Question about Whirlpool 24 in. ADG6340iX Built-in Dishwasher
Whirlpool ADG 6340
Dishwasher fills and empties but does'nt spin and wash Any suggestions please
  • ian lamb Mar 31, 2008
    Hi my dishwasher fills seems to heat up but does not spin or wash ? can anybody help me.
    Ian 31st march
  • 1314 Answers
SOURCE: Dishwasher adg 6340
do you know how to use volt ohm meter your problem can only be two places either your timer is bad or your wash motor is bad un plug the wire at the motor set meter to volts take the connector after the water fills have some one turn the timer for you slowly if you get proper volts on your meter then open the door plug the connector back on the motor if the motor starts then the timer motor is bad if the wash motor doesn't run then its bad if you don't get no volts the contacts in the timer are bad now some timer motors can be replaced with out having to replace the whole timer
Posted on Apr 01, 2008
SOURCE: Whirlpool ADG 6340 Dishwasher
fault 7 is a fill fault . If you take the left side panel off you will see a white plastic tank . The sensor in the tank has failed
Posted on Jun 23, 2008
SOURCE: front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Posted on Jun 11, 2009
  • 534 Answers
SOURCE: We have a Whirlpool ADG 6552 dishwasher.It fills
sounds as if the pump motor has gone out. This motor pumps the water from the bottom of the dishwasher throughout the unit. The solenoid that i think your refering to is the solenoid that activates the drain pump. I would think the pump motor is either stuck and if you can get6 to the back of it you may be able to use a screw driver to spin the fin on the back of the motor to unfreeze it. If this doesnt work then the motor has gone out and will need to be replaced
Dave
Posted on Feb 23, 2010
tbirdfan1
  • 3051 Answers
SOURCE: I have a Whirlpool Dishwasher model no. ADG 6340
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Posted on Jun 05, 2011
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
I have a Whirlpool Dishwasher model no. ADG 6340 IX.The inlet valve is pulsing and letting in water on every pulse. It just keeps filling, over fills and trips elcb
$50.60 Quantity:
In Stock
Jun 05, 2011 | Whirlpool 24 in. ADG6340iX Built-in...
I accidentally put my ADG 4540 on prewash. it
You can continue. It will repeat the cycle and go further till end. But if detergent is required add.
Apr 15, 2010 | Whirlpool ADG450 Slim-Line Built-in...
We have a Whirlpool ADG 6552 dishwasher.It fills and it drains but it does not spray or wash. Is it the solenoid? can it be fixed?
Dave
Feb 23, 2010 | Whirlpool 24 in. ADG6552 Built-in...
Whirlpool ADG 957 Dishwasher not draining water?
There is a remote possibility that the drain line is clogged. Most units should have an aerator on the top of the sink area HOWEVER some are hooked up directly into the garbage disposal and it's at that point where the line can be clogged. Remove the clamp and make sure the line is clear or the hole in the disposal is clear.
Nov 09, 2017 | Dishwashers
Front light flashing
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Dishwasher adg 6340
is this a digital washer? If not turn the knob manualy while the bar is switched to on and see if you can get it running
Mar 30, 2008 | Whirlpool 24 in. ADG6340 Built-in...
What flashing are you referring to ? This could very well be a fault code.
Jan 09, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Whirlpool 24 in. ADG6340iX Built-in Dishwasher Logo
472 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
