Question about Acer Aspire™ T180 PC Desktop
Installing cd drive
I was trying to install another cd drive computer. I am able to remove the front bezel but there is still a piece of metal blocking the 5.25 bay. Anyone knows how to remove that?
  • beisong Nov 12, 2008
    u mean just knock and it will come off?
    it looks pretty tough to be knock off
    lol
    Sergeant:
  • 207 Answers
That piece of metal is called a knockout. It's there to block off that area as long as you don't have anything installed there, to maintain a seal for cooling purposes. You can remove it by simply knocking it out or twisting it. Once you have be careful where the tabs were attached may be sharp, use caution until you get your new drive install to block the edges.
Hope this helps.
Dave
Posted on Nov 06, 2008
  • David Preston
    David Preston Nov 12, 2008
    it might take a lil effort but it is pre cut ther should be somewhere between 2 to 6 little tabs keeping it attached
    Good Luck
    Dave
3 Suggested Answers
danielstoafe
  • 12 Answers
SOURCE: installing cd drive
The piece of metal is a punch out and you will need a flat head screw driver to pry it from the corner of the punch out then bend it back and forth until it release from the small connecting points around the metal, this will fatigue the metal and break away from the opening.
Posted on Nov 05, 2008
wallydanger
SOURCE: Installing cd drive
I am preparing to install a 2nd DVD burner in the E380, and have done quite a bit of research and prep, and called tech support about how to remove the metal piece.
First, remove bothe sides of the case. Then remove, carefully, the front panel which is snapped on. There are three tabs on each side holding it. With a flat screwdriver pop each tab loose. There are wires attached to the data posts which don't need to be messed with, just swing the front panel aside. This gives you total access to the drive bay, which is covered by a piece of metal that has been punched through and still held in place at two spots in the middle of each side of the slot for the drive.
The tech guy said, after asking someone, that you wiggle that plate up and down, piveting it back and forth until it snaps off. I used a pair of needlenose pliers and it was suprisingly easy. After wiggling it 6 or 7 times it came right off.
So I'm now waiting for the drive to arrive by UPS and I'll be ready to go.
Posted on Dec 04, 2008
How to replace CD-ROM drive
In most cases, yes. Sometimes the drive can be removed by pulling it back into the case's motherboard area, then the new drive installed and pushed forward to be flush with the front of the bezel, but not usually. It is usually easier, if the hardware allows it, to remove the front bezel, unplug the drive's connectors, loosen the mounting screws or other gizmos, and push the drive out through the front. Reverse the procedure to install the new one.
Oct 07, 2014 | Gateway 3250S PC Desktop
Disc got stuck in a Lenovo H320
1) Unplug the computer from power.
2) FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out
(Short Circuit) the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
3) Facing the front of the computer the LEFT Side Panel removes.
At the rear of the computer, and on the back edge of the Side Panel, are three Philips head screws to remove.
One towards the Top, one towards the Bottom. Along that edge. There is another screw on the bottom, below the screw on the edge, and towards the middle somewhat.
Use the fingergrip molded out of the back of the Side Panel, and pull the Side Panel towards the back of the computer, then lift off.
4) Remove the Front Panel. (Proper speak for Lenovo = Front Bezel)
Once the Side Panel is removed there are three tabs on the Front Bezel to depress.
These look like flat plastic 'fingers' with a flat hooked end. They are molded out of the plastic of the Front Bezel. They go through slots in the metal framework of the computer case.
Ease the Top plastic tab towards the OUTSIDE, and ease the Front Bezel out a little, at the top.
Now go to the middle plastic tab, and ease it to the outside.
When the bottom plastic tab is eased towards the outside, the Front bezel will swing off. It is just a cover.
5) Now look for a tiny hole near the optical drive's tray.
(CD/DVD drive = optical drive)
Straighten out a paperclip, and bend the end over so that you have a little handle.
Put the straightened out paperclip in the hole, and push in. This is a manual override, and makes the optical drive's tray come partially out.
Then you can grab the tray, and ease it on out.
If there is no manual override hole, you'll have to disconnect the power cable, and data cable, and remove the optical drive's mounting screws.
Then remove the small case cover screws for the optical drive, and remove the disk.
Regards,
joecoolvette
Aug 22, 2012 | Lenovo IdeaCentre H320 PC Desktop
Window on drivers side froze and fell down and won't roll back up. How to take door panel off to fix the window
  1. Disconnect the negative battery cable. Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
  2. Remove the window regulator handle, if equipped.
  3. Remove the front door warning reflector.
  4. Remove the door panel screw (1) through the hole in the door warning reflector opening.
  5. Use a flat bladed tool in order to remove the rear deck release switch bezel.
  6. Disconnect the rear deck release switch.
  7. Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
  8. Remove the lower switch bezel trim screws.
  9. Remove the lower switch bezel
  10. Use a flat-bladed tool in order to pry the front door switch bezel upward.
  11. Disconnect:
  1. Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Installation Procedure
  1. Install the front door trim panel to the door. Ensure that the retainers are locked into place.
  2. Connect the rear deck release connector.
  3. Install the rear deck release switch bezel. Press the bezel firmly into place.
  4. Install the window regulator handle to the door.
  5. Connect:
  1. Install the front door switch bezel assembly to the front door trim panel.
  2. Install the lower switch bezel trim panel. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the lower switch bezel trim screws.
  4. Install the lower switch bezel trim screw access cover.
  5. Install the door trim panel screw (1) through the hole in the front door warning reflector.
  6. Install the front door warning reflector.
  7. Connect the negative battery cable.
Oct 15, 2010 | 2000 Oldsmobile Alero
Need to remove and repair headlight motor on a 1988 corvette
REMOVAL & INSTALLATION 1984–88 Vehicles
  1. Open the hood, then turn the headlights on.
  2. Detach the headlight motor wire on the outer side of the headlight.
  3. Turn the headlights off (the disconnected light should stay open).
  4. Unfasten the 4 screws at the bezel. There are 2 at the front and 2 at the sides. Fig. 1: With the hood in the raised position, unfasten the Torx® screws from the outer side of the headlight bezel/trim piece 91036p23.jpg
    Fig. 2: You must then remove the screws from the inner side of the bezel/trim piece 91036p24.jpg
  5. Remove the bezel. Fig. 3: Remove the first of the top bezel/retaining ring screws . . . 91036p25.jpg
    Fig. 4: . . . then remove the remaining Torx® screw 91036p26.jpg
    Fig. 5: Lift the bezel/trim piece away from the headlight assembly 91036p27.jpg
  6. Remove the retaining spring by carefully using a hooked end tool, such as a cotter pin removal tool to move it to the side.
  7. Remove the headlight from the aiming pins by rotating the headlight toward the center of the car.
  8. Unfasten the 4 retaining ring screws, then remove the ring. Fig. 6: With the hood closed, you can see the 4 headlight retaining ring screws (1) and 2 aiming screws (2) 91036p28.jpg
    Fig. 7: Remove ONLY the 4 retaining ring screws, do NOT touch the aiming screws 91036p29.jpg
  9. Remove the headlight pump from the mounting bracket, unplugging the socket as you pull it away. Fig. 8: Remove the headlight away from the mounting bracket, unplugging the socket as you pull it away 91036p30.jpg
    To install:
  10. Install the headlight bulb, making sure it is plugged in properly.
  11. Position the retaining ring and secure with the 4 screws.
  12. Position the headlight into the aiming pins. Move the retaining spring back into place.
  13. Install the bezel and secure with the retainers.
  14. Turn the headlights on, then connect the headlight motor wire.
  15. Turn the headlights off. Both should lower.
  16. Close the hood. Check the aim of the headlights, and adjust if necessary.
1989–96 Vehicles
  1. Open the hood.
  2. Open the headlight door halfway. This can be done either by turning the headlight switch on, then back to the parking lamp on position, or by the manual headlamp control knob (which is located on the inboard side of the headlight door). NOTE: Before removing the screws from the side of the headlight bezel, place your hand under the bezel to support and prevent damage to it.
  3. Remove the screws from the front of the headlight bezel. NOTE: Before removing the screws from the side of the headlight bezel, place your hand under the bezel to support and prevent damage to it.
  4. Remove the Phillips head screws from each side of the headlight bezel.
  5. Remove the bezel by pulling it straight out from the engine side of the hood. Fig. 9: View of the headlight bezel mounting 91036g28.gif
  6. Unfasten the screws from the headlight retaining ring.
  7. Remove the headlamp from the assembly, unplugging the electrical connector as you are pulling it away. Fig. 10: Exploded view of the headlight assembly 91036g29.gif
    Fig. 11: Location of the headlight mounting and aiming screws 91036g30.gif
    To install:
  8. Attach the headlight electrical connector.
  9. Position the retaining ring and install the screws securing the ring to the headlight.
  10. Position the bezel in place on the headlight assembly.
  11. Install the screws on each side of the bezel and tighten to 51 inch lbs. (5.8 Nm).
  12. Install the screws on the front of the bezel and tighten to 17 inch lbs. (1.9 Nm).
  13. Cycle the headlamps, then close the hood. Check the headlight aim, and adjust if necessary.
Jul 07, 2010 | 1988 Chevrolet Corvette
Can figure out how to remove the cd drive from the actual case
I work at a computer repair shop and I have had a similiar problem with the new compaqs, but the solution is simple. take the side cover off, look in the front of the machine right in the corner where the front bezel and the metal frame meet. There are little plastic tabs on the top and bottom corner. You need to push those tabs either toward you or away from you(depending on model). While those tabs are moved, pull gently on the front bezel. After the bezel is removed, you should be able to remove the drives by taking out the screws and pulling the drives out the front of the case. Hope this helps
Jun 18, 2009 | Compaq Presario 5000 PC Desktop
Can't access the mother board
Remove the left side panel of the computer (front facing you). After that you will see a quick release located at the top, off center slightly. That releases the lock for the drive carriage (Dvd, cd, hard drive, floppy). Pull the small metal piece towards you (left side of cpu facing you), and slide the whole carriage towards the front of the cpu. This will give you enough room to install another pc100 stick onto the motherboard. Install while off and unplugged, make sure it sits correctly and the white tabs on top and bottom snap in, reboot and bios should show upgrade.
Mar 28, 2009 | HP Pavilion 8760C PC Desktop
Installing cd drive
Nov 05, 2008 | Acer Aspire T310 PC Desktop
Installing cd drive
Hey there beisong,
In many desktop computers you need to install the drive from inside the case and slide it outward along the runner. The piece of metal you are possibly referring to, will prevent it from sliding out too far from the inside. Alternately, but less likely, there may may some quick locking mechanism on the side of the bay drive which is in place and preventing your further movement inward. In this case simply remove, usually by twisting to one side or the other to release. It may be advisable to remove both side panels to ensure there is not one on the opposite side.
Good luck and let me know how it goes.
Nov 05, 2008 | Acer Aspire E380 ASE380-UD500A PC Desktop
CD ROM is jammed-wont open
This has happened to me. Sometimes when I'm in a hurry I'll place a CD or DVD in the tray and start to close it without making sure that the disk is seated flat in the tray. If it's ****-eyed the CD wil shatter when the tray is closed. The only way to remove the pieces inside the CD drive is to take apart the CD drive. Might be easier just to replace the unit. They run from about $25.00 to $75.00. One other note: You can try to open the tray manually by inserting the end of a paper clip into a small hole on the front bezel of the drive.
Oct 17, 2008 | E-Machines emachines (emachinees) CD-ROM...
Removing the faceplate
Hi, I can help you with this. Are you trying to remove the cd-rom drive bay plate or the front panel of the tower?
Sep 16, 2007 | Compaq Presario 5000 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
