Question about Sharp 32F640 32" TV
Sharp 32F640 32" TV works intermittently
I have a Sharp 32F640 32" TV that works beautifully when it works. Sometimes when turning it on, it attempts to turn on but will not. We can unplug it for a period of time and try turning it on again. Sometimes it will then turn on and sometimes it will not. We live at the beach. Could the moisture or salt in the air be causing this? If so, what can I do to fix it and stop it from occurring?
  • Gary Boyles Oct 06, 2006
    The model is actually Sharp 32F630 not 640
    Sergeant:
  • 337 Answers
The easiest thing to check is for loose conections because the unit is intermitant,the chassis should be check out for overheated areas and cracked solder joints in the power supply,horizontal driver and all the diodes and resistor off the secondary of the output trnasformer(flyback),if you are familiar with tv service this will help but if you are not too familiar be safe and call for assistance form a servicer.No doubt humidity can damage anything with time.
Posted on Oct 06, 2006
Our Sharp GA864WJSA TV intermittently turns itself off for a few seconds, then turns itself on again. Please help???
Sharp Aquos problem - YouTube
? 1:41
www.youtube.com/watch?v=-EuJZ9NUf3Y
Apr 24, 2012 - Uploaded by rsimon24
So my tv is just turning off by itself, some people tell that is a software issue, others resistance hardware. Has .
Sep 12, 2015 | Sharp Aquos Televison & Video
Strong is Beautiful. tm
Turn the power off to the television and everything connected to it. Count to 10 and just plug the television in. See if it works OK? If it does, start turning on each item connected one by one. If it comes back just on the television, I would contact Sharp.
http://www.sharp.ca/en-CA/CustomerSupport.aspx
Contact Us Sharp wants to hear from you.
Aug 20, 2015 | Sharp AQUOS LC-60LE920UN 60 inch 1080p...
Tv will intermittently not turn on. when i press the on/off switch i hear a click then i hear fans start up - the fans will die down to a steady speed. no raster. press on/off a few times then tv video...
Your Caps on the PSB- Power supply board are on their way out. Pretty soon it won't turn on at all. You will only get the Fault code blinking LED at startup. Recap the UF capacitors on the PSB. Works 90% of the time.
Jun 30, 2010 | LG MU-50PZ90C Television
I ve got a sharp aqueos tv i turned oevr channels
Try this: unplug the power cord from the wall, let TV set stand for AT LEAST 30 minutes, then plug back in and and see if the TV operates as normal.
Sometimes this works and sometimes it doesn't.
Good luck !
Jan 09, 2010 | Sharp 25N-M100 25" TV
Sharp Aquos not always starting up immediately when powering on??
I had the same exact thing happen. I think it's related to a failed firmware update attempt after reading a post on the AVS forum of a guy who also had this problem on this TV. What I did is plug back in the USB drive with the firmware update on it that I had used earlier, and the TV started right up.
Feb 25, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
No sound on Sharp Aquos 37' LC-37D4U
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
Particular thanks are owed ‘Aureius’ of the AVS forums for his research efforts concerning this issue !
Jan 25, 2009 | Sharp LC-37D4U 37 in. LCD Television
Sharp Aquos 32 nch TV, turn TV on, come on & goes off withn 2 sec
You have an intermittent power supply issue. See if you can get a used one on the cheap.
Aug 23, 2017 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp LC-30HV4U
I have the same problem with Sharp LC45GD4U intermittant turn off by itself ,somedays working OK..
Thanks.
Tanvo
Aug 26, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
Sharp 32F640 32" TV Logo
119 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
