Question about Cameras
Sony trv38 camcorder does not record. when turned on to camera mode, the scree is black
    Sergeant:
    Novelist:
  • 196 Answers
Go to their website (esupport.sony.com/perl/news-item.pl?mdl=DCRTRV19&news_id=95). They list the problem and give a toll free number to call. If they put you on hold too long, call them back and DON'T take no for an answer.
Posted on Nov 05, 2008
  • mmechanics Nov 05, 2008
    My TRV38 had the same problem a couple of months ago and I called Sony customer service as recommended in the forum. I described the symptoms and some of the steps taken such as resetting and operating it with a fully charged battery to try to resolve the problem. The service rep. was quick to provide the return label so I can ship my camcorder to their repair center. I just got it back two days ago and it is working fine again. Sony covered the repair and all the shipping cost. The whole process took about 2 weeks so I am satified with the outcome. I would definitely call them if anyone has the same ccd problem.
My computer doesn't recognize the camera, however, it does recognize another sony camcorder that I plug in but not y DCR-TRV38
Well the problem occurs to to driver, so first of all you can try to install driver of your camcorder into computer, you can follow the below link to download the driver -
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=37
(Post comments if further you have the same problem)
Good Luck!!
Thanks for using FixYa!!
Jul 06, 2010 | Sony Handycam DCR-TRV38 Mini DV Digital...
Hi my sony dcr-hc18e camcorder plays back but doesnt record
Unfortunately you're going to need to get some repairs done to your device, the reasoning behind the black screen on recording mode is that one of the many pieces responsible for bringing the image from start to finish has become mis-aligned.
It's either going to be the CCD sensor that has shifted or one of the lenses is slightly off angle and is sending the image off into a wall on the inside of the camcorder.
Estimated repair cost is going to be in the range of $200 USD.
Best of luck with this!
Dec 09, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
No picture when trying to record
Check the following link. Call them and explain the symptoms and they should send shipping label to you so you can send the camcorder in for repair. I had my TRV38 repaired in about 2 weeks. Good luck.
this is a known issue with Sony
Apr 20, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Picture Image Becomes Blury When Recording
i had the same problem i just gave the camera a good smack and it was all good. lol
Apr 19, 2009 | Sony Handycam DCR-TRV38 Mini DV Digital...
No picture seen or recorded - only audio
I had a similar problem with my Sony 14E in that it would not record at all - sound or pictures. Prior to that I had the lines indicating head cleaning necessary. I did this, and still nothing. I then did the following which you might try.
1. Clean the heads (I did it about 3 times in the space of a couple of hours).
2. Leave the camera tape section open (with or without the tape in) for a couple of hours and the camera in a WARM PLACE. I had condensation message prior to my problems too.
3. Put in a recorded tape and attempt to view it. Immediately I had the "dirty" lines for a few seconds then it played the recording.
AT THAT STAGE I TRIED TO RECORD - NOTHING.
Repeat Steps 1 - 3 because this seems to be about dirt and cold.
4. When step 3 is reached again! try to record. Eventually this worked for me.
I hope this helps and works for you.
Jan 03, 2009 | Sony Handycam DCR-TRV38 Mini DV Digital...
Sony camcorder DCR 265E
i think you are in picture mode when the screen mode is changed then it will appear black and recording cannot be done beeing in that mode you have to change the screen mode into recording mode and then continue
May 25, 2008 | E.Digital Sony DCR-TRV265E camcorder Pal
Audio problem in our Sony TRV38 handycam..Please help!
I am not sure if you can use an external microphone on that model (check your owners manual) but that would be the first thing to try. If it records OK using an external mike, then the problem is with the internal microphone.
Mar 17, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
Sony DCR TRV38
Good Day, you need to supply 4.5V DC regulated to the loading motor, however you should disconnect the connector from main board to loading motor, in order not to damage the driver IC. If your technically inclined, and you have the equipment, do it, if your not sure, just refer it to the nearest svc ctr. thanks
Sep 04, 2007 | Sony Handycam DCR-TRV38 Mini DV Digital...
Unable to play Audio after Video Capture
I happen to have this setup... you need to set the audio source (the usb camera connection.) It is possible to hook up via the sound card, but that could be stressful for some.
Sep 14, 2005 | Sony Handycam DCR-TRV38 Mini DV Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
