Question about Panasonic TH37PX60 37 in. Plasma Television
Picture goes white some times flickers on and off sound is fine
  • 3 more comments
  • t__holm Nov 05, 2008
    NOT POWER SUPPLY CONNECTIONS
    UNPLUGGING DID NOT WORK DG BOARD WAS CHANGED ALSO
    NOT MANY WAS IN A HIGH HUMID AREA
    TUNER BOARD WAS REPLACED
    ALL FITTINGS SEAM GOOD
    Brigadier General:
  • 6,966 Answers
To my understanding, white screen (white wash) is a feature of some plasma TVs. its purpose is to illuminate the entire screen so as to even out burn-in effects that is remove minor instances of screen image retention. Constant use of the feature or in your case flickering can decrease the life of the TV as using the white screen/wash stresses the unit and can result in deteriorated image quality.
To your concern, pls check if this feature has been enabled. Additionally, in some versions:
  • service menu, -v on the front panel control and 000 on the remote; or
  • a full factory reset, -v on the front panel control and i button on the remote. This would revert the unit back to factory settings.
Otherwise, you may need to reference a full service manual including the service bulletins. I was made to understand that there were several parts change. Or seek the services of a qualified professional or a Panasonic Service Center.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
  • Louie  Role
    Louie Role Nov 08, 2008
    Hi again,
    Any development(s) so far?
  • 76 Answers
Ysus board is bad if your looking at the back of the tv its the one on the left friend has fixed hundreds and fixes them every time. take it to a reputable service comp. and they'll give you an extra 3 month warranty on iy. or do it yourself. hope this helps
  • jerry g
    jerry g Nov 05, 2008
    Dry solder joints on the pins of the vertical integrated circuit commonly causes this. Tap each I/C with a plastic screwdriver handle to find the intermittent one. It usually is one with a heat sink attached. hope this helps
    Master:
  • 505 Answers
The TV is going in protect mode because it detects an internal problem, try leaving it unplugged for a longer time, let say one hour or two.
Basically, what happens is that the TV does not start because it detects that there is an internal problem, such as a wrong voltage, a bad component, overheating etc.
When you unplug power and restart it, you reset the internal circuit, and the TV will restart, not detecting the internal problem.
As soon as the TV gets hot, after staying on for a while, the defective part start giving troubles, as the defective component (probably an IC, starts overheating).
The Digital Processing Board can be cause for the problem.
However all the following parts can be involved.
Parts involved can be
Replacement Ballast
LCD Controller
Time to get the TV repaired. You can go to the following website for detail Parts List.
http://www.shopjimmy.com/TVs/Panasonic/Panasonic-TV-Parts.html
Thanks
  • Indrajit Roy
    Indrajit Roy Nov 05, 2008
    Sounds like you have an intermitant overdrive situation on the red CRT. This could be caused by a bad component on the Red CRT board, an intermittantly shorting CRT or the circuitry in the main board. You should not run it until the problem is resolved as you could damage the CRT if it is not already bad. This is something that unless you are a qualified tech you are not going to have any success resolving. It should not be very hard for a good tech to diagnose the problem. Costs will depend on the part which is bad. If it is the red CRT it probably is not worth fixing, but it could be a 50 cent capacitor. Certainly worth the cost of a service call. Good luck.
    Thanks
    Genius:
  • 1,689 Answers
Sound like a possible issue on the logic board of the display panel, this is repairable but it may cause you. BTW, have you had this unit serviced previously? how many hours do you have on it?
  • marlon john madrid
    marlon john madrid Nov 05, 2008
    any answer to my inquiry?
    the tuner board of your unit is almost with the logic board, having the part checked if the plasma has burnt out will be the key to your issue...
    Genius:
  • 1,550 Answers
Unplug the power chord for 30 minutes and plug back the power chord to tv .
This will clear the screen .
  • SAM ANDERSON Nov 05, 2008
    Your tv has a video problem leak capacitor need to be replaced.
    Scholar:
  • 155 Answers
The solderings on the power supply board are weak get it soldered properly.or it will lead to further problems.
  • 1 more comment
  • fixexpert Nov 05, 2008
    Possibly a loose solder or cold solder connection somewhere, or maybe a bad cap near the vertical IC, but if you can't find it, you'll want to contact a technician.
    this can also be caused due to overheating of any components on the main board.
    or the loose jack where the power cord of your tv is connected internally.
    check out this.
    check out the fittings on the tuner board let it be new,but if the fitting is not proper this problem could happen as the sound gets cracked there is a false effect on the picture quality.
    thanks.
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
Powers up - white picture with lines and no sound
Sounds like a min board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 14, 2014 | RCA L26HD35D TV
Samsung television flickers to bright white fuzzy picture
In such cases, we have to ensure that it is not the input device that is causing this problem. So, please switch your input device to something you are sure, works. If you notice same problem, look for loose contacts in inter connecting cables and jacks. If problem persists, please refer it to a qualified service technician.
Jul 28, 2012 | Televison & Video
How to remove back picture flickers then goes
Hi ignafam,
Sorry for the late reply, I'm offline upon purchasing my service.
I have some question so that I can give you an accurate solution regarding on your problem.
1. Exact model no. of your unit - this is located on the back cover, manual, or on the receipt.
2. Does the unit has sound, before it goes blank?
3. Does the unit goes black or white screen?
4. Does the symptoms remain the same in all inputs(when watching TV, DVD, game console, etc)?
Jdvillanueva
Oct 14, 2011 | Vizio 42 in. LCD TV
Horinzontal white line with sound
vertical collapse. usually not to expensive to fix.
Jun 02, 2009 | Toshiba 32A33 32" TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
White horizontal flicker on screen
Sounds like the logic boards on its way out
Feb 01, 2008 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Panasonic TH37PX60 37 in. Plasma Television Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
