Question about KitchenAid Dishwashers
Older Kitchenaid Dishwasher door hinge
The left (as you're facing it) hinge on the door of our 15 yr old Kitchenaid has loosened, causing the door to droop and making it difficult to roll out the lower basket. The loosening is behind the vertical section where the hinge bracket is stored when the door is closed. (is that clear???) There's an oval plastic insert through which the bracket passes that's also loose.
Can this be repaired? Or should we get ready to send this great old workhorse to the glue factory?
Thank you
  • 3 more comments
  • justin24 Nov 05, 2008
    Replying to squishy 2, The KitchenAid dishwasher model is a "Superba." I can't seem to find a model number, but right under the interior Superba label there's a part number - (could be for the label!) In any case it's 9740651. Thanks for your help!
    Justin24
  • justin24 Nov 08, 2008
    to squishy2:
    Found the model number: KUDS220T3 F
    For the Kitchenaid dishwasher.
    One more question: How difficult is it to replace the door gasket? It hasn't failed, but it is getting old.
    Thanks,
    Justin24
    To Squishy2:
    Thanks for looking this up, but unfortunately I can't get to the page. The link you posted takes me to a sign in page, but I'm not registered there and there's no registration process available. Is the part I need still available anywhere? I'd hate to dump this machine just for a door hinge.
    I do appreciate your efforts, thanks,
    Justin24
    To Squishy2:
    OK, think I got it! Thank you for your help. I'll let you know how it goes after the parts arrive this week.
    Best,
    Justin24
  • Anonymous Mar 22, 2014
    Door hinge failure, second time on 3 year old fridge. Unable to close fridge.
    Sergeant:
  • 409 Answers
what you are describing is the door link. you can purchase the part and just replace them. they do get loose as they are just made out of plastic. if you can provide me with the model #, will give you the part # that you need.
Posted on Nov 05, 2008
  • 1 more comment
  • Carmen Mikulic Nov 06, 2008
    hi again,
    i can't come up with anything with that part #. the model # on the d/w should be on the inside rim of the tub but you will have to open the door. Superba is just the brand the mfg. uses to distribute their product. sorry but you will have to help me some more.
  • Carmen Mikulic Nov 08, 2008
    Hi Justin,
    I was able to find the exploded view for your dishwasher. Due to the age of the machine, it does not have door links. Back then, everything was mechanical. Follow this link for more information.
    Also, to replace the gasket should be quite easy. This exploded view will show you the details.
    http://reliableparts.infoaccessipl.com/d...
    Hope this helps.
    hi there,
    strange, i go that too just now. i tested the link before i posted it and it worked.
    yes, the hinge should be available at www.reliableparts.com
    part # for the lh door stop bracket is 4161592
    part # for the door stop insert is 4160355
    if you go to the above website, you can look up the diagram yourself. scroll to the bottom of the page and on the left-hand side you will see a window asking for a make and model # off your appliance. type in kuds220t3 and the brand name is kitchenaid and the site will display the exploded view for you.
    i hope this helps.
How-to I replace facing on older whirlpool dishwasher
  • 1. Place your hands at each end of the retainer trim piece that runs along the bottom of the dishwasher door panel. The piece may be metal, black plastic or another color, depending on your dishwasher model. Lift up on the retainer section and pull it toward you to remove it. Set the retainer aside.
  • 2. Press the palms of both hands on the old facing and slide it down until the top is free. The facing flexes easily to allow you to slip it out from under the trim along each side.
  • 3. Hold the replacement door panel, or reverse the old one, so that the desired color is facing you. Turn the panel, if needed, so the dimensions line up with the dishwasher door.
  • 4. Slip the side of the facing into the left side of the frame on the dishwasher door.
  • 5. Secure the other side of the facing into the right side of the dishwasher frame by bowing the panel gently and sliding it into the frame.
  • 6. Slide the new facing up and into place so you can reposition the retainer.
  • 7.Hold the new color panel and the spacer behind it up over the lower edge of the frame about 1/4 inch.
    8. Snap the retainer into place. Push down on the horizontal piece gently to ensure it is securely connected.
  • 9. Adjust the new panel down a bit with the palms of your hands to cover the 1/4-inch space.
Oct 19, 2014 | Whirlpool Dishwashers
15 yr old kitchenaid dishwasher leaving white steam marks on wood floor
Check your seals around the door, if that is where the steam marks are coming from. Rubber can easily be replaced
Mar 04, 2014 | KitchenAid Dishwashers
Can't get the door back on
Instructions
Open the door to the dryer and remove the screws in the hinge. Lay a towel on top of the dryer. Place the dryer door on the towel with the inside facing up.
Remove the screws from the inside of the dryer door. Disassemble the dryer door carefully, removing the cover on the right side of the innermost section of the door and the shield and hinge from the left side of the innermost section. Reattach the side cover to the left side of the innermost part of the door. Install the new shield to the right side of the door section, with the flat side against the door and the notches facing up (they will face into the dryer). Attach the hinge on the same side as the shield.
Set the top section aside. Rotate the remainder of the door 180 degrees so that the handle is on the left of the upside down door. Check that the latch aligns with the cover before screwing the door back together. Screw the hinge into the corresponding holes on the left side of the dryer door frame. Remove any stickers that might be blocking the holes.
Check the alignment of the door by opening and closing it several times. Loosen the screws on the hinge and nudge the door slightly until the fit is correct. Tighten the screws into place.
Jan 09, 2013 | Dryers
Dishwasher leaking
This sounds like a hinge problem to start with.
Test the seal by dragging a strip of paper through it with door closed. Probably that left hinge isn't holding door close enough which was probably the original cause. As seal dries out a bit then will leak.
At this point I would investigate the hinge possibility AND if possible a DIY fix. It may be loose mounting screws or take a little shim to hold the left corner tighter. I would not waste money for a service call.
You probably might need to release the door balance springs accessable under the toe kick area while working on the door. Possibly a hinge is bent.
You might do as they do in the auto industry when a door doesn't fit... basically put forces on it to bend it a bit. In your case it would be to distribute the load and support the door when horizontal about 6 inches out from the left hinge and then bend the end of the door down to bend the hinge mounts slightly..
Then check the seal clearance with the strip of paper as you do with a refigerator seal by cloosing on a strip of paper and dragging the strip to see if it is gripped.
May 13, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
Top door drags on the side just before it closes
sometimes these dooors tend to sag, the hinges cant take as much as the manufacturer claimes,
you can loosen the top hing screws,,,
JUST LOOSEN DO NOT REMOVE
with the upper hing loose you should be able to left the door slightly on the corner it drags, ther ewont be much room but you should get enough play to allow the door to close properly
once lifted tighten in place
might need a hand
Oct 10, 2009 | KitchenAid KBRC36FMS Bottom Freezer...
Leaking door on Bosch dishwasher
I DONT THINK THERE IS A ASSEMBLY MANUAL BUT THE DOOR HINGES IS LOCATED UNDER THE LEFT AND RIGHT SIDE OF THE MACHINE. YOU HAVE TO CHECK THE HINGE PULLEY THEN CHECK THE LOCK.
Sep 23, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Kitchenaid DW door spring
The door hinges are spring-loaded. One or both hinges have failed.
Items 2 and 3 at the link below are the parts that are needed.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5135727
I am not aware of a service manual posted on the internet.
Hope this helps! Please post back with what you end up doing, OK?
Good Luck!
Feb 10, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Oct 07, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Door won't latch
replace the door latch part number 8193830 it will fixya
Sep 23, 2007 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwashers Logo
261 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
