Question about Kitchen Ranges
What is the difference in kw rating between a westinghouse 660 to a westinghouse pop663s
    Scholar:
  • 62 Answers
Just tried to look up the model # and couldnt find it. Usually the difference in kw rating , if there is a large difference , normally has to do with weather it is self cleaning model, how quickly the oven pre heats if it has a pre heat mode, how quickly the burners heat up and how hot they get. If you need more specific answers on those models please recheck model #'s and I will try finding them again and see what the difference is and why.
Posted on Nov 05, 2008
Can I use the existing 40 amp double pole breaker?
Rule of live by: Each unit must have its own breaker. Cooktop needs 30 amps and a double oven needs 40 amps. Never combine the unit as the amps flow if too high can cause the wires to melt. I hope this helps. Be safe!
Sep 13, 2012 | Thermador Ovens
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 20, 2011 | Garmin Nuvi 660 GPS Receiver
I just purchased a lasko model 5805 ceramic heater. What's the cost to operate.
look for the power rating of your heater (usually it is in Watts (W) and convert it to kilo Watts (kW) unit by diving it by 1000).
kW = W / 1000.
now divide the kW by hour many hours your planning to operate your unit.
power consumption = kW/operating hours
when you get your power consumption value then multiply it with the power cost (you can find it usually in your bill).
cost to operate = power consumption x power cost.
Happy New YEAR!!!!
don't forget to rate me...
Dec 31, 2010 | Lasko Ceramic Heater
I just bought the Westinghouse VR-4085DF and tried all the listed codes, but none worked. Any suggestions or other optional codes that may work?
Hello mwhinz, there are currently no codes set up for your TV, what you will need to do is call 1-800-701-0680 or send me a quick email to westytech@westinghousedigital.com to get the FW via email that will allow you to program your remote using different codes other than Westinghouse codes. Please make sure you include the model #, serial #, and TW # all located on the back of the TV. Please rate my answer if it was helpful.
Nov 26, 2010 | Westinghouse 16093 Remote Control
I am trying to find the KW rating of the HBL3550UC so that I can rough in the electric. They couldn't even tell me that info at the store. Thank you.
hi could not find kw rating but found it needs 30- 40 amp supply. it will tell you the kw on therating plate located around the door area.
Jul 23, 2010 | Bosch 300 Series HBL3550UC 30" Double...
Electricity bill coding in java
First think how you would solve this problem yourself on a piece of paper. Then try programming it using the things you learned (if they've given you this assignment without teaching you to multiply, subtract and use if's, drop the course).
Well here is an idea.
Take the total kilowattage and send it to a function. What the function will do is subtract 14KW from the total Kilowattage and add the amount for the first 14KW then subtract 85KW from the total KW and add the amount for the 85KW. But once you subtract the number of KW from the total make sure to check if the total KW isn't negative, if so just break out of the function and return the total due.
Or if you have formula for how much the rate grows over how many miles.
For example lets say the rate grows by $1 every time the KW doubles you could have something like
int rate = 1; //Begining rate
int KW = 14; //First flat rate
int amount; //total amount they have to pay
while(totalKW > 0)
totalKW -= KW; //subtract the first rate
if(totalKW <= 0) //check if too much subtracted
break; //if so break
amount += rate; //add the rate to the total
rate += 1; // Add $1 to the rate every time
KW *= 2; // KW is doubled
Jan 05, 2009 | Computers & Internet
Kitchenaid oven model #KEBC207
this was taken from the installation guide
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kebc207&siteCd=WHRCOM#installation_instructions
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Nov 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Difference in KW
.25Kw or 250 watts of cooking power.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 01, 2008 | Samsung MW5592W Microwave Oven
Kitchen Ranges Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
