Question about Acer Aspire E380 ASE380-UD500A PC Desktop
Installing cd drive
I was trying to install another cd drive computer. I am able to remove the front bezel but there is still a piece of metal blocking the 5.25 bay. Anyone knows how to remove that?
I am preparing to install a 2nd DVD burner in the E380, and have done quite a bit of research and prep, and called tech support about how to remove the metal piece.
First, remove bothe sides of the case. Then remove, carefully, the front panel which is snapped on. There are three tabs on each side holding it. With a flat screwdriver pop each tab loose. There are wires attached to the data posts which don't need to be messed with, just swing the front panel aside. This gives you total access to the drive bay, which is covered by a piece of metal that has been punched through and still held in place at two spots in the middle of each side of the slot for the drive.
The tech guy said, after asking someone, that you wiggle that plate up and down, piveting it back and forth until it snaps off. I used a pair of needlenose pliers and it was suprisingly easy. After wiggling it 6 or 7 times it came right off.
So I'm now waiting for the drive to arrive by UPS and I'll be ready to go.
Posted on Dec 04, 2008
    Sergeant:
  • 201 Answers
Hey there beisong,
In many desktop computers you need to install the drive from inside the case and slide it outward along the runner. The piece of metal you are possibly referring to, will prevent it from sliding out too far from the inside. Alternately, but less likely, there may may some quick locking mechanism on the side of the bay drive which is in place and preventing your further movement inward. In this case simply remove, usually by twisting to one side or the other to release. It may be advisable to remove both side panels to ensure there is not one on the opposite side.
Good luck and let me know how it goes.
Posted on Nov 05, 2008
How to replace CD-ROM drive
In most cases, yes. Sometimes the drive can be removed by pulling it back into the case's motherboard area, then the new drive installed and pushed forward to be flush with the front of the bezel, but not usually. It is usually easier, if the hardware allows it, to remove the front bezel, unplug the drive's connectors, loosen the mounting screws or other gizmos, and push the drive out through the front. Reverse the procedure to install the new one.
Oct 07, 2014 | Gateway 3250S PC Desktop
Disc got stuck in a Lenovo H320
1) Unplug the computer from power.
2) FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out
(Short Circuit) the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
3) Facing the front of the computer the LEFT Side Panel removes.
At the rear of the computer, and on the back edge of the Side Panel, are three Philips head screws to remove.
One towards the Top, one towards the Bottom. Along that edge. There is another screw on the bottom, below the screw on the edge, and towards the middle somewhat.
Use the fingergrip molded out of the back of the Side Panel, and pull the Side Panel towards the back of the computer, then lift off.
4) Remove the Front Panel. (Proper speak for Lenovo = Front Bezel)
Once the Side Panel is removed there are three tabs on the Front Bezel to depress.
These look like flat plastic 'fingers' with a flat hooked end. They are molded out of the plastic of the Front Bezel. They go through slots in the metal framework of the computer case.
Ease the Top plastic tab towards the OUTSIDE, and ease the Front Bezel out a little, at the top.
Now go to the middle plastic tab, and ease it to the outside.
When the bottom plastic tab is eased towards the outside, the Front bezel will swing off. It is just a cover.
5) Now look for a tiny hole near the optical drive's tray.
(CD/DVD drive = optical drive)
Straighten out a paperclip, and bend the end over so that you have a little handle.
Put the straightened out paperclip in the hole, and push in. This is a manual override, and makes the optical drive's tray come partially out.
Then you can grab the tray, and ease it on out.
If there is no manual override hole, you'll have to disconnect the power cable, and data cable, and remove the optical drive's mounting screws.
Then remove the small case cover screws for the optical drive, and remove the disk.
Regards,
joecoolvette
Aug 22, 2012 | Lenovo IdeaCentre H320 PC Desktop
Want to add an additional dvd rom to my packard bell IXTMX6618 but unable to remove the front panel can anyone help
no need to remove front pannel there r slots on the upper portion of cabinet. unscrew cabinet side door and push one of the slot it will come out then u can place dvd from front connect necessary cables and screw the side door
Jan 11, 2010 | Computers & Internet
I need help installing a cd drive in an Antec Sonata III 500 computer case. How do I do it?
Unplug the power from the computer. Open the case cover. Carefully remove the placeholder on the front of the case where you wish to install the CD drive. Make sure you have the proper ribbon cable for the type of drive you are installing and that you know where to plug it into the motherboard (consult your motherboard manual).
Use the screws provided to secure the drive to the chassis rails (make face of drive flush with front of case). Attach an available power supply connector to the new CD drive. Close the cover.
Dec 04, 2009 | Antec Sonata III 500 - mini tower - ATX ...
Acer Travelmate 290 DVD drive quit working. Trying to find a replacement - no luck
I found this drive on Ebay just doing a search:
http://cgi.ebay.com/SD-R6112-DRW-SD-R6112-MS-OEM_W0QQitemZ180382772836QQcmdZViewItem
The model of your dvd drive in your system is SD-R6112 and its the same drive thats used in the Toshiba laptops. The only thing you might have to do is to swap out the front bezel and also the metal piece in the back of the drive but this drive would work in your laptop.
Aug 08, 2009 | Acer TravelMate 290 Notebook
Can figure out how to remove the cd drive from the actual case
I work at a computer repair shop and I have had a similiar problem with the new compaqs, but the solution is simple. take the side cover off, look in the front of the machine right in the corner where the front bezel and the metal frame meet. There are little plastic tabs on the top and bottom corner. You need to push those tabs either toward you or away from you(depending on model). While those tabs are moved, pull gently on the front bezel. After the bezel is removed, you should be able to remove the drives by taking out the screws and pulling the drives out the front of the case. Hope this helps
Jun 18, 2009 | Compaq Presario 5000 PC Desktop
Installing cd drive
The piece of metal is a punch out and you will need a flat head screw driver to pry it from the corner of the punch out then bend it back and forth until it release from the small connecting points around the metal, this will fatigue the metal and break away from the opening.
Nov 05, 2008 | Acer Aspire T310 PC Desktop
Installing cd drive
That piece of metal is called a knockout. It's there to block off that area as long as you don't have anything installed there, to maintain a seal for cooling purposes. You can remove it by simply knocking it out or twisting it. Once you have be careful where the tabs were attached may be sharp, use caution until you get your new drive install to block the edges.
Hope this helps.
Dave
Nov 05, 2008 | Acer Aspire™ T180 PC Desktop
Dell inspiron 1501
Try going to the drive, in my computer ** should be named CD/DVD Or D: E: right click and press eject. Alternatively:-
if you look carefully at the dvd drive, it has a small pinhole in the front drawer. push a paper-clip sized piece of metal, or small jewellers screwdriver into the hole, this will force the drawer open.
mike @ compurepair.
Nov 05, 2008 | Dell Inspiron 1501 Notebook
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
Acer Aspire  E380 ASE380-UD500A PC Desktop Logo
156 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
