Question about Car Audio & Video
I really need ur hlp badley
Every time i hook up my rockwood PA2080 amplifier to my vehicle the red power light comes and stays on and then the green protection light is BUT nothing is coming out its not the radio i dont think i have checked that and yeah
  • 631 Answers
If the protection light is lit, the amplifier probably has shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect mode - Troubleshooting
Posted on Nov 05, 2008
Why my jl audio 1400d amplifier stays in protective mode?
Check for a speaker wire that come come of , Or a loose grond wire on the amp or where ever you have the ground wire connected two,
Oct 31, 2012 | Jl Audio Car Audio & Video
Xplod XM-554ZR Car Audio Amplifier: powr/protect light comes on red not green...
Hi, disconnect all speakers from unit and try again - if red light still shows then your amp has died.
If the light goes green, then start testing for shorted speaker/wiring. This includes speaker wiring to vehicle shorts - there should be an o/c reading on your meter
May 05, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Havin problem with a1200 class a/b amp it ligts green and red at same time after hooking in remote how doi fixdo i need diagram to fix
Make sure you don't have any shorts on your speaker wires or rca cables. Unplug one at a time, the turn on power until it stays green with no protect light, then you know what input is causing the short. If you remove all speaker wires and rca wires and all you have connected is the ground, power(12volts) and remote and it still lights up red/green(in protect mode) then your problem is the amp.
Mar 09, 2010 | Car Audio & Video
Green light (protection mode) on, NO red light (ready)
double check your wires aren't shorting out or power or remote wires aren't grounding. check if speakers are blown with nine volt battery
Sep 05, 2009 | Kenwood Car Audio & Video
Pyle dryver amp light protection stays on not green light stays red i have tried to disconnect everything and plug it back up but light stays red
check your subs disconnect them the try to power the amp up if it powers up the the subs have died and it could be a problem with that amp i suggest you get a better amp
Jul 09, 2009 | Pyle Dryver PLAD213 Car Audio Amplifier
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
Mar 23, 2009 | Sony NTX-2136 DHD 2Channel Car Amplifier...
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Mar 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
RED Port light on AMP?
are you sure its not PROT?
the amplifier is protecting itself from fire because of something.
Disconnect the subs. and turn on.
if it comes on normally, the subs are at fault and will need attention. If the light still stays on, you hafe probably blown an output on the amplifier and it will need repair.
Dec 24, 2008 | Sony XM-2200GTX Car Audio Amplifier
Red light
something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Rockford Fosgate P3002 Amp
what are the color of the lights that stay on.red= protect/ green=on.if the amp has little sound it probably still working,check deck output volume(rca)
Aug 22, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
350 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
