Question about Microwave Ovens
HOW DO YOU REMOVE AN OVER THE STOVE GE MICROWAVE ?
  • 76 Answers
Open doors of your cabinet above the microwave, look carefully toward the front you will see two screws one on either side, remove theses screws while a helper holds bottom of microwave, after screws are removed lift up on rear of microwave it will slide up and out of a rear clip mounted on the back wall. remove wall bracket and job is complete. oh yeah unplug microwave, or turn off circuitbreaker first. easy as 1, 2, 3. hope this helps.
Posted on Nov 05, 2008
My GE Hvm1450dniww over the stove microwave won't
May be an internal fuse that has blown
Sep 13, 2012 | Microwave Ovens
Ge oven membrane panel
Order GE range/stove/oven parts today. We ship GE range/stove/oven parts on time or your order is free. Return any GE range/stove/oven part for any reason for one full year. Customer service for GE range/stove/oven parts is available 7 days a week. More than one million parts available. We stock the GE range/stove/oven parts you need for immediate shipment. We have more than 200,000 high-resolution part photos.
Jul 26, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Can you put and over-the-counter microwave over a stove?
Yes, that is what they are made for, As long as it has a vent that can be used to vent the smoke from cooking it can be mounted over the stove. Normally the bottom of the microwave should be mounted 16" to 19" above the stove top. The microwave must have a vent with a blower motor in order to be used above a stove top. Most have a thermal switch that will turn the microwave vent on once the temperature reaches a set point.
Jun 12, 2010 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Stove fire smoke on microwave above stove.what will clean off this smoke residue? we encountered a stove which left a heavy smoke residue on the microwave above. the microwave has a plastic handle and...
Mr. Muscle Kitchen cleaner will remove the smoke. It won't hurt the plastic. Just make sure to either wear rubber gloves or wash your hands soon after cleaning off the smoke residue. It will make the skin on your hands / fingers slick and then dry after your done. Let the cleaner sit for about a minute before trying to wipe off the smoke residue.
Mar 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE over-the-stove microwave has power, the table turns; but, it does not function (heat)
check the door satety interlock switches ... remove the cover and look for one or two micro switches.
If they are not able to report the door is closed, the magnaton will not come on and there will be no heat.
Mar 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Trim Kit for Over stove GE Spacemaker 1800
i think i am having the same problem, i spilled a cup of coffee inside of the microwave as i was reaching to get it and the turntable stopped rotating since then. what do you think could be the problem and how could i fix it?
Oct 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Removing an old old microwave oven
look in the cabinet above the microwave, there should be 2 bolts which go through the bottom of the cabinet and screw into the microwave. remove these 2 bolts holding the unit steady then tilt the unit down and away from the wall.
Aug 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need help figuring out microwave installation above stove
Not sure I understand the question, but is building your own cabinet or enclosure an option?
If not, please feel free to write us back if you can clarify this matter further.
We'd be happy to help.
Nov 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
156 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
