Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Intuitive washer code 43
I am constantly getting an error code 43 and the machine stops and starts. I have been told that this is a bowl out of balance warning but it has happened over a year ago and then was ok. Happened again 2 weeks ago then rectified but now its acting up like basil faultys mini. I,ll get the Birch out to it soon! can anyone help? Thanks.
  • Anonymous Dec 03, 2008
    That was brilliant advice. My intuitive just had the same drama, i fiddled around with the bowl a bit and in the top right corner I noticed the switch between the top of the bowl and the console. I flicked the switch a few times, ( could hear it clicking) and now shes back in business!!!
    Now at least I'll have clean socks in the morning!! ;-)
Thx to fixya l sovled my code 43 by removing and cleaning my balance control switch. If anyone needs to know here step by step
1 Make sure the plug is out ( dont want curly hair do you )
2 Remove 2 screws from back of control panel and lift off
3 Remove 1 screw holding grey module panel
4 Under grey module on right hand side is the balance control switch with 1 white and 1 yellow set of wires
5 remove wires ( make note on where they plug back into )
6 2 small clips hold the switch in place, open them gently and pull switch out
Its that simple , clean the contacts with some wd40 or bicarb soda in hot water to get rid of any corrosion, make sure that the little button on the side springs out freely ( tiny drop of oil/wd40 ) clean or replace plugs on the white / yellow wires. install and do that washing!!! It worked for me but if the switch is too far gone no need for a service man just get a new one and go for it .
Good luck Pieman
Posted on Jul 01, 2009
  • webb1975 Jan 08, 2011
    thank you so much for your solution - the little button on my switch was stuck and with a few clicks - bingo it works again! I can't imagine how much money you saved me! my MW059AU machine is better again!
Hi Washer, I had a similar problem and rang the F&P service line. They gave me the solution and my machine now works perfectly. You're right, it's an 'out of balance' error message. To fix: Turn off machine and unplug the power cord. Open the lid. Move the bowl forward and backwards, then side to side a few times. Also diagonally back and forth. Turn machine on and try again. Apparently there's a small 'sensor stick' under the bowl which sometimes gets stuck. By moving the bowl back and forth you're rebalancing this, and machine should be fine again.
Posted on Feb 12, 2007
  • lisaobie Aug 27, 2011
    thankyou so much fixed the problem straight away !! :)
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Thanks everyone i shook the living daylights out of the machine last week and this week code 43 happened again i very bravely real all the advice and with a screw driver in hand dismantled the control panel not neally as scary as i thought it would be i located the switch cleaned it up reinstalled it and bobs your uncle finished my washing
Posted on Apr 18, 2011
Hey Gitte
I had trouble with my washing machine and tryed your advise on moving the bowl backwards and forwards and left to right and it works perfectly. Thanks for saving me some money.
Posted on Aug 12, 2008
  • yekaw Apr 13, 2011
    just had the same problem live100km from nearest service centre shook the **** out of the bowl more fustration with the load of wet washing than anything closed the lid power on works like a gem once again thank you
I had same problem had to replace the hall effect sensor switch ... just looks like a limit switch with an arm coming down off it touching the bowl and it senses if its not centered or too much weight in machine
Posted on Jan 23, 2008
I had this last month and i had to replace the out of balance switch. now she is running nicely again.
Posted on Jul 28, 2007
SOURCE:
What is error code 43 on Fisher & Paykel Intuitive Eco ModelIW810AU
usually out of balance switch . if load not oob,switch is in top deck under controller .Back right hand corner,it is microswitch ,with toggle hanging down behind bowl.
May 15, 2014 | Fisher and Paykel GWL11 Top Load Washer
Error code 43 on intuitive top loader
hello click this link for error code 43 this is an out of balace error and this link will tell how to fix as well http://applianceguru.com/forum2/3397.html if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 01, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine stopped filling up and an error 43 or 43 came up on screen
Hi just read your posting.Now Error code 43 means you have an OUT OF BALANCE SWITCH FAULT.The switch is located under the control module which is located under the top panel.Would you like me to guide you throe the testing and possible replacement of the Switch?The secondary source of this error code is your Motor Controller.But we must test the switch 1st as the switch is the most likely component that is faulty.Have you or can you borrow an electrical test meter to test the switch.It would make it easier to test the switch with the tester but there are ways around this.Please reply for further assistance and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 43
Error code 43 indicates that the washer is 'out of balance' . The switch is under the motor controller board. This is accessed by removing the 2 screws at rear of facia and exposing the motor board which is attached to the hob. The micro switch might be probably the faulty one. When replacing the switch make sure it's the same as the one coming off as they can be opposite function. Sometimes the oob arm below the oob switch can get jammed over the edge of the bowl and result in the same fault.
Thank you !!
Jun 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
Have an eco washer gwl 10. worked fine for years today stopped wokring. tried all trouble shooting and diagnostics. always coming up error code 43. replaced switch and no different. any idea?
Hi there
Try bridging the switch out(join the wires together) and if that doesnt work you may have to replace your motor controller module.
I hope this helps.
Nick
Aug 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washer what is a code 43 please
code for out of balance oob switch probably needs replacing if load wasn't off to one side.
Jun 20, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
Jun 09, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
May 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
1,095 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
