Posted on Nov 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The printer will not print copies. It has ink in its cartridges. No problems until today.
Anonymous
Level 3:
Genius:
  • Master 1,689 Answers
  • Posted on Nov 05, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1689
Questions
8
Helped
567688
Points
4681
In behalf of the support group, may we know what is the modem number of your printer and what is the specific feature of it that is not working?
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
2answers
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Hi I just change my ink two times in a row and it still wont print what do i do ?
Will the printer print if you make a copy using the Copy button on the operator panel? Maybe the cartridges needs to be cleaned. Press Copy Mode. Press pattlnk_522006_1348-menu.gif -> Press pattlnk_522006_1348-up%20arrow.gif or pattlnk_522006_1348-down%20arrow.gifrepeatedly until pattlnk_522006_1349-side%20pointer.gifappears next to Maintenance. Press pattlnk_522006_1348-select.gif -> Press pattlnk_522006_1348-up%20arrow.gif or pattlnk_522006_1348-down%20arrow.gifrepeatedly until pattlnk_522006_1349-side%20pointer.gifappears next to Clean Cartridges. -> Press pattlnk_522006_1348-select.gif A page prints, forcing ink through the print cartridge nozzles to clean them. -> Print the document again to verify that the print quality has improved..
2answers
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
1helpful
Red on print is coming out pink
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If issue still continues:
  1. Verify that inkjet paper is loaded in the paper tray.
  2. Press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes green. The On/Off light continues to flash during the cleaning procedure.
  3. When the On/Off light glows a steady green, press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes, then wait for the demo sheet to print.
the printhead for your printer is in need of replacement. Contact Kodak
Best of Luck
Not all the colors print
Best of Luck
Poor black print quality black prints greenish grey
Best of Luck
The machine prints documents when using the print
When not used for any length of time, ink jet printer print heads will clog with dry ink. You can try to manually clean the printhead with a cloth moistened with water or maybe alcohol until you get some ink on the cloth. Then reinstall and run cleaning cycle. If unsuccessful, new cartridges are needed.
My Epson C60 won't print multiple copies after I have just installed a new ink cartridge. Prior to this it was able to do so with no problems. Now it will print 1 page then stoop, no matter how many copies...
I cannot think of a sensible reason why a faulty ink cartridge should stop the computer printing more than one copy (your post does seem to confuse "page" with "copy" though). To eliminate the cartridge as the source of the problem, you should install another one (a cheap clone on e-bay); if it now works, then yes, it was the cartridge causing the problem. If you still get the same problem, no, it isn't the cartridge. If it is the latter, I suggest you uninstall the printer, turn the printer off, reboot the computer, then re-install the printer, but do not turn it on until told to. If this works, the mystery remains why changing a cartridge should cause a printer driver hiccup! If it doesn't work, repost back with a new post and we'll scratch our heads a bit more!
Check ink cartridge
Your ink cartridges could be dried up or empty, even if they are new.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
