Question about Nokia e65 Cellular Phone
Nokia e65 stuck in offline mode.
I placed my Nokia e65 into offline mode. Now my kepad won't work and I can't use and buttons to get it out of offline mode. Any ideas.
  • mariqong2003 Nov 10, 2008
    my E65 always says offline mode, insert sim card and sim card registration. Sent it to Nokia Care, but nothing happen. Same problem, have to take off the battery
  • 4 Answers
Step 1>switch off your phone and turn it on again
step2>you should get a respond <: continue in offline mode>: select no
finally, i believe that everything should be ok.
if it doesn't there is alternative 2???/////
ALTERNATIVE TWO: this is useful for those who got INSERT SIM CARD RESPONSE.
WHY INSERT SIM CARD PROBLEM ?
my phone is 1yr and 6 months now and i discovered that as you remove and replace your Sim card numerous times, there is a big possibility that Sim card port will get expanded.
SOLUTION is very simple:.>>:1. buy a black solo tape
2. place it at the outer part of the sim card and use blade to cut exactly the same shape as the sim card.
3. finally stick the tape.
WARNING>>?do not stick the tape on where you have the Sim card service sensors.make use of your brain.
Posted on Jan 14, 2009
  • Olayemi Breakthrough Jun 14, 2012
    Thank you very much. your solution worked 4 me. THE CELLO Tape worked. I''m relieved and happy now. GOD BLESS YOU
1. Remove both ur sim card and memory card. Then insert only the sim card Then start up ur fone without d memory card. If doesnt work try no 2.
2.The sim card port of ur fone mite be loose due to frequent removal of ur sim. Just cut a black cello tape(the size of the sim) and gum it to the back of the sim and NOT THE SENSOR of the sim (the golden panel). then slide the sim into the sim port. Dat should work. It WORKED FOR MY nokia E65. continue enjoying ur fone. CHEERS
Posted on Jun 14, 2012
Have got a e65 nokia phone that screen flicers and i have tried to change the sreen but fault not solved.what could be the solution to this fault. gkemb.
the place of the screen cable needs repairing
it might be only dirt stuck on it so clean it with a teeth brush.
if it doesnt work means you have to change the place of the screen cable on board
May 10, 2011 | Nokia e65 Cellular Phone
My nokiae65 is in offline mode,how can i back in online mode?
Offline mode?What do you mean?clarify your question
Dec 26, 2010 | Nokia e65 Cellular Phone
Hi ya i have a Nokia E65 it keeps on saying offline mode, when i always txt or call it says insert sim card? do i need to get the unlock codes? or is there a fault in the fone......
The problem with this is that, the profile that you are operating on seems to place the phone at a position not to recognize any form of network or signal. I would suggest or recommend for you to change the phone profile and see what is going to happen next!
Dec 21, 2010 | Nokia e65 Cellular Phone
My nokia e65 cell phone is in offline mode, i cannot receive or make a call, how do i change it back to online mode
dear sir,
plz go to menu - profiles and select general mode..........
thank you...take care............
Oct 03, 2010 | Nokia e65 Cellular Phone
How do I take my Nokia E65 mobile phone off silent?
Please press and hold # button for 3 seconds it will go to silent mode.To deactive do the same thing it will go general mode.
You can also use the manual.
Thank You
Aug 16, 2010 | Nokia e65 Cellular Phone
I have a Nokia E65. I recently took my sim out to put in another sim and when I put the new sim in i turned the phone on and it says its offline. I tried to switch the profile from offline to general but...
I had the same problem with Nokia E66. Just a problem of SIM card contact points. Slide a piece of paper on top of your SIM card and put SIM-card paper back in the slot. The contact points work again. R.
May 17, 2010 | Cell Phones
I just have an e65 nokia cellphone but the phone is on offline mode.. how can i put it to online mode?
hi just select any other profile it will automatically deactivate offline mode
May 18, 2010 | Nokia e65 Cellular Phone
Cellphone remains in Offline profile and requests that sim be inserted while the sim is inserted in the cell. How do i get it to change profile?
just look to your profile and select the other profile not the last of the list.use general on your profile and your phone is not offline mode.tnx.
Nov 08, 2009 | Nokia e65 Cellular Phone
Nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
Jun 15, 2009 | Nokia e65 Cellular Phone
Nokia e65 Cellular Phone Logo
1,574 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
