Question about DBX -215 Home Equalizer
File in Outbox cannot delete or send
I have one file in my Outlook Express Outbox. I am assuming that it is corrupted. I have searched for and found Outbox.dbx and deleted it. However the file is still in my Outbox. When I go to my Outbox and click on anything, I get the famous hour glass. Any ideas?
  • Anonymous Mar 29, 2009
    I tried to send too many pictures at once and now cannot get any response from outlook express, cannot delete the email and only get the hourglass.
  • 26 Answers
>lets go store location
>open outlook express>tools>options>maintenance>store folder>Copy the location
>click start >run>paste the location >Click OK
>it would open up outlook express data file with .DBX extensions
>lets make sure outlook express closed
>lets rename the outbox.dbx to outbox.old
>lets reopen outlook express> but we will loose the outbox email
Posted on Apr 16, 2009
Not receiving or sending at start in outlook express
To fix this issue you can follow the
below mentioned workaround :
- Check your Internet and Outlook
Express account settings and double check that you have entered the
correct password and user name.
- Check your Firewall and Anti-virus
settings as sometimes this blocks the sending and receiving of
messages.
- Check if there is a corrupt
message stuck in your Outbox.
- A corrupt Outlook express dbx file
may also cause this issue so it is required to go for solution.
regards
jane
Jan 25, 2012 | Microsoft Update for Outlook Express 6.0...
In Outlook Express, it continues to send older messages each time you send an e-mail. It also does not include them in the Sent file. What can we do? I just ran a new version of Norton 360 2010. ...
delete the old failed messages out of the outbox.. delete ALL messages from the OUTBOX.. if they have failed previously or are too big they might sit there, then every time you go to send a new one or hit send/recieve to get new ones, it will try to send them again.
good luck
Sep 03, 2010 | Microsoft Outlook Express
Inbox corrupted in Outlook Express 6
if your inbox is coorupted its not possible to access your old e mails but there is a way to make your Outlook express workking
Make sure you close outlook express
You need to go to following location and delte outbox.dbx and inbox.dbx to outboxold.dbx and inboxold.dbx
Open Outlook express it will create new inbox and outbox
Dec 29, 2008 | DBX -215 Home Equalizer
I am unable to open Outlook Express 2003
What you need to do is go to 'my computer' then right click on 'C Drive' then click on 'Search'.
Look for a folder named 'identities' - it is hidden so don't forget to mark 'search for hidden files' as well.
It should find the identities folder under application data or something like that.
Anyhow, under identities youl find a string of letters and numbers (another folder), double click and get into it all the way to outlook express... under outlook express you should see all your outlook express folder (like inbox, sent items and outbox).
If the problem is with the outbox just delete it and rerun outlook express, it should recreate that folder.
Good luck.
Hopefully it was informative enough for you to rate my response,
Thank you for using agadycom.
Dec 12, 2008 | Microsoft Office Outlook 2003 for PC
Outbox - Outlook Express 6
Hello
I havent seen that problem with Outlook Express just with Microsoft Outlook. but this solution should work with outlook express to.
here how you solv it. you need to remove the outbox file manually. remember that all your outbox files gonna be deleted.
step by step.
1.close outlook express
2. go to C:\Documents and Settings\"your user name"\Local Settings\Application Data\Identities\("alot of numbers here.->"{7850C6E6-099E-4EFD-A3F5-A88CA4FC6169}\Microsoft\Outlook Express\
* if you can find Local settings you need to show hidden files!
a. go to tools>folder options->view-> mark show hidden files and folders-> ok
3.in the map outlook express delete the outbox.dbx or move it somewhere.
4. try now to start the outlook express and the outbox should be empty.
good luck.
Sep 04, 2008 | DBX -215 Home Equalizer
Outlook Express
Empty the Outbox in Outlook Express, move any messages you want to Send later to the Drafts folder.
Close Outlook Express.
Do a Search for .dbx files.
Search:
  • Start > Search > For Files or Folders > All files and folders,
    In the field for: all or part of the file name
    Key in:
    .dbx
    Below that, click on More advanced options
    in the field: Type of File, select (All Files and Folders)
    place a checkmark in:
  • Search system folders
  • Search hidden files and folders
  • Search subfolders
    click Search
Locate the Outbox.dbx file and Sent Items.dbx file and delete it.
Restart Outlook Express, a new Outbox.dbx file will be created.
Send yourself a Test message to see if it leaves the Outbox.
You may need to enable Show Hidden Files and Folders to see the .dbx files.
Windows XP:
  • Open My Computer,
    Tools > Folder Options > View tab,
    under Hidden Files and Folders, verify Show Hidden Files and Folders is selected.
    Remove the check mark for Hide Extensions for known file types.
    Apply, OK to save and close.
Jun 18, 2008 | Microsoft Office Outlook 2003 for PC
Outlook problems
Search:
    Key in:
    .dbx
  • Search subfolders
    click Search
Windows XP:
  • Open My Computer,
Email stuck in outbox
Here's the fix if when you send an email attachment from another application it gets stuck in the Outlook Outbox...
[HKEY_CURRENT_USER\Software\Microsoft\Office\Common\MailSettings]
"StrictAccountOrder"=dword:00000001
Tooks us a long time to come up with it but great to have! It's fixed in Outlook 2007.
Bill
www.IVDesk.com
Complete hosted IT solution where we run all your applications and provide 24x7 support!
Work from any Internet connection anywhere.
Outlook express outbox is stuck in 'sending' mode
More than likely, you'll need to delete the outbox.dbx file located in the following location:
C:\Documents and Settings\***you user name***\Local Settings\Application Data\Identities\{***LONG SET OF NUMBERS}\Microsoft\Outlook Express
You will find the outbox.dbx in that directory.. Delete it, and you're good to go!
Jun 13, 2008 | Computers & Internet
DBX -215 Home Equalizer Logo
412 people viewed this question
Top DBX Audio Players & Recorders Experts
Vito Vacirca Jr.
Themcramers
Level 1 Expert
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
