Question about Canon MP520 All-In-One InkJet Photo Printer
Blank LCD display screen
LCD display screen intermittently has no display. What is the cause and the solution
  • 2 more comments
  • Anonymous Mar 08, 2009
    I have the same problem. Intermittent display on the LCD. I took the side panel off the printer and discovered it was a fault inside the ribbon cable connecting the LCD to the printer, probably caused by bending the cable each time the LCD panel is raised and lowered. The cable is built into the LCD unit, so does not appear to be possible to replace the cable. Looks like a design fault.
  • cece7652 Apr 05, 2009
    Hi - I'am having the same problem - it just started a few days ago - how did you remove the side panel and were you able to fix the issue? pls contact me at cece7652@hotmail.com
    Thank you -
  • Anonymous Apr 24, 2009
    because of suddne city blackout, now the lcd, is only blank white
  • Anonymous May 05, 2009
    openb the lid cover by lift it and push it forward, lift the black attachment where the ribbon cable ends, and re attached the cable, for the back lid cover, near the intersection of front lid, lift it and push it backward, the green cable attachment can be lift it also, good luck, mine already worn out the cable .. so it cant be done by this fix
  • 421 Answers
You need to check firstly that the LCD connections are still connected correctly inside the printer and then you can enter service mode on the printer and run an LCD test. To open printer and run test you will need a service manual:
http://www.tradebit.com/filedetail.php/4981053-canon-pixma-mp520-printer-service-manual
Posted on Dec 05, 2008
  • 36 Answers
Here is the solution
http://sites.google.com/site/bricolagesetc/home/my-experience-guide-repairing-pixma
Thanks to Berurier he gave us this trick from MP520
Posted on Sep 11, 2010
What do I need to do to fix a blank screen on a whirlpool built in oven?
Often the Whirlpool built in ovens have a control board failure which causes the screen to go blank. May be intermittent and may be accompanied by an E6 F2 failure code on the display (before it blanks out). We rebuild a lot of control boards for this problem. For example see:
http://www.fixyourboard.com/boards/8302967.html
Mar 18, 2015 | Whirlpool Ovens
Lcd display only works flat against camera
The ribbon wire from the display to the system board has cracked causing intermittent operation when moved. Depending on the wire configuration to the screen will decide if the screen must be replaced or the ribbon wire.
Apr 02, 2012 | Video Cameras
My screen intermittently goes blank (without lighting). I can see that there is something displayed and a connection to an external monitor shows that everything is working fine. I've disassembled the...
I've seen this problem time and time again. Replacing the inverter fixed it every time. HOWEVER it could always be the CCFL backlight as well. Both fortunately are VERY inexpensive. Changing the inverter is easy but the CCFL will be a little harder. Take your time and remember how to put it all back together and you'll save that $100. I'm sure it's either of those two that's causing the backlight issues. NO NEED to change the entire LCD.
Aug 22, 2011 | Acer TRAVELMATE 8371-944G25 LAPTOP LCD...
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | Cell Phones
Screen went blank
cslkkent, Your description of problem fits the common "black" or "blank n black" lcd screen symptom. Because 98 percent of all desktop cold cathode fluorescent lamp back-lit lcd monitors use the same basic lighting technology, it will be in your best interest to view some video clips of CCFL back-lit lcd monitor repair on YOUTUBE just for info on typical causes of black or blank n black screen symptoms and how some owners do repair on the cheap! Yes, your unit may have BAD capacitors on the power supply printed circuit board or one "thermally intermittant" component solder joint which will need to be resoldered. Just do some research first. Read fixya profiles of "buddymc" , "budmrtn" and my own files. Good luck on your quest. 12fixlouie
Jun 09, 2010 | LG Flatron L1919S LCD Monitor
Screen is completely blank, cant access anything.
Good day sir/ma'am, the problem with your phone sound can be that the driver speaker(earpiece) is defective or it may opened wiring/unsoldered to the driver. also check the volume or mute. 2. the display problem may be caused by intermittent contact problem or the display lcd is lose. you may have to dismantle it and look for these things and fix it. Hate to say it but you may need to bring it to a cellphone technician. Hope this may help. thanks
Jul 16, 2009 | Nokia e65 Cellular Phone
Sony Laptop PCG-F450 Display
Usually it is the lcd inverter going bad...if you do a search for your model # and lcd inverter and see if you can find any...also you will be able to very faintly see what is on the screen althought it looks black...if that doesn't work then i may be the backlight in the lcd and a new screen may be needed.
Hope this helps
Jan 09, 2009 | Computers & Internet
I have Canon EOS 300D digital Rebel. I have had intermittent problem with the camera display screen going blank even though I put a freshly charged battery in. Usually I can take a couple pictures then the...
Strange, intermittent problems with the EOS Digital Rebels can be caused by a defective shutter release switch. We charge about $85 to replace it.
Nov 12, 2008 | Canon Cameras
Mag lcd question
Hey CBernard84,
While a blank screen could be caused by a controller, it could also be caused by something simple like the settings on the controller.
Question: When you boot up, does the screen show the Power On Self Test then go blank? If yes, the screen refresh rate is most likely set too high.
Comment me back, if this is the case. I can walk you through the procedure.
Hope this helps,
Mike
Oct 06, 2008 | Computers & Internet
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
Canon MP520 All-In-One InkJet Photo Printer Logo
2,543 people viewed this question
old marine
old marine
