I purchased a new laptop, the usb hub cord is not long enough to reach my usb slots on the laptop so I purchased a usb extension cord 3' from radioshack, but when I use it vista says it does not recognize and cannot install, when I plug the usb direct into the laptop everything works. any suggestions?
  • charitmnacho Nov 05, 2008
    I checked the ext cord I am trying to use and it says it is 2.0 usb. I have also found that my computer will not fully shutdown when I have a usb extension cord plugged in. I will sit on the screen that says shutting down until I manually shut it down, any other suggestions? I think I am just going to have to buy a new hub that comes with a longer cord.
  • 4,338 Answers
You may need a 2.0 USB cable. Read on:
The cables will most definitely look the same. That's because the connectors didn't change between USB 1.1 and 2.0.
But not all cables that look the same are the same.
A higher quality 1.1 cable stands a better chance of working at 2.0 speeds. What do I mean by quality? Well, it's nothing that's visible, I'm afraid. It has to do with the quality of the wires used and especially the shielding against electrical interference. Higher speeds are more susceptible to interference and noise - either from the outside, or from the USB signals themselves.
I also say in "typical" usage, because not all scenarios are the same either. For example a short cable is more likely to work than a long one. If you have an electrically noisy environment that might cause problems.
And of course the devices themselves play a big role. Some devices are more tolerant of weak or noisy signals than other. Purchase a 2.0 USB cable, it is not expensive.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 05, 2008
Need an extension power cord for the TG5632
You can get up to a 25ft silver satin line cord for phone, or even an extensine cord. Or contact the manufactor about a longer cord.
Feb 05, 2014 | Panasonic KX-TG5632 Phone
Hi also own a acer aspire 5516 and both usb slots are unoperable when i try to attach usb cables into the slots it won't go in. It's like the little piece that sticks out has fallen down. please...
Welcome to Fixya.
Seems like you're having some serious hardware issues with the USB ports. Before I go on, you have to know and understand that all USB ports in your laptop is connected to the mainboard (motherboard) and there are no ways developed (yet) to repair/replace a USB port without replacing the entire board itself. With this, I am highly recommending for you to purchase a USB Hub - where you only need 1 USB slot from your computer as this device carries multiple (up to 16!) USB ports with it. It can be purchased from any local computer/electronic boutiques near you and it looks something like this :
Common price ranges from $30 to $50 (depending on model and number of slots). If however, you choose to have the board replaced, then we are looking for around $300 - $400 for the labor and parts.
Here's acer's support site if you wish to know more details about replacement options :
Acer Support
Thanks for using Fixya.
May 12, 2011 | Acer Aspire 5500 5570-2609 Laptop
Tell me the steps to install my magic jack to my laptop
When you receive your package in the mail, open it up and you will have three items: the USB plug-in device, a short USB extension cord and a telephone cord. Follow these steps for you to be able to install magic jack on your laptop.
1. Plug the device into your computer's USB port and it will automatically start downloading and installing some software that you need to be able to make calls.If the device doesn't fit in the area where your USB port is on your computer, then you can use the extension cord that was included in your package to hook up the device.
2. Another option is to use an a/c powered USB hub to plug it into. Using an a/c powered USB hub is recommended over using the extension cord, as it will save you from having some problems in the future.
3. You will also be able to visit the official website for this voip phone if you are having problems getting it to work all of the time. There are downloads available that are called "magic fixes" that will help the device work better with your computer.
4. Now all you need to do is to plug in any regular land line type phone into the device. The phone line that came with the device is best to use as it is recommended not to use a phone cord that is over 6 feet long. This is all it takes to install Magic Jack so you can start making free long distance calls.
Hope this will help...Thank you for using Fixya...
Feb 25, 2011 | Computers & Internet
Some of my peripherals, trackball inc. want to be connected to the netbook instead of settling for my hub. What do I HAVE to connect to the computer among CD drive, hard drive, printer, keyboard,...
Most likely your USB hub is not capable of supplying enough power to support all your peripheral devices. USB devices are powered by 5 volts from the USB port. If you connect a hub to a USB port and connect a lot of devices to the hub, there is not enough 5 volt power to let all devices work. To fix this, most USB hubs have an external power option that when plugged in will supply extra power for any connected devices.
If your hub does not have an external power option I would suggest you purchase a new hub that does have an external power supply.
Good luck :)
Jan 25, 2011 | ASUS Eee 4G Notebook
When I attempt to download photos onto my laptop I either get a message saying the USB hub cannot take the power level required or there is no recognition at all. Any suggestions?
You might want to consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 20, 2011 | Vivitar ViviCam 8400 Digital Camera
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Computers & Internet
Logitech Alto Connect 3-Port USB Hub
There is a port for the a/c adapter on the bottom side where the USB ports are.
Looks like its supposed to come w/ an A/C power cord
See package contents
U can purchase a universal power adapter from Radio Shack if needed.
Jun 05, 2009 | Logitech Alto Connect 3-Port USB Hub
Netgear wireless adapter disconnects from router randomly
check for firmware update for your adapter...since it usb..u need to put it in open..i believed the USB extension is included when u purchased that.
do not connect the USB adapter to a USB hub unless the HUB is powered so that it can performed better. Connect it directly to your PC slot
Mar 13, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Battery on Sony Walkman NWZ-E436F
ok, just tried something with maybe a solution....
I was connected via an usb hub to my laptop, then it said battery is full, it apparently didn't charge.
When i connect my usb cable directly to my laptop it started to charge again!!.
My usb hub is not connected to a adapter so all power comes from the USB port, this may be not strong enough to charge your walkman.
Try this (so directly connect to your desk / laptop) it may work!
regards
me
Jan 02, 2009 | Audio Players & Recorders
Usb cable for delstar mp4 degital player
The cable plug is called Hirose. Specifically a mini-B 4pin Hirose, BUT-- there is a single slot as well as a double slot. You need the double.
640dab4.jpg If you find one and can't tell from the pics or description, ask the vendor.
Here are a few links though I haven't purchased myself.
http://foliumcei.com/usbadapteramaletohiroseminib4pmale.aspx 99 CENTS!!!!!!!!!!!!!!!!!!!!!!!
http://www.powersonic.ca/usb20-cable-mini-hirosemini-p-3714.html?osCsid=38c68f6d5fdb33d77b04d6c43004c103
http://www.revealcable.co.uk/acatalog/Camcorder.html
http://www.ebuyer.com/product/95792
http://www.ebuyer.com/product/95797
http://stores.channeladvisor.com/cablestar/Items/hiroseusbzz?sck=73192081&caSKU=hiroseusbzz&caTitle=USB2%204%20Pin%20HiRose%20MP3%20Digital%20Camera%20Cable%201.8m%20Lead
So I guess you lost your AC charger as well. I recently purchased a cool USB charger at Dollar Tree. They also have various cords including USB A to A extension in case you only purchase a Hirose adapter. Good luck.
Sep 01, 2008 | Delstar DS-802 Digital Media Player
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
