can find exploded view diagrams and order parts here.
Dec 25, 2009 | GE Microwave Ovens
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I HAVE MIC. NN-SD997S ,IT DOES NOT WORK ,MESSAGE SAYS "H98" .
This displaying indicates a
problem with the microwave
generation system
This is for your dealer to resolve
Mar 11, 2009 | Panasonic NN-SD997S Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker oven keeps flashing "message - hit button for messa
If you have an "options" pad, press that and you should be able to get to the message sub-menu. If not, you may have gotten too much moisture in the key pad when you cleaned it and it will either need to be replaced or might possibly return to normal after drying out completely for a few days
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
Message Pad does not replay
Is there a fan or another noisy device running in the background when you leave the message? You might contact call the GE Answer Center at 1-800-626-2005.
Sep 24, 2007 | GE JVM1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
35 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
