Question about Microwave Ovens
Microwave beeps for no reason. Panasonic NN-8501V
Microwave beeps for no reason, I think a button on the touch pad is making contact, may be a worn Touch Pad.
  • 528 Answers
The touch pad need to be replace, it is not so cheap but if you want to fix it you can order the panel and do it yourself just make sure the unit is off and the capacitor is grounded.
good luck
Posted on Jan 20, 2010
  • Microwave Ovens Master
  • 8,973 Answers
There may be an F type fault code on the display, or the display may reflect that a key has been pressed when it has not.
If you can supply more details along those lines, that can help in the diagnosis.
The rest of the answer assumes you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Or you can find an authorized Panasonic servicer here.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 08, 2008
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Panosonic Microwave convection Model NN-8501V Touchpad appears dead
The unit has a fuse in the power board, but when the fuse is gone it does not even start up. If it starts it is not the fuse.
Look rather a problem with a faulty touchpad, or the magnetron that is not working and need to be changed.
Check also the door sensor.
Oct 03, 2008 | Microwave Ovens
PANASONIC Microwave Inverter #NN-SD697S. Everything works except the START button. Works sometimes, and not other times. Checked outlet, all was good.
This is either the door sensing switch (most likely) or a bad membrane switch [start switch] (that's what Panasonic calls it) on the touch pad. The contacts on the door sensing switch can be slightly contaminated and not read "zero ohms" to the control PCB. The control board thinks that the door is open and it will not allow the cook cycle to start.
Sep 11, 2013 | Panasonic NN-S251 Microwave Oven
NN 8501V Panasonic Dimension 4 Convection/Microwave oven keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
Apr 16, 2013 | Microwave Ovens
I got this microwave in my house, but its not working. all the buttons are not working accept stop/cancel button. please send me the sollution.
I have a similar microwave that I recently repaired. NN-9854 (bad capacitor). So your microwave functions but you cant stop it unless you unplug it, it ends its cycle, or you open the door? Does it beep when pressed? If not, you need a new control pad.
Dec 19, 2009 | Panasonic NN-T888S Convection/Microwave...
I have the same problem with Panasonic NN-8501V Microwave Oven
I took the touch pad control unit apart, clean the connector for the ribbon wire connection between the key pad and the control unit, reseated the ribbon wire in the connection. Everything worked like new.
Oct 16, 2009 | Panasonic Microwave Ovens
Buttons on number pad dont work , except one
HI, the key pad or, touch pad is defective. you will need to replace it asap if possible.
These key pads run about 130 dollars tops. contact Panasonic for this part.
Jun 21, 2009 | Panasonic NN-S433 1100 Watts Microwave...
RV Microwave/Convection by Panosonic Model NN-8501V, touch controls go crazy when cold, indicating the AUTO DEF button is in continuous contact. CLEAR/STOP only works for a second and then AUTO DEF starts...
I tried looking up the part number for this model and they don't identify clearly what the touch pad is. Would have to get one of the parts companys (andrewselectronics.com) to do research on it.
I've done surgery on a few touch panels and it usually works out. Have to break through the plastic tabs holding it together, then you can clean the contacts. Then do something like find little tiny screws to fasten it back together.
Hope Ya Fix It!
Jan 24, 2008 | Microwave Ovens
Touch pad went dead
your Display board will need to be replaced
Jan 23, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic NN-8501V Convection beeps on AUTO DEFROST when cold
I'm replying privately with complete details.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 13, 2008 | Microwave Ovens
Microwave Ovens Logo
201 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
