Question about Dell Dimension 2400 PC Desktop
Lsass.exe error insufficient system resources exist to complete the API. what can i do to fix that. thanks I have the same problem in Windows XP but can not get past the error message. It will not start.
  • 1 more comment
  • 4Tweety Nov 05, 2008
    Thank you Sweetyanne! I had done exactly what you said before I got your answer, but you were exactly right!
  • rtaz74 May 24, 2009
    Insufficient system resouces exit to complete the API.
    loading XP pro. tried three other hard drives,cables,and bios sees memory and all drives. can anyone help me how to fix this issue.
    rob
    rtaz74@yahoo.com
  • 68 Answers
Try to boot to the safe mode, when use the splash screen of your system press f8, you will be able to choose there safe mode or safe mode with networking. Make sure that there is no virus or spyware.
Check in Task Manager and see how much physical memory is being used.
Then check your PF Usage, the problem may be a lack of virtual memory.
Go to System Properties > Advanced and under Performance Options click Settings. Then click on the Advanced tab and click Change under Virutal Memory.
-Click Custom size and set the Initial size to 384MB and Maximum to 768MB.
Then try to reboot and then defrag,reboot again.
Posted on Nov 05, 2008
  • sweetyanne
    sweetyanne Nov 05, 2008
    Thank you so much as well..
  • bamdad
    bamdad Oct 19, 2013
    thanks , it was helpfull
  • Dell Master
  • 4,338 Answers
The first thing I would look at is a memory problem. Go to CMOS and see if the PC is showing the correct amount of memory. If your PC has more than one memory module, I would take one out and boot the PC, if it start, then it is that module. If it doesn't start, try the other memory module.
Make sure you power off the computer each time before you remove the memory.
If and when you are able to start the PC, go to msconfig and see what you have loading in start up. I would remove anything that is not needed at start up.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
    New Friend:
Thanks alot friends ,
I start windows in safe mode and decrease virtual memory and restart , then problem fixed.
I had a big File on desktop that get a lot of space of Drive C,
Posted on Oct 19, 2013
I solved this problem by simply boot my laptop in safe mode and transfer some data from C drive to other drives. After this i reboot my computer so it didnt give the Lsass error and started normally.
Posted on Mar 11, 2011
2 Suggested Answers
  • 19 Answers
SOURCE: lsass.exe system error insufficient system resources exist to com
You probably have been hit by a virus that is attacking your Local Security Accounts Windows file and is using all your system resources. You may not be able to perform a system scan to fix this issue do to the lack of system resources. Now if you have another pc with a good and upto date antivirus application you can take the hard drive out of your computer and plug it into that other computer and scan it and remove the infection and while you have it in their go to the command prompt and repair the windows files by typing:
chkdsk E: /r
The E: is the drive letter of your infected drive you will know what this is when you go into my computer.
Also use a spyware program like Adaware that is up to date to scan the drive as well.
This all assumes you want to save the drive, Windows, and all your applications. Now if you don't care about those things then try a system restore to go back to a working point in your computers history.
Otherwise repair mode for windows will work also.
Posted on Sep 24, 2009
Lsass.exe error insufficient system resources exist to complete the api how to problem solve
Remove the Cmos battery and reset the Bios. Then if it isn't already, flash the bios to the latest version.
You can get the latest Bios here:
http://www.msi.com/product/mb/845E%20Max.html#/?div=BIOS
Aug 23, 2012 | MSI P4 Mainboard Intel 845E Chipset Based...
Lsass.exe Insufficient resources to complete API
In safe mode it does the same reboot reboot thing? Computer messages are not really reliable as far as fault tracing is concerned. The message given is a close as the PC can come to the right one.It sound as though there is a problem reading the hard drive. Try booting from a bootable CDor flash drive if you don't have a floppy drive, and see it if does the same.Can you get into the BIOS setup by pressing delete on bootup?
Apr 20, 2010 | Computers & Internet
I use outlook express.it creates trouble today. i restarted my pc. then a notice showing " insufficient system resources exist in API" & i cant log i n my windows. when click ok Or close into it then...
hi dear
Insufficient system resources exist to complete the API
download update for windows xp (KB909095) and install it
http://www.microsoft.com/downloads/details.aspx?familyid=9D20F96A-A8D6-4627-89F7-787CD9B3852C&displaylang=en
if you do not able to install the fix
then boot your system with one boot cd and replace your page file with another one
Apr 02, 2010 | Computers & Internet
Lsass.exe system error insufficient system resources exist to com
chkdsk E: /r
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Insufficient system resources exist to complete API
Install Win XP KB909095 and increase the size of page file
May 11, 2009 | Toshiba V3100 PC Desktop
Insufficient system resources exist to complete the api
The computer occasionally does not hibernate and you receive an “Insufficient System Resources Exist to Complete the API” error message in Windows XP with Service Pack 2, in Windows XP Tablet PC Edition 2005, or in Windows XP Media Center Edition 2005. Apparently, the problem is caused by the fact that the Windows kernel power manager doesn’t manage to find a block of contiguous memory to hibernate. This happens occasionally on laptops with 2Gb of RAM. It can be quite annoying when you put your laptop to sleep, pop it in your haversack, then some time later find a discharged battery and a VERY HOT laptop bag , it’s nice that they solved the problem, HOWEVER, you can’t actually download the hotfix, but have to contact Product Support Services for it. I’m not sure if there’s a fee to be paid for it, so I just Googled the hotfix and found a copy elsewhere.
Here’s a copy if anyone wants it: Download here: http://www.u-g-h.com/content/binary/WindowsXP-KB909095-x86-ENU.exe
Nov 27, 2008 | Computers & Internet
Error Message : insufficient system resources exist to complete the API
boot your system in safe mode by pressing f8 key repeatedly during the booting process then select safe mode and press enter then go to system restore option, and select system restore, then select some previous date where system is working fine, restore it
how do you like the solution please rate it
Oct 12, 2008 | Acer Aspire 3680 Laptop
how to remove ISASS.EXE SYSTAM ERROR INSUFFICIENT SYSTEM RESOURCES EXIST TO COMPLETE THE API
May 28, 2008 | Apple MacBook Pro PC Notebook
Dell Dimension 2400 PC Desktop Logo
3,967 people viewed this question
Alun Cox
