Question about Intel Motherboard
Northbridge Overheating Gigabyte MA790X-DS4 The Northbridge is idling at 84 celcius.... what do I do? that is way to warm .... and it is causing the computer to reboot constantly... especially when I'm half way through a laddered tournement match on COD4 ... It's worrying as I have read many reviews and they say this board sets on fire within 3 months of purchase :-/ Thanks in advance.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
Add a fan and put it on the NB heatsink. Also reapply quality thermal paste while your at it. I have a Gigabyte and my NB does get warm, so i put one of those small fans, got some double-sided tape, and that was it. Hope you fix it.
Posted on Nov 06, 2008
How do i gange it
Hello here is the gigabyte homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=2819#dl
You must be more precise, what your problem is.
Good luck
Apr 01, 2013 | GIGABYTE GA-M750SLI-DS4 AM2 NV750A DDR2...
Gigabite motherboard overheating
Well, you've left a lot to consider. Have you checked that the case and CPU fans are running? Where do the unit sit? Units that are placed inside computer desks that have doors in front of them are just begging for overheating problems as there is very poor air ciculation. Is the CPU sitting on the floor? Here the enemy becomes dust and dirt. Dust and dirt are the most common causes of PC heat issues. The CPU heat sink becomes clogged with dirt and cannot cool effectively. Use canned air (available at most stores that sell PCs) to blow out the heat sinks. DO NOT REMOVE THE HEAT SINK/FAN ASSEMBLY unless you have proper thermal paste to apply for the remounting. Usually a good cleaning is all most machines need.
Jan 03, 2012 | Gigabyte GA-MA790X-DS4 - Motherboard - ATX...
İşlemci x86 Family 16 Model 6 Stepping 2 AuthenticAMD ~2712 Mhz işlemci kaç çekirdek
If you are looking for the device drivers for this motherboard then -
You can download the device drivers from Gigabyte WEBsupport site, select your model motherboard to download :-http://www.gigabyte.com/support-downloads/support-downloads.aspx
May 08, 2011 | Gigabyte GA-MA790X-DS4 - Motherboard - ATX...
Currently when i start up my pc it boots up correctly until it reaches the DMI verification prompt. Here the system halts halfway through the process and does not even get to the window boot. i have...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 23, 2011 | Gigabyte GA-MA790X-DS4 - Motherboard - ATX...
Price of x86 Family 16 Model 6 Stepping 2 AuthenticAMD ~2712 Mhz
See for yourself
http://www.newegg.com/product/product.aspx?item=n82e16819103681
May 23, 2010 | Gigabyte GA-MA790X-DS4 - Motherboard - ATX...
System Manufacturer Gigabyte Technology Co., Ltd. System Model GA-MA790X-DS4 System Type X86-based PC Processor x86 Family 16 Model 2 Stepping 3 AuthenticAMD ~2712 Mhz Processor x86 Family 16 Model 2...
Hello my friend,this is could happen because of driver problem or and more common operating system failure.Try to reinstall the windows again but i recommend you to make a clean install (format hard drive and install the new windows)
Feb 06, 2010 | Gigabyte GA-MA790X-DS4 - Motherboard - ATX...
Having replaced my PSU, I now have a new problem. In games or scrolling in IE8, there is a loud buzzing noise coming from the CPU area. What could be done? I'm not sure if it's the CPU or the Northbridge,...
Electrostatic interference may also be the cause, for some reason, I'm not exactly sure of, there are PC's that emit this high-pitch squeal or noise when doing certain tasks on the PC, usually this can be tracked down to the sound system in the machine, but sometimes is not.
Also, some motherboards come with a safety feature that can cause the noise, it's called a voltage regulator, these can sometimes go bad, and while they may still function properly, the circuitry can emit these noises as over or under voltage is being rectified as it is passed through them. I have 3 servers here that used to do it untill i replaced the module, on a desktop motherboard, these are usually built into the motherboard circuitry and cannot be replaced.
Nov 02, 2009 | Gigabyte GA-MA790X-DS4 - Motherboard - ATX...
AMD Phenom II x4 920 processor works with a GA-MA790X-UD4P
Yes, that Gigabyte motherboard does support the Phenom II X4, for additional CPUs it supports check out the following website on the specifications tab:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387&Tpk=GA-MA790X-UD4P
Mar 12, 2009 | Gigabyte Computers & Internet
Intel Motherboard Logo
670 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
